How to remove fallback-dn Config from VG224?
kennedy.paul
Clearly I am missing something but just how do i remove the fallback-dn XXXX line of config from a VG224 voice gateway?
Cheers
stcapp ccm-group 1
stcapp
stcapp supplementary-services
port 2/0
  fallback-dn 12345
port 2/1
  fallback-dn 12346
port 2/2
  fallback-dn 12347
port 2/3
  fallback-dn 12348
port 2/4
  fallback-dn 12349
paolo bevilacqua
It is a consequence of configuring SCCP, cannot be removed, and does not cause any problem.
I was able to remove the fallback-dn. You have to turn off the stcapp supplementary-services and any stcapp features. Then you can negate the port. Example:
 no port 2/0/0
 fallback-dn 8396
