how to remove the ephone TAG after the CME remove from router
ciscoroyzhang
                   HI there,   after removed the CME in one of our branch office router, the TAG with 200XX and port with 50/0/XX, which is auto created when ephone has been enabled still existed. Can someone please help to advice how to remove the those auto created tag?
Thanks in advance
Roy
5 Replies 5
paolo bevilacqua
Conf t
no exphone
Hi Paolo,  thanks for the reply.  following is what I am talking about,  the command you suggestion is unrecognized in the router. this router is 2821 wiht IOS: C2800NM-SPSERVICESK9-M, try in 2911 same error. any other suggestion ? roy
20001  pots  up   down                              0                           50/0/1
20002  pots  up   down                              0                           50/0/2
20003  pots  up   down                              0                           50/0/3
20004  pots  up   down                              0                           50/0/4
20005  pots  up   down                              0                           50/0/5
20006  pots  up   down                              0                           50/0/6
20007  pots  up   down                              0                           50/0/7
20008  pots  up   down                              0                           50/0/8
20009  pots  up   down                              0                           50/0/9
Once you have issue the command avove, you can ignore anything else.
Please remember to rate useful posts clicing on the stars below.
Hi there,   is any one can help with this? or any suggestions?
thanks
Roy
Can you explain what is the problem are you having, particularly, what is NOT working ?
