06-19-2013 09:20 AM - edited 03-16-2019 05:58 PM
I have a user with an IP 7942 that is always saying "registering". We've already changed out the cable and it persists even after a reset on the phone.
I have a spare phone that I was to assign this user.
Is it really as simple as changing the MAC address on the PHONE CONFIGURATION page and saving and applying the config, then have the user plug in the new phone? Or is there more to it or a different method required?
Sorry, I'm new to CUCM/CallManager and learning as I go. I tried to find a "moves/adds/changes" cheat sheet somewhere...
Solved! Go to Solution.
06-19-2013 09:27 AM
Hi Chris,
You can certainly do it the way you listed by changing the MAC
save/apply. or another nice way is super copy
Cheers!
Rob
"I don't know how, I don't know when
But you and I will meet again "
- Tom Petty
06-19-2013 09:27 AM
Hi Chris,
Cheers!
Rob
- Tom Petty
06-19-2013 09:33 AM
Yes, you only need to change the MAC address, save and the phone should register. If the other phone is not working you can try a factory reset:
Tere.
If you find this post helpful, please rate!
