10-19-2016 06:51 AM - edited 03-17-2019 08:24 AM
Dear All,
Hope you all doing well.
We have collected Be6k demo device, however, we dont have the login and password of the ESXi .
Anyone know how to reset the be6k as a fresh installation? or how to reset the ESXi?
Million thanks.
Best Regards,
Ben
10-19-2016 09:03 AM
Default username and password for CIMC is admin and password respectively. For ESXi, it should be root and password. If these do not work then that means it had been changed and you should check with the person who gave it you in the first place
Deepak
10-19-2016 09:21 AM
I don't think there's a supported way to reset the ESXi password, you can google that, or look at VMWare info, but last time I checked, that was pretty much like trying to do the same for windows.
