07-14-2016 12:03 PM - edited 03-17-2019 07:32 AM
Hi Guys,
Is it possible to route all calls to the certain phone number (333-111-2222) to the specific Line (Line 3) on the phone?
[PRI > Voice Gateway > CUCM 9.2 > ip phone]
Thank you
07-14-2016 12:12 PM
Yes, it is.
If provider is sending 10 digits for example in this case 333 111 2222 then you can forward same to CUCM and if line 3 is 2222 then do a translation pattern for 333 111 2222 to 2222 .
Or you can also do translation at the gateway if you using SIP or h323 gateway and then send only internal extension to the CUCM.
07-14-2016 01:47 PM
Or just set the significant digits to 4 in the GW config.
In any case, yes, if it's not a DID, just configure whatever call manipulation that is required.
