How to send After Hours Incoming calls straight to Voicemail
Bahlul Guliyev
Hello all,
Can anybody tell me how to configure after hours incoming calls go to Voicemail?
Best Regards
Suresh Hudda
Hello Bahlul,
You can refer below thread to achieve this, if still you have issue the pls post here back.
https://supportforums.cisco.com/discussion/10819201/send-after-hours-incoming-calls-straight-voicemail
Suresh
Deepak Rawat
Time of Day routing is what you need to achieve this using Call Manager and Unity Connection, refer below:
https://supportforums.cisco.com/document/54501/how-configure-time-day-routing-communications-manager
In case, you have UCCX there then configure the TOD in script and send the call to Voice Mail after hours, let me know if you need help configuring this in the script.
Deepak
