how to set Pre-announcement instead of ringback tone
yaser weis
how can i set specific announcement play instead of ring back tone in CUCM phones
Thanks in advance
22 Replies 22
Check Algorithm type in hunt group i think you have selected Broadcast change it from CUCM.
Hi ,
I have the same problem,
I am blocked in step 7, when I choose "My Personnal Record" I get no window to uplaod my file
HI Chafi,
In this case please make sure that you installed Java in this machine, and no firewall blocks it.
Mohamed Helmy
Regards, Mohamed Helmy
Hi Mohamed,
Kindly i used UCCX as a solution and it's work very well
Many Thanks,
Hi Yaser,
Can you show me the procedure to do on UCCX and what scenario you did on the script?
Hi Yaser,
Actually it was more easier to do this using UCCX, but you didn't give any hint that you already have it :)
this is the normal setup for UCCX.
any way, good luck
Mohamed Helmy
Bear in mind the above method would need manual config for every single user you want to have this.
java
if this helps, please rate
I also would keep in mind, that a calling user will pay for an unansewred call. Just my 2 cents Regards Carlo
Please rate all helpful posts "The more you help the more you learn"
