how to set up paging for cisco 8841
mccluregraden
hello, we have a paging system that used to be and still have a few analog phones on it. We decided to get voip phones for it. We got cisco 8841 phones for it. Now we can't  get it to work. How do you access paging on them or what we need to get paging for us.
Cisco Paging Server is an OEM of Singlewire Informacast. IIRC, it provides <75 member page groups for free.
Webex Calling multi-tenant also has a built-in IP Phone paging capability up to 75 members.
Jaime Valencia
There's no way for anyone to assist if you don't mention the products you're working with.
CUCM doesn't have paging, you need informacast for that.
If you're using something else, then you need to discuss this with the vendor of your paging system.
java
if this helps, please rate
Thanks you so much  just what I need
