10-03-2018 10:14 AM - edited 03-17-2019 01:32 PM
Hello Experts,
Can you please help me ?
I have 2 question after capturing pacquet from CUCM.
I have executed the command utils network capture file mycap count 100000 size all host 10.150.1.1 on the CUCM.
1) My session timed out Before I typing Ctrl-C.
How can I stop the capture please ?
2) How can i delete existing PCAP capture on the CUCM server ?
Thanks In advance.
Zanga
Solved! Go to Solution.
10-03-2018 12:46 PM
Hello Zanga,
If the session times out the packet capture stops and the file then gets saved on CUCM.
To check the CUCM files use the following command:
file list activelog platform/cli/* detail
Then to delete the packet capture use:
file delete activelog platform/cli/<name of the capture file>
You can also check and delete the files from the Cisco Unified Real Time Monitoring tool by going to
Tools > Trace & Log Central > Trace & Log Central > Remote Browse > "Trace Files" > Check on "Cisco CallManager" hit next and select "Packet Capture Logs" too. Then "Finish".
Yeikol E.
10-03-2018 11:14 AM
You may check all capture files with the following command:
To delete the file you may use this:
file delete activelog platform/cli/<your file name>
I am not sure if you will be able to finish it before packet count reaches 100000.
I will test in a lab.
Gilmar Silva
10-03-2018 11:20 AM
I started a packet capture in lab and closed the putty session.
It seems the capture is interrupted when the session closes, so I think you will be able to delete the file with no issues.
10-03-2018 12:46 PM
Hello Zanga,
Yeikol E.
10-05-2018 10:25 AM
Hello experts,
I delete the capture and try to cupture another yesterday.
utils network capture eth0 file packets count 2000 size all host ip 10.160.7.10
Yesterday i file was blank, I got that output today. Please What can cause that ?
Zanga
