How to super copy phone setup to a different phone model
sheletal82
We are upgrading many of our 7960 phones to 8945's.  I had been setting up the new phones manually but recently learned about the copy and super copy features.  I am not able to take advantage of the copy features however because the copy of the phone doesn't allow me to change the model or device security profile.  Is there a way around this?
Aaron O'Hare
Super Copy is only like model to like model.
BAT would be the best way to do this, export the existing phones, update MAC addresses, import the phones.
-AO
Please rate useful posts and mark answers as "correct" if applicable.
Aaron O'Hare
-AO
Thank you.  I'm new to CUCM so I'll look in to that.
This doesn't do all the config settings I was hoping for.  I wanted the device pool, the CSS, the region, etc, etc, etc.  Maybe I'm using the wrong 'export.'
I went to Bulk Admin >> Phones >> Export Phones >> All details.  Is there a different way?
I have a receptionist phone that she's upgrading from a 7970 to an 8861.  It's going to take me a long time to get all the settings converted from the 7970 to the 8861.
7970 -----------
Description
Device PoolRequired Field
 View Details
Common Device Configuration
 View Details
Phone Button TemplateRequired Field
Softkey Template
Common Phone ProfileRequired Field
 View Details
Calling Search Space
AAR Calling Search Space
Media Resource Group List
User Hold MOH Audio Source
Network Hold MOH Audio Source
LocationRequired Field
AAR Group
User Locale
Network Locale
Built In BridgeRequired Field
PrivacyRequired Field
Device Mobility ModeRequired Field
 View Current Device Mobility Settings
Owner     User Anonymous (Public/Shared Space)
Owner User IDRequired Field
Mobility User ID
Phone PersonalizationRequired Field
Services ProvisioningRequired Field
Phone Load Name
Single Button Barge
Join Across Lines
Use Trusted Relay PointRequired Field
BLF Audible Alert Setting (Phone Idle)Required Field
BLF Audible Alert Setting (Phone Busy)Required Field
Always Use Prime LineRequired Field
Always Use Prime Line for Voice MessageRequired Field
Geolocation
Retry Video Call as Audio
Ignore Presentation Indicators (internal calls only)
Allow Control of Device from CTI
Logged Into Hunt Group
Remote Device
Protected Device
Hot line Device
Require off-premise location
Number Presentation Transformation
Caller ID For Calls From This Phone
Calling Party Transformation CSS
Use Device Pool Calling Party Transformation CSS (Caller ID For Calls From This Phone)
Remote Number
Use Device Pool Calling Party Transformation CSS (Device Mobility Related Information)
Protocol Specific Information
Packet Capture ModeRequired Field
Packet Capture Duration
BLF Presence GroupRequired Field
Device Security ProfileRequired Field
SUBSCRIBE Calling Search Space
Unattended Port
Require DTMF Reception
RFC2833 Disabled
Certification Authority Proxy Function (CAPF) Information
Certificate OperationRequired Field
Authentication ModeRequired Field
Authentication StringRequired Field
Key OrderRequired Field
RSA Key Size (Bits)Required Field
EC Key Size (Bits)Required Field
Operation Completes By     (YYYY:MM:DD:HH)
Certificate Operation Status:     None
Note: Security Profile Contains Addition CAPF Settings.
Expansion Module Information
Module 1
Module 1 Load Name
Module 2
Module 2 Load Name
External Data Locations Information (Leave blank to use default)
Information
Directory
Messages
Services
Authentication Server
Proxy Server
Idle
Idle Timer (seconds)
Secure Authentication URL
Secure Directory URL
Secure Idle URL
Secure Information URL
Secure Messages URL
Secure Services URL
Extension Information
Enable Extension Mobility
Log Out Profile
Log in Time     < None >
Log out Time     < None >
MLPP and Confidential Access Level Information
MLPP Domain
MLPP IndicationRequired Field
MLPP PreemptionRequired Field
Confidential Access Mode
Do Not Disturb
Do Not Disturb
DND OptionRequired Field
DND Incoming Call Alert
Secure Shell Information
Secure Shell User
Secure Shell Password
Product Specific Configuration Layout
Help    Parameter Value    Override Enterprise/Common Phone Profile Settings
Disable Speakerphone
Disable Speakerphone and Headset
Forwarding DelayRequired Field
PC Port Required Field
Settings AccessRequired Field
Gratuitous ARPRequired Field
PC Voice VLAN AccessRequired Field
Video CapabilitiesRequired Field
Auto Line SelectRequired Field
Web AccessRequired Field
Days Display Not Active
Display On Time
Display On Duration
Display Idle Timeout
Enable Power Save Plus
Phone On Time
Phone Off Time
Phone Off Idle TimeoutRequired Field
Enable Audible Alert
EnergyWise Domain
EnergyWise Endpoint Security Secret
Allow EnergyWise Overrides
Span to PC PortRequired Field
Logging DisplayRequired Field
Load Server
Recording ToneRequired Field
Recording Tone Local VolumeRequired Field
Recording Tone Remote VolumeRequired Field
Recording Tone Duration
Display On When Incoming CallRequired Field
RTCPRequired Field
"more" Soft Key Timer
Auto Call SelectRequired Field
Log Server
Advertise G.722 CodecRequired Field
Wideband Headset UI ControlRequired Field
Wideband Handset UI ControlRequired Field
Wideband HeadsetRequired Field
Wideband HandsetRequired Field
Peer Firmware SharingRequired Field
Cisco Discovery Protocol (CDP): Switch PortRequired Field
Cisco Discovery Protocol (CDP): PC PortRequired Field
Link Layer Discovery Protocol - Media Endpoint Discover (LLDP-MED): Switch PortRequired Field
Link Layer Discovery Protocol (LLDP): PC PortRequired Field
LLDP Asset ID
LLDP Power PriorityRequired Field
IPv6 Load Server
IPv6 Log Server
802.1x AuthenticationRequired Field
Detect Unified CM Connection FailureRequired Field
Minimum Ring VolumeRequired Field
Headset Sidetone LevelRequired Field
HTTPS ServerRequired Field
Enbloc DialingRequired Field
Switch Port Remote ConfigurationRequired Field
PC Port Remote ConfigurationRequired Field
Automatic Port SynchronizationRequired Field
SSH AccessRequired Field
LOGIN AccessRequired Field
FIPS ModeRequired Field
80-bit SRTCPRequired Field
Customer Support Use
