How to tell which dn is using a PRI channel
gb-fairchild
I'm looking at
my gateway and can see from using the show voice port stat command that one channel on the
PRI  (MGCP) is in use.  Is there a way to tell who (which DN) is using it?  I want to shut down the gateway to change a PVDMII but don't just want to dump whoever is using it.
Bill
Gordon Ross
Level 9
Level 9
You can't with MGCP.
Please rate all helpful posts.
Thanks - Can't do it from the router because the D-channel is backhauled to Call Manager?  But Call Manager knows - it will create a CDR record for it so you would think it could be done from there some how.
You're correct, in that CUCM does know. However, Cisco have decided not to expose that information.
(remember, CDRs don't get written 'till the call has completed)
GTG
