How to upgrade AS5350XM
vadoodetm
I have a AS5350XM. This is what I have got on it. I know that the device is outdated but wanted to find modules from ebay and upgrade it to support 2 more E1 lines. I intend to buy another E1 2 PRI DFC card and install it on the slot 2. But I am not sure if this device will support these 2 cards (and 100+ concurrent calls) or not.
I also wonder what exactly this VUFC does. Will it support 4 E1 links? Will i need to replace it with a AS5XM-VUFC-108NP?
Slot 1:
DFC type is AS5350XM NP60 VUFC
Slot 2:
DFC type is AS5350XM Empty DFC
Slot 3:
DFC type is AS5350XM E1 2 PRI DFC
