Showing results forĀ
Search instead forĀ
Did you mean:Ā
How to upgrade IOS on Cisco Router 2801 ?
Fida jlassi
Bellow the router's information
Cisco 2801 (revision 7.0)
CME 4.1(0)
IOS 12.4(11)XJ
Now, I want to upgrade Cisco IOS to the 15.1(3)T  IOS.
I don't have any CD. I don't know the method, though I have NEVER upgraded IOS before.
Please tell me:
1. How can I get the 15.1(3)T version of Cisco IOS for Router 2801 ?
2. How can I get the program to use to backup and restore the Router's configurations ?
Hi Fida,
You need to look into below  steps:
a. Check the DRAM and Flash Size before u upgrade IOS?
b. You need to have CCOId to download the desired 15.x version.
c. take backup of startup-config by using command copy startup-config  tftp:
d. upgrade IOS of router using command copy tftp: flash:c28xx.bin [desired version]
e. before u start steps c and d , download tftpd32 software fron Internet and run in a PC . tftp should run in background.while taking backup and upgrading IOS.
Also, as suggested by Mr. Paolo, u should involve consultant to work on live router.
regds,
aman
paolo bevilacqua
Both questions are often asked and discussed if you could take the time to search before asking.
My recommendation however is that you engage a reputable consultant, or UC certfied Cisco partner, instead of trying to do yourself.
If you have a link that explain the procedure and that could answer to my questions I would be grateful.
Hi Fida,
regds,
aman
