05-02-2025 07:43 AM
Hi, cucm version 12, created line group with 3 numbers (A, B,C) then hunt list then hunt group . User complained that order when someone calls is not A, B, C but B, A, C
Anyone has idea why and how to fix this?
Thank you
Solved! Go to Solution.
05-02-2025 07:54 AM - edited 05-02-2025 07:55 AM
Check the algorithm at the line group level. To have the hunted calls always be A-B-C you will want to select "Top Down", which is not the default.
Also, the Route Plan Report does not reflect the order of the hunt but only shows a list of the numbers in a Line Group.
Maren
Maren
05-02-2025 08:41 AM
Thank you
