165
G3261
Participant
Hunt Group solution
Hello, I was asked to provide a solution for following scenario---
There are 2 DIDs -1111 and 2222. Create a hunt group for calls to 1111 and if all agents are busy,  queue the calls and play a message after 1min saying someone will be with you shortly ( I can do that) ....However, if a special group of people call 2222, these calls should take priority over calls to 1111 and these calls should be handled right away.  How do I present these 2222 calls to agents if they are already dealing with calls to 1111?   Is there anyways I can achieve by hunt group? I can also use Unity for this setup but NO uccx. I can give agents 2nd line for priority calls only but then that would have nothing do with hunt group.
CUCM 11.5
Unity 11.5
4 REPLIES 4
Roger Kallberg
VIP Advisor
With the systems you have available this is not possible to achieve. You would need to have a contact centre solution in place for this, like UCCX.
Response Signature
thank you
Nithin Eluvathingal
VIP Advisor
With CUCM Hunt group  or CUC AA we cant achieve this.
Response Signature
Thank you
Create
Recognize Your Peers
Content for Community-Ad
