Hunt Pilot using VG224 analog lines
MICHAEL CICCONE
I'm trying to setup a hunt pilot using serveral analog lines from my vg224.  When I use these DN numbers assoicated with the VG
224 I get a busy signal.  if I use any other DN number, such as an IP phone the Hunt pilot works correctly.  Since it works correctly with
the IP Phone DN number, I'm guessing I have the hunt pilot configured correctly.  Is there any reason why it won't work with DN numbers assoicated with a VG224 device?  I'm using Call Manager 6.1.4.2000-5.  VG224 IOS is 12.4(24)T3
Mike C.
Rob Huffman
Hi Mike,
The VG224 ports are "logged out" of Hunt Groups by default.
If you put a tick in the "Logged into Hunt Group" box at the Device Level on the VG224 that should fix it."
Hope this helps!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Rob Huffman
Hi Mike,
Hope this helps!
Rob
Rob,
Thanks so much for the quick response...  Its working now.
Cheers
Mike
Hey Mike,
Glad to be of some small help here my friend
Cheers!
Rob
saif musa
Level 4
Level 4
Thanks, the post was helpful for me also
