Hunt pilote probleme
csp-reseau.rt1
when i call the pilot hunt number internally, three members of the group line ring but not the others, i have 7 members in all. note RNA Reversion Timeout is 180 and the Distribution Algorithm is diffuser
I also looked in the same version and we don’t either have the option the OP has. Something seems to be fishy in that specific system. Advise to reach out to TAC for assistance.
Response Signature
6 Replies 6
What you mean by algorithm diffuser, I couldn't see this option on my CUCM. What versions of CUCM you use ? I have only the below options.
Response Signature
Active Version12.5.1.14900-63
That’s strange, the screenshot which I shared above is exactly the same version.
But I have no option called diffuser and it’s broadcast.
I cross checked and it’s broadcast for me.
And broadcast works as expected..
I think you may need to open a TAC ticket.
Response Signature
Ok, but when i call this hunt pilote, the partition is null on CDR logs, but this hunt pilote have a partition.
Best regards,
Response Signature
i will add my name to the same version-no such option list.
