Hunting in CUCM 6.1.2
dc-csa-chn
Beginner
Beginner
I need assistance in the Hunting settings
we are using CUCM 6.1.2 ,the hunting is working good.
But i want to customize the settings
Required
1.When the members of the Line Group dial outside for Internal extension (CUG) calls . It should Only display the Text "XYZ Team"
2.For Incoming calls coming to that Line group. it should display the DN of the calling Party.
Tried:
1.I tried the Internal alerting, caller Id parameters.But it shows the DN(EXTN) in Braces
eg: XYZ(1234)
2.Tried CLI Resticted option in Hunt Pilot getting Only "PRIVATE" for both incoming and Outcoming.
Looking for the solution
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Look at this for the outbound calls
Call Display Restrictions
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmfeat/fshosp.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
As Per document
i have created a Translation Pattern for Hunt Pilot .
In Translation Pattern
1. I tried Calling Name Presentation -Allowed
2.I tried Connected name Presentation
-allowed
While Calling and Connected Line ID are in restricted.
I am able to see the incoming calls calling the Translation Pattern
Calling Party --- Private
Called Party --- DN of calling Party.
It's Good.
When i am making an outbound call from the line group to calling Party through directory,
It shows
Calling Party --Extension
Called Party --XYX (DN)
Need assistance for the Outbound calls.
Recognize Your Peers
