HW conference not working with offnet call
nmdc.kzstan
I configured two conference bridges, both registered to CUCM: HW on ISR and SW on CUCM. Conferences on both bridges work fine with internal extensions. I can add offnet party (GSM or PSTN) to the conference only if SW conference bridge chosen in MRGL of Meetme conference initiating IP phone. Only G.711 codec is used in internal LAN and offnet calls.
TIA
Jaime Valencia
What codecs do you have configured in the HW CFB??
Is it registered??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
When trying to call to GSM number from existing conference CUCM sends CANCEL SIP message after TRYING message from GSM gateway.
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 1
associate application SCCP
Problem resolved after configuring "maximum sessions 2" under dspfarm profile.
