I am getting hacked, CME12.0 WHY?
Michael Durham
Level 4
Level 4
I have two CME systems both version 12.  One of them is getting hacked where someone is making international calls as though I was dialing them myself and for the life of me, I cannot figure out why?
The config is nearly identical between the two systems and both are in the same building so its not a firewall issue.
For the protected and NON hacked system we have the following config:
interface GigabitEthernet0/2
ip address 123.456.12.130 255.255.255.224 secondary
ip address 123.456.217.58 255.255.255.248
ip access-group Protect in
ip nat outside
ip virtual-reassembly in
no ip route-cache
duplex auto
speed auto
Extended IP access list Protect
10 permit tcp any any established (212736198 matches)
20 permit tcp any host 123.456.217.58 eq ftp (4174 matches)
30 permit tcp any eq ftp any (2 matches)
40 permit tcp any host 123.456.217.58 eq domain (350 matches)
50 permit udp any host 123.456.217.58 eq domain (1613 matches)
60 permit tcp any host 123.456.217.58 eq 443 (2624 matches)
70 permit udp any host 123.456.217.58 eq isakmp (501084 matches)
80 permit tcp any host 123.456.217.58 eq 1194 (21 matches)
90 permit udp any host 123.456.217.58 eq 1194 (1779714 matches)
100 permit tcp any host 123.456.217.58 range 2000 2099 (697 matches)
110 permit udp any host 123.456.217.58 eq non500-isakmp (799177 matches)
120 permit tcp any host 123.456.217.58 eq 5060 (637 matches)
130 permit udp any host 123.456.217.58 eq 5060 (169570 matches)
140 permit udp any host 123.456.217.58 range 16384 32767 (4602154 matches)
150 permit gre any host 123.456.217.58 (7 matches)
160 permit esp any host 123.456.217.58 (75345 matches)
170 permit ahp any host 123.456.217.58
180 permit udp any eq domain any (1746522 matches)
190 permit udp any eq 5010 any (79054 matches)
200 permit tcp any host 123.456.217.58 eq 9090 (5888 matches)
210 permit udp any eq ntp any (52899 matches)
220 permit icmp any any (391980 matches)
230 deny ip any any log (320101 matches)
IPs and passwords have been changed.  Below is the config from the system getting hacked.  So far, they have made over $800.00 is fraud calls At the end is a few reports from the hacked system.  It is not offline but I can get any report needed.
Current configuration : 30710 bytes
! Last configuration change at 22:42:30 DST Fri Jul 24 2020 by psesupport
! NVRAM config last updated at 17:07:50 DST Fri Jul 24 2020 by psesupport
version 15.6
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime year
service password-encryption
service internal
service sequence-numbers
hostname PSE_2900
boot-start-marker
boot-end-marker
logging message-counter log
logging buffered 100000
logging monitor notifications
enable secret cisco
aaa new-model
aaa local authentication attempts max-fail 6
aaa authentication login default local
aaa session-id common
ethernet lmi ce
clock timezone Eastern -5 0
clock summer-time DST recurring
crypto pki trustpoint TP-self-signed-2514444448
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-251444448
revocation-check none
rsakeypair TP-self-signed-25164444958
crypto pki certificate chain TP-self-signed-2516279958
certificate self-signed 01
quit
ip dhcp smart-relay
ip dhcp relay information option
ip dhcp excluded-address 192.168.100.1 192.168.100.100
ip dhcp excluded-address 192.168.150.1 192.168.150.100
ip dhcp excluded-address 192.168.200.1 192.168.200.100
ip dhcp pool Customer_Data
network 192.168.100.0 255.255.255.0
dns-server 192.168.100.1
default-router 192.168.100.1
option 150 ip 192.168.200.1
lease 0 12
ip dhcp pool Customer_WiFi_Guests
network 192.168.150.0 255.255.255.0
dns-server 4.2.2.2
default-router 192.168.150.1
lease 0 12
ip dhcp pool Customer_Voice
network 192.168.200.0 255.255.255.0
dns-server 192.168.200.1
default-router 192.168.200.1
lease 0 12
ip domain lookup source-interface GigabitEthernet0/0
ip domain name Customer
ip host Public_IP_Address 123.456.12.150
ip name-server 4.2.2.2
ip name-server 8.8.4.4
ip name-server 8.8.8.8
ip inspect WAAS flush-timeout 10
ip cef
login block-for 90 attempts 3 within 10
login delay 10
login on-success log
no ipv6 cef
stcapp feature access-code
password encryption aes
voice-card 0
dsp services dspfarm
voice service pots
fax rate disable
voice service voip
ip address trusted list
ipv4 777.999.149.969
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
fax protocol none
sip
registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711ulaw
voice register global
mode cme
source-address 192.168.200.1 port 2000
bandwidth video tias-modifier 512000 negotiate end-to-end
max-dn 100
max-pool 30
load 8811 sip88xx.12-6-1-0001-668.loads
timezone 13
voicemail 2000
url authentication http://192.168.100.1/CCMCIP/authenticate.asp
tftp-path flash:
create profile sync 0090253921825175
camera
video
auto-register
voice register dn 1
number 1000
name Technologies
voice register dn 11
number 6001
name John Wayne
voice register dn 12
number 6002
name Lacey
voice register dn 13
number 6003
name Michael
voice register pool 1
busy-trigger-per-button 2
id mac 84B5.17AE.bbbb
type 8811
number 1 dn 11
number 2 dn 1
dtmf-relay sip-notify
voice-class codec 1
username user1 password 1234
voice register pool 12
pin 1234
id mac 00CC.FC4A.aaaa
type DX650
number 1 dn 1
number 2 dn 12
voice-class codec 1
username mike password 1234
camera
video
voice register pool 13
pin 1234
id mac 2C73.A02C.cccc
type 8851
number 1 dn 1
number 2 dn 13
voice-class codec 1
username bob password 1234
voice translation-rule 1
rule 1 /18005551212/ /1000/
voice translation-rule 2
rule 1 /411/ /18003733411/
voice translation-rule 3
rule 1 /611/ /18002003004/
voice translation-rule 4
rule 1 reject /^011/
rule 2 reject /^900.......$/
rule 3 reject /^1900.......$/
voice translation-rule 5
rule 1 /1.../ /18005551212/
rule 2 /6.../ /18005551212/
voice translation-rule 6
rule 1 /\([2-9].........\)/ /1\1/
voice translation-rule 7
rule 1 /1.../ /1000/
voice translation-profile 411_CALL_FREE_411
translate calling 5
translate called 2
voice translation-profile 611_CALL_PSE_SUPPORT
translate calling 5
translate called 3
voice translation-profile BLOCK-OUTBOUND_INT+900
translate calling 4
voice translation-profile CONVERT_OUTBOUND_CALLER-ID
translate calling 5
voice translation-profile Hunt_Group_2_to_VVM_1000
translate calling 7
translate redirect-called 7
voice translation-profile INBOUND_CALL_CONVERT_CALLER-ID
translate called 1
voice translation-profile OUTBOUND_C-ID+10_DIGIT_DIALING
translate calling 5
translate called 6
license udi pid CISCO2951/K9 sn FTX1527ALG3
license boot module c2951 technology-package securityk9
license boot module c2951 technology-package uck9
hw-module ism 0
hw-module pvdm 0/2
hw-module sm 1
file privilege 0
dial-control-mib retain-timer 10080
dial-control-mib max-size 500
username support privilege 15 secret cisco
redundancy
notification-timer 120000
crypto keyring CUSTOMER-KEYRING
local-address GigabitEthernet0/0
pre-shared-key address 123.456.217.58 key Florida_32025_LC
pre-shared-key address 0.0.0.0 0.0.0.0 key 6 Customer_Home_000
crypto logging session
crypto isakmp policy 100
encr aes 256
hash sha512
authentication pre-share
group 16
lifetime 3600
crypto isakmp keepalive 10 periodic
crypto isakmp profile CUSTOMER-ISAKMP
match identity address 0.0.0.0
crypto ipsec transform-set CUSTOMER-TSET esp-aes esp-sha512-hmac
mode tunnel
crypto ipsec profile CUSTOMER-IPSEC
set security-association lifetime seconds 86400
set transform-set CUSTOMER-TSET
set isakmp-profile CUSTOMER-ISAKMP
interface Tunnel0
description DMVPN mGRE tunnel to support
bandwidth 100000
ip address 172.16.0.99 255.255.0.0
no ip redirects
ip mtu 1400
ip nhrp authentication CiscO
ip nhrp map 172.16.0.1 123.456.217.58
ip nhrp map multicast 123.456.217.58
ip nhrp network-id 666
ip nhrp nhs 172.16.0.1
ip tcp adjust-mss 1360
shutdown
cdp enable
tunnel source GigabitEthernet0/0
tunnel mode gre multipoint
tunnel key 666
tunnel protection ipsec profile CUSTOMER-IPSEC shared
interface Tunnel200
description mGRE - DMVPN Tunnel for Remote Home User
bandwidth 1000000
ip address 172.20.0.1 255.255.255.252
no ip redirects
ip mtu 1400
ip nhrp authentication CHANGE
ip nhrp network-id 5617
shutdown
cdp enable
tunnel key 5617
interface Embedded-Service-Engine0/0
no ip address
shutdown
description Internet Access Port
ip address 123.456.12.150 255.255.255.224
ip nat outside
no ip route-cache
shutdown
duplex auto
speed auto
interface ISM0/0
description Cisco Unity Express VoiceMail/AA Module
ip unnumbered GigabitEthernet0/1.200
ip nat inside
no ip route-cache
!Application: CUE Running on ISM
interface GigabitEthernet0/1
description Connects to Cisco 3750G-PoE Switch port GI1/0/48
no ip address
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0/1.100
description Data Network
encapsulation dot1Q 100 native
ip address 192.168.100.1 255.255.255.0
ip nat inside
no ip route-cache
interface GigabitEthernet0/1.150
description Guest WiFi Network
encapsulation dot1Q 150
ip address 192.168.150.1 255.255.255.0
ip access-group 100 in
ip nat inside
no ip route-cache
interface GigabitEthernet0/1.200
description Voice Network
encapsulation dot1Q 200
ip address 192.168.200.1 255.255.255.0
ip nat inside
no ip route-cache
no ip address
shutdown
duplex auto
speed auto
interface ISM0/1
no ip address
interface Vlan1
no ip address
router eigrp 9001
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:GUI
ip dns server
ip nat inside source list 10 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 123.456.12.129
ip route 192.168.50.0 255.255.255.0 172.20.0.2
ip route 192.168.69.0 255.255.255.0 172.16.0.1
ip route 192.168.200.2 255.255.255.255 ISM0/0
ip access-list extended Protect
remark - Protect Internet inbound connection
permit tcp any host 12.456.12.150 eq domain
permit udp any host 12.456.12.150 eq domain
permit tcp any host 12.456.12.150 eq 443
permit udp any host 12.456.12.150 eq isakmp
permit udp any host 123.456.12.150 eq non500-isakmp
permit tcp any host 123.456.12.150 eq 1194
permit udp any host 123.456.12.150 eq 1194
permit tcp any host 123.456.12.150 eq 5060
permit udp any host 123.456.12.150 eq 5060
permit udp any host 123.456.12.150 range 16384 32767
permit gre any host 123.456.12.150
permit esp any host 123.456.12.150
permit ahp any host 123.456.12.150
permit icmp any any
deny ip any any log
logging history size 100
logging history notifications
ixi transport http
response size 64
no shutdown
request outstanding 1
ixi application cme
no shutdown
nls resp-timeout 1
cpd cr-id 1
tftp-server flash0:/PhoneFiles/8811-41-51-61/vc488xx.12-6-1-0001-668.sbn alias vc488xx.12-6-1-0001-668
tftp-server flash0:/PhoneFiles/8811-41-51-61/ssb288xx.BE-01-007.sbn alias ssb288xx.BE-01-007
tftp-server flash0:/PhoneFiles/8811-41-51-61/sip88xx.12-6-1-0001-668.loads alias sip88xx.12-6-1-0001-668
tftp-server flash0:/PhoneFiles/8811-41-51-61/sb288xx.BE-01-026.sbn alias sb288xx.BE-01-026
tftp-server flash0:/PhoneFiles/8811-41-51-61/sb2388xx.BE-01-026.sbn alias sb2388xx.BE-01-026
tftp-server flash0:/PhoneFiles/8811-41-51-61/sb2288xx.BE-01-013.sbn alias sb2288xx.BE-01-013
tftp-server flash0:/PhoneFiles/8811-41-51-61/rootfs88xx.12-6-1-0001-668.sbn alias rootfs88xx.12-6-1-0001-668
tftp-server flash0:/PhoneFiles/8811-41-51-61/rootfs388xx.12-6-1-0001-668.sbn alias rootfs388xx.12-6-1-0001-668
tftp-server flash0:/PhoneFiles/8811-41-51-61/rootfs288xx.12-6-1-0001-668.sbn alias rootfs288xx.12-6-1-0001-668
tftp-server flash0:/PhoneFiles/8811-41-51-61/preloader88xx.BE-01-002.sbn alias preloader88xx.BE-01-002
tftp-server flash0:/PhoneFiles/8811-41-51-61/m0patch288xx.BE-01-001.sbn alias m0patch288xx.BE-01-001
tftp-server flash0:/PhoneFiles/8811-41-51-61/kern288xx.12-6-1-0001-668.sbn alias kern288xx.12-6-1-0001-668
tftp-server flash0:/PhoneFiles/8811-41-51-61/kern388xx.12-6-1-0001-668.sbn alias kern388xx.12-6-1-0001-668
tftp-server flash0:/PhoneFiles/8811-41-51-61/fbi88xx.BE-01-012.sbn alias fbi88xx.BE-01-012
tftp-server flash0:/PhoneFiles/8811-41-51-61/boot1288xx.BE-01-007.sbn alias boot1288xx.BE-01-007
tftp-server flash0:/PhoneFiles/8811-41-51-61/kern88xx.12-6-1-0001-668.sbn alias kern88xx.12-6-1-0001-668
tftp-server flash0:/Ringtones/RingList.xml alias RingList.xml
tftp-server flash0:/Ringtones/RingList-wb.xml alias RingList-wb.xml
tftp-server flash0:/Ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash0:/Ringtones/Analog1.raw alias Analog1.raw
tftp-server flash0:/Ringtones/Analog2.raw alias Analog2.raw
tftp-server Desktops/800x480x24/List.xml
tftp-server Desktops/800x480x24/PSE_800x480be.png
tftp-server Desktops/800x480x24/PSE_800x480bs.png
tftp-server Desktops/800x480x24/PSE_800x480E.png
tftp-server Desktops/800x480x24/PSE_800x480S.png
access-list 10 remark Networks Allowed onto the Internet
access-list 10 permit 172.20.0.0 0.0.255.255
access-list 10 permit 192.168.100.0 0.0.0.255
access-list 10 permit 192.168.150.0 0.0.0.255
access-list 10 permit 192.168.200.0 0.0.0.255
access-list 20 remark Networks Allowed onto the router's web server
access-list 20 permit 192.168.100.0 0.0.0.255
access-list 50 remark VTY_ACCESS_CONTROL
access-list 50 permit 192.168.0.0 0.0.255.255
access-list 50 deny any
access-list 100 remark "Block Guest WiFi network to everything except ntp & the Internet
access-list 100 permit ip any 192.168.150.0 0.0.0.255
access-list 100 deny ip any 192.168.0.0 0.0.255.255
access-list 100 permit ip any any
control-plane
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/1.200
sccp ccm 192.168.200.1 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/1.200
associate ccm 1 priority 1
no ccm-manager fax protocol cisco
dspfarm profile 1 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec pass-through
codec g722-64
codec g729r8
maximum sessions 2
associate application SCCP
shutdown
dspfarm profile 2 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g722-64
maximum sessions 2
shutdown
dial-peer cor custom
name LoK_Local
name LoK_National
name LoK_International
name LoK_EMS
dial-peer cor list Keyring-EMS-Only
member LoK_EMS
dial-peer cor list Keyring-Local
member LoK_Local
member LoK_EMS
dial-peer cor list Keyring-National
member LoK_Local
member LoK_National
member LoK_EMS
dial-peer cor list Keyring-International
member LoK_Local
member LoK_National
member LoK_International
member LoK_EMS
dial-peer cor list Door-EMS-Only
member LoK_EMS
dial-peer cor list Door-Local
member LoK_Local
member LoK_EMS
dial-peer cor list Door-National
member LoK_Local
member LoK_National
member LoK_EMS
dial-peer cor list Door-International
member LoK_Local
member LoK_National
member LoK_EMS
dial-peer voice 100 voip
description *** Incoming Calls VoIP ***
translation-profile incoming INBOUND_CALL_CONVERT_CALLER-ID
call-block translation-profile incoming BLOCK-OUTBOUND_INT+900
call-block disconnect-cause incoming call-reject
preference 1
b2bua
session protocol sipv2
session target sip-server
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 150 voip
corlist outgoing Door-National
description *** Outbound 10 Digit Dialing Calls ***
translation-profile outgoing OUTBOUND_C-ID+10_DIGIT_DIALING
preference 1
destination-pattern [2-9].........$
translate-outgoing called 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 160 voip
description *** Outbound 11 Digit Dialing Calls ***
translation-profile outgoing CONVERT_OUTBOUND_CALLER-ID
preference 1
destination-pattern 1[2-9]..[2-9]......$
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 170 voip
corlist outgoing Door-International
description *** Outbound International Calling ***
preference 1
destination-pattern 011T
b2bua
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 200 voip
description Dial-peer to the Voicemail System
translation-profile outgoing Hunt_Group_2_to_VVM_1000
destination-pattern 2000
b2bua
session target ipv4:192.168.200.2
voice-class codec 1
no vad
dial-peer voice 411 voip
corlist outgoing Door-Local
description Call Free 411 information service
translation-profile outgoing 411_CALL_FREE_411
destination-pattern 411
translate-outgoing called 3
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 611 voip
description Call Phone Systems Express Support
translation-profile outgoing 611_CALL_PSE_SUPPORT
destination-pattern 611
b2bua
translate-outgoing called 5
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 911 voip
corlist outgoing Door-EMS-Only
description 911 emergency calls ONLY
destination-pattern 911
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 933 voip
description 911 system testing number
destination-pattern 933
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 196 voip
description Dial-peer to "AA & Voicemail Admin/Operator"
destination-pattern 199[6-9]
b2bua
voice-class codec 1
no vad
presence
presence call-list
gateway
timer receive-rtp 1200
sip-ua
credentials username 11111 password cisco realm anveo.com
authentication username 11111 password cisco realm anveo.com
mwi-server ipv4:192.168.200.2 expires 3600 port 5060 transport udp unsolicited
registrar dns:sip.phonesystem.com:5010 expires 180
sip-server dns:sip.phonesystem.com:5010
gatekeeper
shutdown
telephony-service
sdspfarm conference mute-on *** mute-off ###
sdspfarm units 5
sdspfarm transcode sessions 8
sdspfarm tag 1 XCODE
sdspfarm tag 2 CCONF
conference hardware
no auto-reg-ephone
authentication credential support cisco
xml user pvadmin password cisco 15
max-ephones 50
max-dn 50
ip source-address 192.168.200.1 port 2000
caller-id block code *67
service phone daysDisplayNotActive 1,6,7
service phone displayOnTime 07:45
service phone displayOnDuration 09:30
service phone displayIdleTimeout 00:10
service phone settingsAccess 1
service phone modeOfOperation 1
service phone displaywhebincomingcall 1
service phone webAccess 0
service phone ehookEnable 1
service phone displayOnWhenIncomingCall 1
service phone handsetWidebandEnable 1
service phone handsetWidebandUIControl 0
service phone headsetWidebandEnable 0
service phone headsetWidebandUIControl 0
system message Demo Phone System
url services http://192.168.200.2/voiceview/common/login.do
url authentication http://192.168.100.1/CCMCIP/authenticate.asp pvphone cisco
load 7916-24 B016-1-0-4
load 7906 SCCP11.9-2-1S
load 7975 SCCP75.9-2-1S
time-zone 12
voicemail 2000
mwi relay
max-conferences 4 gain -6
call-park system redirect
call-park system application
moh enable-g711 "flash0:/Audio/music-on-hold.au"
multicast moh 239.2.2.2 port 2000
web admin system name Support password cisco
web admin customer name Customer password 123456
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern ..........
after-hours block pattern 1 900 7-24
after-hours block pattern 2 1900 7-24
after-hours block pattern 3 976 7-24
after-hours block pattern 4 1976 7-24
night-service code *99
night-service day Sun 08:00 07:59
night-service day Mon 17:00 07:59
night-service day Tue 17:00 07:59
night-service day Wed 17:00 07:59
night-service day Thu 17:00 07:59
night-service day Fri 08:00 07:59
night-service day Sat 08:00 07:59
fac custom callfwd all *72
fac custom callfwd cancel *73
fac custom park *90
fac custom dnd *78
fac custom redial *69
fac custom voicemail *98
fac custom alias 0 *93 to *903000
fac custom alias 1 *94 to *904000
fac custom trnsfvm *97
fac custom dpark-retrieval *95
create cnf-files version-stamp 7960 Jul 24 2020 15:46:54
ephone-dn-template 1
corlist incoming Keyring-National
call-forward busy 2000
call-forward noan 2000 timeout 25
hold-alert 25 shared recurrence 20
mwi-type both
mwi sip
ephone-template 1
conference drop-mode creator
conference add-mode creator
conference admin
transfer max-length 10
softkeys remote-in-use CBarge Newcall
softkeys hold Resume Newcall Select Join
softkeys idle Redial Newcall Dnd Pickup Join Cfwdall ConfList Mobility RmLstC
softkeys seized Redial Endcall CWOff Cfwdall Callback Meetme
softkeys alerting Endcall Callback
softkeys connected Hold Park Trnsfer Endcall Select Join Confrn ConfList RmLstC TrnsfVM Mobility
softkeys ringing Answer Dnd
button-layout 1-2 line
button-layout 9 speed-dial
button-layout 3-8 blf-speed-dial
type 7945
ephone-dn 1 octo-line
number 18005551212 no-reg both
label Test - Main
description Main Line - Test
name TEST
ephone-dn 12
number 4001
ephone 12
device-security-mode none
description "Michael's Bench Phone"
mac-address 0024.142F.ffff
ephone-template 1
type 7942
button 1:12 2:1
banner login ^CCCCC
** W A R N I N G **
UNAUTHORIZED ACCESS TO THIS DEVICE IS PROHIBITED!
WARNING:
This system is for the use of authorized clients only. Individuals using the computer network
system without authorization, or in excess of their authorization, are subject to having all
their activity on this computer network system monitored and recorded by system personnel.
To protect the computer network system from unauthorized use and to ensure the computer
network systems is functioning properly, system administrators monitor this system. Anyone
using this computer network system expressly consents to such monitoring and is advised that
if such monitoring reveals possible conduct of criminal activity, system personnel may provide
the evidence of such activity to law enforcement officers.
Access is restricted to authorized users only.
Unauthorized access is a violation of state and federal,
civil and criminal laws.
All activities performed on this device are logged and monitored.
All rights retained -
You have entered $(hostname).$(domain) on line $(line) $(line-desc)
^C
line con 0
location Cisco CISCO2951 Test System
exec-timeout 0 0
password cisco
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 195
no exec
transport input all
stopbits 1
line vty 0 4
location Cisco CISCO3925 Shop Rack
exec-timeout 0 0
privilege level 15
password cisco
logging synchronous
terminal-type monitor
transport input telnet ssh
transport output telnet ssh
line vty 5 15
exec-timeout 0 0
privilege level 15
password cisco
logging synchronous
scheduler allocate 20000 1000
ntp master
ntp update-calendar
ntp server 0.north-america.pool.ntp.org
ntp server 1.north-america.pool.ntp.org
ntp server 103.105.51.156 minpoll 10
ntp server 2.north-america.pool.ntp.org
ntp server 3.north-america.pool.ntp.org
end
Non oth these IPs are mine in the reports below:
Log Buffer (100000 bytes):
ul 24 2020 19:17:50.171: %SEC-6-IPACCESSLOGP: list Protect denied tcp 125.124.63.19(34370) -> 123.456.12.150(7001), 1 packet
009479: Jul 24 2020 19:17:52.163: %SEC-6-IPACCESSLOGP: list Protect denied tcp 125.124.63.19(45548) -> 123.456.12.150(6379), 1 packet
009480: Jul 24 2020 19:17:54.167: %SEC-6-IPACCESSLOGP: list Protect denied tcp 125.124.63.19(34484) -> 123.456.12.150(7002), 1 packet
009481: Jul 24 2020 19:17:55.140: %SIP_SUPPSERV-6-TRANSFER: Transfer from pool(0) to 0115924444918 is not allowed
009482: Jul 24 2020 19:17:56.152: %SEC-6-IPACCESSLOGP: list Protect denied tcp 125.124.63.19(41388) -> 123.456.12.150(9200), 1 packet
009483: Jul 24 2020 19:17:57.788: %SIP_SUPPSERV-6-TRANSFER: Transfer from pool(0) to 0115927722723 is not allowed
009484: Jul 24 2020 19:18:17.830: %SEC-6-IPACCESSLOGP: list Protect denied tcp 219.74.130.202(25888) -> 123.456.12.150(23), 1 packet
009485: Jul 24 2020 19:18:34.908: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 3 packets
009486: Jul 24 2020 19:18:37.652: %SEC-6-IPACCESSLOGP: list Protect denied udp 89.248.160.150(59187) -> 123.456.12.150(40793), 1 packet
009487: Jul 24 2020 19:18:52.173: %SIP_SUPPSERV-6-TRANSFER: Transfer from pool(0) to 0115924444919 is not allowed
009488: Jul 24 2020 19:19:20.420: %SEC-6-IPACCESSLOGP: list Protect denied tcp 159.89.157.161(39261) -> 123.456.12.150(8081), 1 packet
009489: Jul 24 2020 19:19:23.613: %SEC-6-IPACCESSLOGP: list Protect denied tcp 83.40.124.203(53464) -> 123.456.12.150(445), 1 packet
009490: Jul 24 2020 19:19:35.270: %SEC-6-IPACCESSLOGP: list Protect denied tcp 161.35.41.151(47764) -> 123.456.12.150(8082), 1 packet
009491: Jul 24 2020 19:19:50.043: %SEC-6-IPACCESSLOGP: list Protect denied tcp 185.153.196.122(47568) -> 123.456.12.150(5004), 1 packet
009492: Jul 24 2020 19:20:30.124: %SEC-6-IPACCESSLOGP: list Protect denied tcp 45.2.251.126(52116) -> 123.456.12.150(50802), 1 packet
009493: Jul 24 2020 19:20:33.520: %SEC-6-IPACCESSLOGP: list Protect denied tcp 112.17.79.156(19803) -> 123.456.12.150(26541), 1 packet
009494: Jul 24 2020 19:20:34.920: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 2 packets
009495: Jul 24 2020 19:20:55.206: %SEC-6-IPACCESSLOGP: list Protect denied tcp 45.134.179.243(54936) -> 123.456.12.150(3390), 1 packet
009496: Jul 24 2020 19:21:01.603: %SEC-6-IPACCESSLOGP: list Protect denied tcp 45.129.33.5(52225) -> 123.456.12.150(4430), 1 packet
009497: Jul 24 2020 19:21:23.557: %SEC-6-IPACCESSLOGP: list Protect denied tcp 218.70.218.228(31045) -> 123.456.12.150(1433), 1 packet
009498: Jul 24 2020 19:21:34.370: %SEC-6-IPACCESSLOGP: list Protect denied tcp 46.161.27.75(45388) -> 123.456.12.150(2002), 1 packet
009499: Jul 24 2020 19:21:34.926: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 1 packet
009500: Jul 24 2020 19:21:46.988: %SEC-6-IPACCESSLOGP: list Protect denied tcp 71.6.233.173(8002) -> 123.456.12.150(8002), 1 packet
009501: Jul 24 2020 19:21:54.524: %SEC-6-IPACCESSLOGP: list Protect denied tcp 45.129.33.16(52681) -> 123.456.12.150(3505), 1 packet
009502: Jul 24 2020 19:22:34.932: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 1 packet
009503: Jul 24 2020 19:22:57.903: %SEC-6-IPACCESSLOGP: list Protect denied tcp 45.129.33.21(49541) -> 123.456.12.150(37516), 1 packet
009504: Jul 24 2020 19:23:13.729: %SEC-6-IPACCESSLOGP: list Protect denied tcp 61.134.62.226(44240) -> 123.456.12.150(8081), 1 packet
009505: Jul 24 2020 19:23:32.210: %SEC-6-IPACCESSLOGP: list Protect denied tcp 92.63.196.25(52268) -> 123.456.12.150(9523), 1 packet
009506: Jul 24 2020 19:23:34.939: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 1 packet
009507: Jul 24 2020 19:23:36.755: %SEC-6-IPACCESSLOGP: list Protect denied tcp 45.129.33.21(49541) -> 123.456.12.150(37434), 1 packet
009508: Jul 24 2020 19:24:15.203: %SEC-6-IPACCESSLOGP: list Protect denied tcp 49.247.196.128(46935) -> 123.456.12.150(9953), 1 packet
009509: Jul 24 2020 19:24:18.455: %SEC-6-IPACCESSLOGP: list Protect denied tcp 45.129.33.8(52317) -> 123.456.12.150(9405), 1 packet
009510: Jul 24 2020 19:24:48.126: %SEC-6-IPACCESSLOGP: list Protect denied tcp 185.232.30.130(44950) -> 123.456.12.150(6002), 1 packet
009511: Jul 24 2020 19:24:51.747: %SEC-6-IPACCESSLOGP: list Protect denied tcp 185.153.199.201(43005) -> 123.456.12.150(3339), 1 packet
009512: Jul 24 2020 19:25:06.780: %SEC-6-IPACCESSLOGP: list Protect denied tcp 196.52.43.94(52953) -> 123.456.12.150(9200), 1 packet
009513: Jul 24 2020 19:25:33.239: %SEC-6-IPACCESSLOGP: list Protect denied tcp 45.129.33.8(52317) -> 123.456.12.150(9583), 1 packet
009514: Jul 24 2020 19:26:18.328: %SEC-6-IPACCESSLOGP: list Protect denied tcp 188.166.145.228(46219) -> 123.456.12.150(8443), 1 packet
009515: Jul 24 2020 19:26:34.413: %SEC-6-IPACCESSLOGP: list Protect denied tcp 138.197.175.236(46809) -> 123.456.12.150(26144), 1 packet
009516: Jul 24 2020 19:26:34.957: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 1 packet
009517: Jul 24 2020 19:26:59.088: %SEC-6-IPACCESSLOGP: list Protect denied tcp 79.124.8.95(43997) -> 123.456.12.150(1043), 1 packet
009518: Jul 24 2020 19:27:14.009: %SEC-6-IPACCESSLOGP: list Protect denied tcp 193.32.161.141(45128) -> 123.456.12.150(50695), 1 packet
009519: Jul 24 2020 19:27:48.273: %SEC-6-IPACCESSLOGP: list Protect denied tcp 185.56.80.51(56314) -> 123.456.12.150(5900), 1 packet
009520: Jul 24 2020 19:28:34.970: %SEC-6-IPACCESSLOGP: list Protect denied tcp 61.134.62.226(44240) -> 123.456.12.150(8081), 1 packet
009521: Jul 24 2020 19:28:34.970: %SEC-6-IPACCESSLOGP: list Protect denied tcp 134.122.79.129(46812) -> 123.456.12.150(537), 1 packet
009522: Jul 24 2020 19:28:39.298: %SEC-6-IPACCESSLOGP: list Protect denied tcp 83.97.20.35(58930) -> 123.456.12.150(2083), 1 packet
009523: Jul 24 2020 19:28:47.999: %SEC-6-IPACCESSLOGP: list Protect denied tcp 115.124.114.242(61191) -> 123.456.12.150(1433), 1 packet
009524: Jul 24 2020 19:28:57.628: %SEC-6-IPACCESSLOGP: list Protect denied tcp 92.63.196.26(48795) -> 123.456.12.150(44696), 1 packet
009525: Jul 24 2020 19:28:59.816: %SEC-6-IPACCESSLOGP: list Protect denied tcp 91.204.199.73(51391) -> 123.456.12.150(5440), 1 packet
009526: Jul 24 2020 19:29:45.429: %SEC-6-IPACCESSLOGP: list Protect denied tcp 156.219.96.31(42910) -> 123.456.12.150(23), 1 packet
PSE_2900#sh call his voi last 15
GENERIC:
SetupTime=24069150 ms (22:23:36.749 DST Fri Jul 24 2020)
Index=44271
PeerAddress=97453
PeerSubAddress=
PeerId=100
PeerIfIndex=26
LogicalIfIndex=0
DisconnectCause=15
DisconnectText=call rejected (21)
ConnectTime=0 ms (0)
DisconnectTime=24088650 ms (22:23:56.249 DST Fri Jul 24 2020)
CallDuration=00:00:00 sec
CallOrigin=2
ReleaseSource=7
InternalErrorCode=1.1.228.3.31.0
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
VOIP:
ConnectionId[0xADBF8086 0xCD5411EA 0x9BEFD4EF 0x6517926C]
IncomingConnectionId[0xADBF8086 0xCD5411EA 0x9BEFD4EF 0x6517926C]
CallID=60056
SessionIDLocaluuid=c3d15895f13a5c6db07733425381832b
SessionIDRemoteuuid=10dba5d6f68b5a7ba051a1399e8d2e08
CallReferenceId=0
CallServiceType=Unknown
RTP Loopback Call=FALSE
RemoteIPAddress=164.132.201.36
RemoteUDPPort=25282
RemoteSignallingIPAddress=164.132.201.36
RemoteSignallingPort=58391
RemoteMediaIPAddress=0.0.0.0
RemoteMediaPort=25282
SRTP = off
TextRelay = off
Fallback Icpif=0
Fallback Loss=0
Fallback Delay=0
RoundTripDelay=0 ms
SelectedQoS=best-effort
tx_DtmfRelay=rtp-nte
FastConnect=FALSE
AnnexE=FALSE
Separate H245 Connection=FALSE
H245 Tunneling=FALSE
SessionProtocol=sipv2
ProtocolCallId=1516977663-810822823-1396583920
SessionTarget=164.132.201.36
SafEnabled=FALSE
OnTimeRvPlayout=0
GapFillWithSilence=0 ms
GapFillWithPrediction=0 ms
GapFillWithInterpolation=0 ms
GapFillWithRedundancy=0 ms
HiWaterPlayoutDelay=0 ms
LoWaterPlayoutDelay=0 ms
Transcoded : No
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = disabled
CoderTypeRate=g711ulaw
CodecBytes=160
cvVoIPCallHistoryIcpif=0
MediaSetting=flow-through
CallerName=
CallerIDBlocked=False
OriginalCallingNumber=97453
OriginalCallingOctet=0x0
OriginalCalledNumber=+46213724612
OriginalCalledOctet=0x0
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0x80
DestinationRouteStr=
TranslatedCallingNumber=97453
TranslatedCallingOctet=0x0
TranslatedCalledNumber=+46213724612
TranslatedCalledOctet=0x0
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0x80
GwReceivedCalledNumber=+46213724612
GwReceivedCalledOctet3=0x0
GwReceivedCallingNumber=97453
GwReceivedCallingOctet3=0x0
GwReceivedCallingOctet3a=0x80
MediaInactiveDetected=no
MediaInactiveTimestamp=
MediaControlReceived=
LongDurationCallDetected=no
LongDurationCallTimerStamp=
LongDurationCallDuration=
Username=97453
MlppServiceDomainNW=0 (none)
MlppServiceDomainID=
PrecedenceLevel=0 (PRECEDENCE_LEVEL_NONE)
CPA Call History Parameters
CPA Event Status: DISABLE
RTCP TransmitPackets=0
RTCP ReceivePackets=0
GENERIC:
SetupTime=24069400 ms (22:23:36.996 DST Fri Jul 24 2020)
Index=44272
PeerAddress=101
PeerSubAddress=
PeerId=100
PeerIfIndex=26
LogicalIfIndex=0
DisconnectCause=15
DisconnectTime=24088900 ms (22:23:56.500 DST Fri Jul 24 2020)
CallOrigin=2
ReleaseSource=7
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
VOIP:
ConnectionId[0xADE5F451 0xCD5411EA 0x9BF4D4EF 0x6517926C]
IncomingConnectionId[0xADE5F451 0xCD5411EA 0x9BF4D4EF 0x6517926C]
CallID=60057
SessionIDLocaluuid=dac7b8897dbb5f20a8d03c34442250d9
SessionIDRemoteuuid=c1064551dd3e52b6978b02e1fab9814e
CallReferenceId=0
RemoteIPAddress=192.227.132.22
RemoteUDPPort=25282
RemoteSignallingIPAddress=192.227.132.22
RemoteSignallingPort=59537
RemoteMediaIPAddress=192.168.1.83
SRTP = off
TextRelay = off
Fallback Icpif=0
Fallback Loss=0
Fallback Delay=0
RoundTripDelay=0 ms
FastConnect=FALSE
AnnexE=FALSE
ProtocolCallId=528685421-137126919-496768641
SessionTarget=192.227.132.22
SafEnabled=FALSE
OnTimeRvPlayout=0
Transcoded : No
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = disabled
CodecBytes=160
CallerName=
OriginalCallingNumber=101
OriginalCalledNumber=1791900441924922800
TranslatedCallingNumber=101
TranslatedCalledNumber=1791900441924922800
GwReceivedCalledNumber=1791900441924922800
GwReceivedCallingNumber=101
Username=101
GENERIC:
SetupTime=24069560 ms (22:23:37.162 DST Fri Jul 24 2020)
Index=44273
PeerAddress=610
PeerSubAddress=
PeerId=100
PeerIfIndex=26
LogicalIfIndex=0
DisconnectCause=15
DisconnectTime=24089060 ms (22:23:56.656 DST Fri Jul 24 2020)
CallOrigin=2
ReleaseSource=7
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
VOIP:
ConnectionId[0xADFE5D8A 0xCD5411EA 0x9BF9D4EF 0x6517926C]
IncomingConnectionId[0xADFE5D8A 0xCD5411EA 0x9BF9D4EF 0x6517926C]
CallID=60058
SessionIDLocaluuid=dbd0b65e670650148df14880b1bdcc16
SessionIDRemoteuuid=51818f0e2b6f56be9e6cbfd11aa6401a
CallReferenceId=0
RemoteIPAddress=23.94.150.236
RemoteUDPPort=25282
RemoteSignallingIPAddress=23.94.150.236
RemoteSignallingPort=62662
SRTP = off
TextRelay = off
Fallback Icpif=0
Fallback Loss=0
Fallback Delay=0
RoundTripDelay=0 ms
FastConnect=FALSE
AnnexE=FALSE
ProtocolCallId=1137991645-1145064195-963260262
SessionTarget=23.94.150.236
SafEnabled=FALSE
OnTimeRvPlayout=0
Transcoded : No
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = disabled
CodecBytes=160
CallerName=
OriginalCallingNumber=610
OriginalCalledNumber=9011441544395303
TranslatedCallingNumber=610
TranslatedCalledNumber=9011441544395303
GwReceivedCalledNumber=9011441544395303
GwReceivedCallingNumber=610
Username=610
GENERIC:
SetupTime=24069760 ms (22:23:37.364 DST Fri Jul 24 2020)
Index=44274
PeerAddress=1001
PeerSubAddress=
PeerId=100
PeerIfIndex=26
LogicalIfIndex=0
DisconnectCause=15
DisconnectTime=24089260 ms (22:23:56.864 DST Fri Jul 24 2020)
CallOrigin=2
ReleaseSource=7
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
VOIP:
ConnectionId[0xAE1CE389 0xCD5411EA 0x9BFED4EF 0x6517926C]
IncomingConnectionId[0xAE1CE389 0xCD5411EA 0x9BFED4EF 0x6517926C]
CallID=60059
SessionIDLocaluuid=bc6f314cd85751b88d8483c1dc152935
SessionIDRemoteuuid=fae81ab717c155f7ac77911f139aa37b
CallReferenceId=0
RemoteUDPPort=25282
RemoteSignallingPort=60567
SRTP = off
TextRelay = off
Fallback Icpif=0
Fallback Loss=0
Fallback Delay=0
RoundTripDelay=0 ms
FastConnect=FALSE
AnnexE=FALSE
ProtocolCallId=348510376-1837489508-1957990100
SafEnabled=FALSE
OnTimeRvPlayout=0
Transcoded : No
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = disabled
CodecBytes=160
CallerName=
OriginalCallingNumber=1001
OriginalCalledNumber=805746406820513
TranslatedCallingNumber=1001
TranslatedCalledNumber=805746406820513
GwReceivedCalledNumber=805746406820513
GwReceivedCallingNumber=1001
Username=1001
GENERIC:
SetupTime=24069990 ms (22:23:37.591 DST Fri Jul 24 2020)
Index=44275
PeerAddress=9200
PeerSubAddress=
PeerId=100
PeerIfIndex=26
LogicalIfIndex=0
DisconnectCause=15
DisconnectTime=24089490 ms (22:23:57.091 DST Fri Jul 24 2020)
CallOrigin=2
ReleaseSource=7
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
VOIP:
ConnectionId[0xAE3FAE65 0xCD5411EA 0x9C03D4EF 0x6517926C]
IncomingConnectionId[0xAE3FAE65 0xCD5411EA 0x9C03D4EF 0x6517926C]
CallID=60060
SessionIDLocaluuid=9795c213a605537f9982eef22fa11602
SessionIDRemoteuuid=bbfd10d3d0e653ed898edf5f942ab868
CallReferenceId=0
RemoteIPAddress=156.96.117.164
RemoteUDPPort=4000
RemoteSignallingIPAddress=156.96.117.164
RemoteSignallingPort=55798
RemoteMediaPort=4000
SRTP = off
TextRelay = off
Fallback Icpif=0
Fallback Loss=0
Fallback Delay=0
RoundTripDelay=0 ms
FastConnect=FALSE
AnnexE=FALSE
ProtocolCallId=558881015-396441449-378840698
SessionTarget=156.96.117.164
SafEnabled=FALSE
OnTimeRvPlayout=0
Transcoded : No
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = disabled
CodecBytes=160
CallerName=
OriginalCallingNumber=9200
OriginalCalledNumber=990046192777669
TranslatedCallingNumber=9200
TranslatedCalledNumber=990046192777669
GwReceivedCalledNumber=990046192777669
GwReceivedCallingNumber=9200
Username=9200
GENERIC:
SetupTime=24070590 ms (22:23:38.193 DST Fri Jul 24 2020)
Index=44276
PeerAddress=97453
PeerSubAddress=
PeerId=100
PeerIfIndex=26
LogicalIfIndex=0
DisconnectCause=15
DisconnectTime=24090180 ms (22:23:57.783 DST Fri Jul 24 2020)
CallOrigin=2
ReleaseSource=7
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
VOIP:
ConnectionId[0xAE9AA1BF 0xCD5411EA 0x9C08D4EF 0x6517926C]
IncomingConnectionId[0xAE9AA1BF 0xCD5411EA 0x9C08D4EF 0x6517926C]
CallID=60061
SessionIDLocaluuid=5f03429a0cdf5354b616df93d922d60a
SessionIDRemoteuuid=bdd42d90ac415c7f9301dabaef5f5dc6
CallReferenceId=0
RemoteUDPPort=25282
RemoteSignallingPort=63585
SRTP = off
TextRelay = off
Fallback Icpif=0
Fallback Loss=0
Fallback Delay=0
RoundTripDelay=0 ms
FastConnect=FALSE
AnnexE=FALSE
ProtocolCallId=1531120144-297174187-342380899
SafEnabled=FALSE
OnTimeRvPlayout=0
Transcoded : No
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = disabled
CodecBytes=160
CallerName=
OriginalCalledNumber=00046213724612
TranslatedCalledNumber=00046213724612
GwReceivedCalledNumber=00046213724612
Username=97453
GENERIC:
SetupTime=24071260 ms (22:23:38.860 DST Fri Jul 24 2020)
Index=44277
PeerAddress=1001
PeerSubAddress=
PeerId=100
PeerIfIndex=26
LogicalIfIndex=0
DisconnectCause=15
DisconnectTime=24090760 ms (22:23:58.362 DST Fri Jul 24 2020)
CallOrigin=2
ReleaseSource=7
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
VOIP:
ConnectionId[0xAF01CC9F 0xCD5411EA 0x9C14D4EF 0x6517926C]
IncomingConnectionId[0xAF01CC9F 0xCD5411EA 0x9C14D4EF 0x6517926C]
CallID=60064
SessionIDLocaluuid=086ded1cfe3a5581b7d28f5eaf2a5486
SessionIDRemoteuuid=78ef5debdb5f5d89a3938f7e466dd748
CallReferenceId=0
RemoteUDPPort=25282
RemoteSignallingPort=49429
SRTP = off
TextRelay = off
Fallback Icpif=0
Fallback Loss=0
Fallback Delay=0
RoundTripDelay=0 ms
FastConnect=FALSE
AnnexE=FALSE
ProtocolCallId=1639082933-35271137-1180207095
SafEnabled=FALSE
OnTimeRvPlayout=0
Transcoded : No
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = disabled
CodecBytes=160
CallerName=
OriginalCalledNumber=805846406820513
TranslatedCalledNumber=805846406820513
GwReceivedCalledNumber=805846406820513
Username=1001
GENERIC:
SetupTime=24072040 ms (22:23:39.645 DST Fri Jul 24 2020)
Index=44278
PeerAddress=97453
PeerSubAddress=
PeerId=100
PeerIfIndex=26
LogicalIfIndex=0
DisconnectCause=15
DisconnectTime=24091540 ms (22:23:59.145 DST Fri Jul 24 2020)
CallOrigin=2
ReleaseSource=7
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
VOIP:
ConnectionId[0xAF78D38E 0xCD5411EA 0x9C19D4EF 0x6517926C]
IncomingConnectionId[0xAF78D38E 0xCD5411EA 0x9C19D4EF 0x6517926C]
CallID=60065
SessionIDLocaluuid=28b111678d07599e89902a80a3d71e99
SessionIDRemoteuuid=c28f57e6cceb5d938a8155062f01f81b
CallReferenceId=0
RemoteUDPPort=25282
RemoteSignallingPort=52295
SRTP = off
TextRelay = off
Fallback Icpif=0
Fallback Loss=0
Fallback Delay=0
RoundTripDelay=0 ms
FastConnect=FALSE
AnnexE=FALSE
ProtocolCallId=1282175394-535042804-58211314
SafEnabled=FALSE
OnTimeRvPlayout=0
Transcoded : No
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = disabled
CodecBytes=160
CallerName=
OriginalCalledNumber=46213724612
TranslatedCalledNumber=46213724612
GwReceivedCalledNumber=46213724612
Username=97453
GENERIC:
SetupTime=24072690 ms (22:23:40.289 DST Fri Jul 24 2020)
Index=44279
PeerAddress=1001
PeerSubAddress=
PeerId=100
PeerIfIndex=26
LogicalIfIndex=0
DisconnectCause=15
DisconnectTime=24092190 ms (22:23:59.789 DST Fri Jul 24 2020)
CallOrigin=2
ReleaseSource=7
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
VOIP:
ConnectionId[0xAFDB18C7 0xCD5411EA 0x9C1ED4EF 0x6517926C]
IncomingConnectionId[0xAFDB18C7 0xCD5411EA 0x9C1ED4EF 0x6517926C]
CallID=60066
SessionIDLocaluuid=0300eb1c412451f295ab50cfc06ad016
SessionIDRemoteuuid=acad2b4873cb5a078f8ea3d75f43ab9b
CallReferenceId=0
RemoteUDPPort=25282
RemoteSignallingPort=54616
SRTP = off
TextRelay = off
Fallback Icpif=0
Fallback Loss=0
Fallback Delay=0
RoundTripDelay=0 ms
FastConnect=FALSE
AnnexE=FALSE
ProtocolCallId=609475824-1651170291-418084707
SafEnabled=FALSE
OnTimeRvPlayout=0
Transcoded : No
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = disabled
CodecBytes=160
CallerName=
OriginalCalledNumber=805946406820513
TranslatedCalledNumber=805946406820513
GwReceivedCalledNumber=805946406820513
Username=1001
GENERIC:
SetupTime=24073480 ms (22:23:41.081 DST Fri Jul 24 2020)
Index=44280
PeerAddress=97453
PeerSubAddress=
PeerId=100
PeerIfIndex=26
LogicalIfIndex=0
DisconnectCause=15
DisconnectTime=24092980 ms (22:24:00.585 DST Fri Jul 24 2020)
CallOrigin=2
ReleaseSource=7
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
VOIP:
ConnectionId[0xB0549351 0xCD5411EA 0x9C24D4EF 0x6517926C]
IncomingConnectionId[0xB0549351 0xCD5411EA 0x9C24D4EF 0x6517926C]
CallID=60068
SessionIDLocaluuid=9e14c9b3a13f50e5965be7f8a687d57e
SessionIDRemoteuuid=f66dbdc6288e515aaaa492b0ade6e521
CallReferenceId=0
RemoteUDPPort=25282
RemoteSignallingPort=57440
SRTP = off
TextRelay = off
Fallback Icpif=0
Fallback Loss=0
Fallback Delay=0
RoundTripDelay=0 ms
FastConnect=FALSE
AnnexE=FALSE
ProtocolCallId=2078445708-1219067132-305882431
SafEnabled=FALSE
OnTimeRvPlayout=0
Transcoded : No
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = disabled
CodecBytes=160
CallerName=
OriginalCalledNumber=90046213724612
TranslatedCalledNumber=90046213724612
GwReceivedCalledNumber=90046213724612
Username=97453
Vinod.s
Level 3
Level 3
Hi ,
This is very serious issue , please raise tac to find RCA for this...
Have you enabled voice mail also in your CME setup ?
No voicemail configured yet.  I do not have a Cisco support contract to TAC is not an option for me.
