issue with fax machine in H323 gateway.
ciscoroyzhang
                   Hi there,   recently we have deployed voice system in our Korea office, user experience problem to receiving fax in some fax machine.
on H323 gateway, there are 4 fxs ports connected to 2 faxe machines. fax01 is working fine but fax02 can't send/receive fax. From deb ISDN q931, I can see both inboun call arrived to the gateway successfully, but when call forward to the fxs port, one fax receiving the call, another not.
I have compared the "deb isdn q931" resoult,  only diffference is that inbound fax to fax01 Bearer Cap is set to 9090A3 (3.1kHzAudio), while the inbound fax to fax02 Bearer Cap is set to 8090A3 (sech). under the voice port 0/0/0:15, bear-cap is set to speech.   my believe is this might cause the issue.
I tried to change bear-cap to 3.1audio and default bear-cap in voice port 0/0/0:15,  as well as FXS ports, not change. (correct me if I am wrong, but my understanding is these configuration mailnly affects the outbond call, rather than inbound call)
Now my question is why the inbound fax to FAX01 is with bearer-cap SPEECH,  while to FAX02 is 3.1kHzAudio. is this controlled by TEL or I can manipulate via some command in gateway.
Router: cisco 2901
fxs card: VIC3-4FXS/DID
CUCM: 8.6, but no relevent here.
DEB to FAX01 - working one:
Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98387
dial-peer voice 100002 pots
description Sales Department FAX 7825759
huntstop
destination-pattern 7825759
clid network-number 7825759
port 0/1/2
                Standard = CCITT
DEB to FAX02 - not working one:
Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
        Channel ID i = 0xA98386
                Exclusive, Channel 6 Bearer Capability i = 0x8090A3
                Standard = CCITT
Sample configuration for dial-peer to fxs port:
dial-peer voice 6715001 pots
description Sales Department FAX 6715001
huntstop
destination-pattern 6715001
clid network-number 6715001
port 0/1/2
Above same configuration used in Australia and other countries, no such issue so far.
many thanks Roy
17 Replies 17
paolo bevilacqua
That is likely not the cause, beside you cannot control what telco sends to you.
Check that you have network-clock-select to the PRI interface.
Also you should include the complete call flow and complete traces.
Jagpreet Singh
Hi Roy,
     I agree with Paolo. This likely not the cause of the fax failure. As suggested, please include the entire cal flow in detail and I'll let you know which debugs and logs to collect to troubleshoot this further.
Jagpreet
Hi guys, thanks for the reply.
Polao, I can confirm network clock select has setup as following:
    network-clock-select 1 E1 0/0/0
     network-clock-select 2 E1 0/0/1
also check the controller: no any issue has been found.
Hi Japgpreet,   the call flow is  PSTN------------> E1-------> FXS-------------->Fax
I agree that I might be in wrong direction to investigate the cause.  I did a bit reach and found out this setup is called hairpin. since no fax call goes over IP nework, so the fax protocol should be disabled.
https://supportforums.cisco.com/thread/2035567
At moment the setting is as following
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  h225 signal overlap
modem passthrough nse codec g711ulaw
I tried to remove the modem passthrough nse... but when try to issue fax protocol none, get warning message T38  is default....also disable fax protocol in the FXS port. tested but same problem persists.
the insteresting thing here is that fax01 conncted to port 0/1/2 is working, fax02 connect to the port 0/1/3 is not. and configuration is all same. same configuration has been used in other site no issue.
would appreciate if you can let me know where the problem might be?  cheers Roy
Hi Roy,
     Try running the following debugs for a non-working call:
> deb isdn q931
> debug h225 asn1
> deb h245 asn1
> deb voice ccapi inout
> deb vpm signal
It'll be great if you can test when no other call is on, but if thats not possible, no worries. Please also mention the calling and the called numbers.
Jagpreet
Hi Jagpreet,  I have done all the debugs and upload them to my initial question. would much appreciate if you can have a look when you have time and let me know what is your finding.  Cheers Roy
kenjoh725
The first thing I check with fax issues is T1/E1 controller errors.
Are you getting any controller errors?
kenjoh725
You say 'one fax receiving call, the other not'
Is the call connecting to the port? It doesn't sound like fax problem if the call is not connecting.
hi Ken,   there is VIC3-4FXS/DID card on this 2901 router, and inbound fax call are sending to the port, result from deb voice ccapi inout indecates taht it tried to send to that port. user also can hear the ring tone from the fax then it suddenly stop.
  Guid=921E2A20-DD20-11E2-82BB-00077DDC4CC0, Outgoing Dial-peer=100003 --------------------> match dialk-peer
014956: Jun 26 2013 07:51:13.471 KST: //2836/921E2A2082BB/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=7825789
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=7825789
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
014957: Jun 26 2013 07:51:13.471 KST: //2836/921E2A2082BB/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x29DAF678, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=7825789,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=7825789(TON=National, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=100003, Call Count On=FALSE,  ----------------------------->  match dial-peer
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
014958: Jun 26 2013 07:51:13.471 KST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
014959: Jun 26 2013 07:51:13.471 KST: :cc_get_feature_vsa malloc success
014960: Jun 26 2013 07:51:13.471 KST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
014961: Jun 26 2013 07:51:13.471 KST:  cc_get_feature_vsa count is
koseo02-vgw01#
koseo02-vgw01#2
014962: Jun 26 2013 07:51:13.471 KST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
014963: Jun 26 2013 07:51:13.471 KST: :FEATURE_VSA attributes are: feature_name:0,feature_time:808066928,feature_id:2837
014964: Jun 26 2013 07:51:13.471 KST: //2837/921E2A2082BB/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
014965: Jun 26 2013 07:51:13.471 KST: //2837/921E2A2082BB/CCAPI/ccCallSetContext:
   Context=0x30029E5C
014966: Jun 26 2013 07:51:13.471 KST: //2836/921E2A2082BB/CCAPI/ccSaveDialpeerTag:
014967: Jun 26 2013 07:51:13.475 KST: //2837/921E2A2082BB/CCAPI/cc_api_call_proceeding:
   Interface=0x29DAF678, Progress Indication=NULL(0)
014968: Jun 26 2013 07:51:13.475 KST: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x83FC
        Channel ID i = 0xA98394
                Exclusive, Channel 20
014969: Jun 26 2013 07:51:13.475 KST: //2837/921E2A2082BB/CCAPI/cc_api_call_cut_progress:
   Interface=0x29DAF678, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
   Cause Value=0
014970: Jun 26 2013 07:51:13.475 KST: //2837/921E2A2082BB/CCAPI/cc_api_call_cut_progress:
   Call Entry(Responsed=TRUE)
014971: Jun 26 2013 07:51:13.475 KST: //2836/921E2A2082BB/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
014972: Jun 26 2013 07:51:13.475 KST: //2836/921E2A2082BB/CCAPI/ccCallCutProgress:
014973: Jun 26 2013 07:51:13.475 KST: //2836/921E2A2082BB/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=2836
014974: Jun 26 2013 07:51:13.475 KST: //2836/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x2AE2D9B8, callID1=0xB14, callID2=0xB15, tag=0x0)
014975: Jun 26 2013 07:51:13.475 KST: //2836/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x2AE2D9B8, callID1=0xB14, gcid=921E2A20-DD2011E2-82BB0007-7DDC4CC0, tag=0x0)
014976: Jun 26 2013 07:51:13.475 KST: //2837/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x2AE2D9B8, callID2=0xB15, gcid=921E2A20-DD2011E2-82BB0007-7DDC4CC0, tag=0x0)
014977: Jun 26 2013 07:51:13.475 KST: //2836/921E2A2082BB/CCAPI/ccConferenceCreate:
   Conference Id=0x2AE2D9B8, Call Id1=2836, Call Id2=2837, Tag=0x0
014978: Jun 26 2013 07:51:13.475 KST: //2836/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x501, Source Interface=0x2A227DC0, Source Call Id=2836,
   Destination Call Id=2837, Disposition=0x0, Tag=0xFFFFFFFF
014979: Jun 26 2013 07:51:13.475 KST: //2837/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x501, Source Interface=0x29DAF678, Source Call Id=2837,
   Destination Call Id=2836, Disposition=0x0, Tag=0xFFFFFFFF
014980: Jun 26 2013 07:51:13.475 KST: //2836/921E2A2082BB/CCAPI/cc_generic_bridge_done:
014981: Jun 26 2013 07:51:13.475 KST: //2836/921E2A2082BB/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x501, Destination Call Id=2837)
014982: Jun 26 2013 07:51:13.475 KST: //2837/921E2A2082BB/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x501, Destination Call Id=2836)
014983: Jun 26 2013 07:51:13.475 KST: //2836/921E2A2082BB/CCAPI/cc_api_caps_ind:
   Destination Interface=0x29DAF678, Destination Call Id=2837, Source Call Id=2836,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x2,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
014984: Jun 26 2013 07:51:13.475 KST: //2836/921E2A2082BB/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
014985: Jun 26 2013 07:51:13.475 KST: //2837/921E2A2082BB/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2A227DC0, Destination Call Id=2836, Source Call Id=2837,
014986: Jun 26 2013 07:51:13.475 KST: //2837/921E2A2082BB/CCAPI/cc_api_caps_ind:
014987: Jun 26 2013 07:51:13.475 KST: //2837/921E2A2082BB/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Vad=ON(0x2),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=7678)
014988: Jun 26 2013 07:51:13.475 KST: //2836/921E2A2082BB/CCAPI/cc_api_caps_ack:
koseo02-vgw01#Bytes=160, Signal Type=2, Seq Num Start=7038)
014989: Jun 26 2013 07:51:13.479 KST: //2837/921E2A2082BB/CCAPI/cc_api_voice_mode_event:
   Call Id=2837
014990: Jun 26 2013 07:51:13.479 KST: //2837/921E2A2082BB/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x30029E5C)
014991: Jun 26 2013 07:51:13.479 KST: //2836/921E2A2082BB/CCAPI/cc_api_voice_mode_event:
   Call Id=2836
014992: Jun 26 2013 07:51:13.479 KST: //2836/921E2A2082BB/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x3001CD04)
014993: Jun 26 2013 07:51:13.479 KST: //2836/921E2A2082BB/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x501, Call Id1=2836, Call Id2=2837
014994: Jun 26 2013 07:51:13.479 KST: ISDN Se0/0/0:15 Q931: TX -> PROGRESS pd = 8  callref = 0x83FC
        Progress Ind i = 0x8188 - In-band info or appropriate now available
koseo02-vgw01#
koseo02-vgw01#
014995: Jun 26 2013 07:51:23.491 KST: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x03FC    ----------------------------- disconnect
        Cause i = 0x82E6 - Recovery on timer expiry
Ok, this is not really useful, please capture the following debugs simultaneously:
deb isdn q931
deb vpm signal
Use the following commands to capture everything on the buffer:
Recommended Configuration:
Router(config)# service sequence-numbers
Router(config)# service timestamps debug datetime localtime msec
Router(config)# logging buffered 10000000 debug
Router(config)# no logging console
Router(config)# no logging monitor
Router(config)# default logging rate-limit
Router(config)# default logging queue-limit
Router(config)# voice iec syslog
https://supportforums.cisco.com/docs/DOC-16310
After doing the call, issue "show logg" and post the output.
In addition, can you share the full config of the Gateway?
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Hi Jorge, thanks for reply. a copy of various debug have been uploaded as attachment in my original post. go to the top of this page you will see it.
I requested a new set of debugs in a specific manner, since I already checked previous logs, and I can't see much about the call. Aditional logs are required.
Please also share the configuration.
Jorge Armijo
Hi Jorge,   please see the voice related configuration as folllowing,will upload the deb later tonight.
!network-clock-participate wic 0
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
voice call disc-pi-off
voice rtp send-recv
voice service pots
fax rate disable
voice service voip
fax protocol pass-through g711ulaw
h323
  h225 signal overlap
voice class codec 1
codec preference 1 g711ulaw
interface Serial0/0/0:15
isdn incoming-voice voice
isdn send-alerting
isdn bchan-number-order ascending
isdn sending-complete
isdn outgoing display-ie
voice-port 0/0/0:15
translation-profile incoming ISDNin
translation-profile outgoing ISDNout
cptone KR
bearer-cap Speech
dial-peer voice 100007 pots
description Technical Department FAX 7825777
destination-pattern 7825777
fax rate disable
clid network-number 7825777
port 0/1/3
Since the call is connecting, and looks like you use T.38, I would recommend debug fax relay t30 all-level-1 to see whether it's the fax detection or the fax training phase that is failing.
From Cisco.com
Working Examples Of T.30 Codes
http://www.cisco.com/en/US/tech/tk652/tk777/technologies_tech_note09186a008014c1cf.shtml
Hi Ken, thanks for the suggestion, I have just try now and no fax call has been detected.  following is the configuration related to the fax protocole, fax rate disable has been added recently for testing purpose and also try to remove the fax protocol pass-through g711ulaw, but get error: Warning: T38 is the default fax protocol, it can not be removed message.  and the  fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none has been added automatcally by system.
is any other way to remove the default fax protocol in the 2901 router?  cheers Roy
voice service pots
fax rate disable
voice service voip
h323
  h225 signal overlap
