I do not get Cisco option in MTR device
pmlync007
I do not get Cisco option in MTR device, when i click on the Join the meeting from Cisco CVI link.
I get this screen attached, i can see Teams & Zoom option but Cisco option is not available.
This is related to Cisco CVI trying to join external Cisco CVI meetings.
6 Replies 6
You did not attach the picture.
Response Signature
pmlync007
I do have similar issue .. could you check the screen shot attached ...
When attaching a picture to your post it is advisable to use this function as that would show your picture directly in the post instead of as an attached file.
There are organizations that have policies that forbid employees to open files on certain file sharing sites. Me for example cannot open an attached file in the community directly as it is stored on Box, but I can download the file and then open it. As this is quite cumbersome it is much better if you where to use the appropriate function for adding pictures to a post.
Response Signature
pmlync007
@Roger Kallberg - I have attached the screen shot
pmlync007
I have no idea on this as I've never worked with MTR devices. From what I've heard from Cisco it should however support Webex same as a device running RoomOS in native mode. Do you not have the specific Webex join button visible on the touch panel?
Response Signature
