I have a customer with CUCM 7.1.3 I am trying to find an example "Department Billing Summary" report that can be generated by CDR Analysis and Reporting Tool. Can anyone tell me where I can find this example report?
glenox
Adam Thompson
Level 4
Level 4
Take a look at this document:
https://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_1_2/car/caruserr.html#wp1004948
This should give you an idea what the report will look like. It also describes the information that it contains.
Adam
Please rate if helpful
Jaime Valencia
Configuring Department Bills Reports
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_1_2/car/caruserb.html#wp1026998
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
glenox
Thanks to the two of you who replied. The documents you suggested were exactly what I needed. Thanks again.
