I need to change the port ALT in my ring topology using rep
Alexandre11
I need to change my ring topology using rep.
Problem with dhcp in client's ring structure
client has a ring topology
client has a ring topology, when we disconnect one side of the ring the dhcp does not work on some machines.
follows the attached image.
by default it locks a port Gi1/0/2 using rep, it is possible for us to define which port we want to block automatically, eg I want to lock gate gi1 / 0/2 of the LDA-COI-SWC126 switch
How do I do that ?
Hi Alexandre,
You posted your query in a wrong section.
In Switchting section you’l surely find the right answer.
Carlo
Please rate all helpful posts "The more you help the more you learn"
