IAD2431 to CUCM 6.1 using MGCP Issue
jordan.bean
I'm trying to configure an IAD2431 to register to CUCM 6.1 using MGCP.  I have entered all of the MGCP commands and enabled 'mgcpapp' on the voice ports.  I configured the gateway in CUCM as well, but it's not registering.  I confirmed that the hostname and domain name on the IAD match CUCM.  When I configure the IAD2431 in CUCM, I choose 8FXS as the option.  I notice that the ports in CUCM are labeled 1/1-1/8.  However, the FXS ports on the IAD2431 are 2/0-2/7.  I see that an IAD2435 is also labeled as ports 2/0-2/7.  Is this the issue and is this device compatible with CUCM 6.1?  I wasn't able to find a hardware support matrix for 6.1.  Thanks.
Karthik Sivaram
Level 4
Level 4
The analog options listed for the IAD2400 gateway configuration list on CUCM match the IAD2420 not the IAD2430.
IAD2430 is not supported using mgcp on any version of CUCM .
Hope this helps!
Karthik
