ILS/GDPR
Leonardo Santana
I running a CUCM Lab with CUCM version System version: 11.5.1.14900-11, i cannot dial the +E.164 Alternalte Number, at the learned numbers i see the DNs of the other cluster but i unable to dial them.
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
17 Replies 17
I made all the configurations mentioned in this doc.
CSS configured at the IP Phone and on SIP TRUNK.
Learned Numbers:
The result of the DNA made on CUCM Spoke Cluster
  • Results Summary
    • Calling Party Information
    • Dialed Digits = 7498
    • Match Result = BlockThisPattern
    • Route Block Cause = Unallocated Number
    • Called Party Number = 7498
    • Time Zone = Etc/GMT
    • Outside Dial Tone = NO
  • Call Flow
    • Note: Information Not Available
  • Alternate Matches
Leonardo Santana
Leonardo Santana
Also check that the appropriate CSSes contains the partitions for the learned patterns as indicated in "Partitions for Learned Numbers and Patterns".
I already check this, the partitions and css are assigned to the calling device.
Leonardo Santana
