ILS/GDPR
Leonardo Santana
I running a CUCM Lab with CUCM version System version: 11.5.1.14900-11, i cannot dial the +E.164 Alternalte Number, at the learned numbers i see the DNs of the other cluster but i unable to dial them.
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
That doesn't match your route string from your other screenshot
17 Replies 17
What happens when you look at RTMT traces
I see the learned numbers, but when i dial i hear i busy tone.
I have 2 CUCM has Spoke Clusters and one as the HUB
There is something else to configure?
Leonardo Santana
Do you have the route patterns in place to call those numbers?
java
if this helps, please rate
Jaime,
Do i need to have route patterns to the alternate numbers?
The Spoke Cluster learned from the SME
Leonardo Santana
Leonardo Santana
The server learned this numbers
Why is necessary to create route pattern to them if we learnerd with ILS/GDPR?
Leonardo Santana
You need a SIP Route Pattern for the learned/advertised Route String.  Did you do that?
"To be able to reach destinations learned through GDPR, the calling device's calling search space has to include the partition that the GDPR learned pattern is residing in and also the partition that the SIP route pattern resides in, which matches the SIP route string associated with the GDPR learned destination."
Source: CUCM SRND
Yes, the css has the partition of the learned numbers.
I created a SIP Route Pattern to the URI dial.
Do i need to create route pattern to the learned numbers?
Leonardo Santana
You need to create a SIP Route Pattern matching your advertised Route String. You shared your Route String in the screen shot. Do you have that created as a SIP Route Pattern, pointing at your SIP Trunk to that cluster?
Leonardo Santana
Sorry wich one?
Leonardo Santana
The problem was that the Advertised Route String of the HUB CLUSTER and the SIP Route Pattern of the SPOKE CLUSTER were different and vice versa.
Now its working fine, dialing the advertised numbers and URI.
Thanks...
Leonardo Santana
I´ll check this doc
Leonardo Santana
