01-09-2020 08:31 AM
What does * do when it is part of a directory number, we have some with 2*XXX and some with *XXXXX
Solved! Go to Solution.
01-09-2020 09:21 AM
I personally haven't seen many numbers with * that do not use * as the first digit, but I've seen a few here and there.
But *something are commonly used as service numbers internally, or sometimes as short dials for commonly used numbers in a company.
If you're asking about your specific case and what they do in your system, you need to look at your config to find that out.
01-09-2020 09:21 AM
