* in DN
meagherg1
What does * do when it is part of a directory number, we have some with 2*XXX and some with *XXXXX
Jaime Valencia
I personally haven't seen many numbers with * that do not use * as the first digit, but I've seen a few here and there.
But *something are commonly used as service numbers internally, or sometimes as short dials for commonly used numbers in a company.
If you're asking about your specific case and what they do in your system, you need to look at your config to find that out.
java
if this helps, please rate
Jaime Valencia
java
