in need some details for the equipment
omar Alqadi
hi,
kindly, i hope to help me to find information  of the  below equipments:
UCUCS-EZ-C220M3S
UCL-UCM-LIC-K9
CUWL-STD-K9
thanks
ronpatel
Level 8
Level 8
Hi Omar,
If you do not get answer here, you can open case with Cisco at cisco.com/go/ph and PH team will be able to help you on this.
regards
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Jonathan Schulenberg
The top one is a TRC-compliant build ot a UCS C220 M3.
The later two are software licenses. UCL-UCM-LIC-K9 is an Enhanced User Connect License for CUCM while CUWL-STD-K9 is a Standard User Workspace License. The ordering guides (partners only) contain additional detail on these SKUs.
Please remember to rate helpful responses and identify helpful or correct answers.
