ā01-31-2013 01:56 AM - edited ā03-16-2019 03:27 PM
hi,
kindly, i hope to help me to find information of the below equipments:
UCUCS-EZ-C220M3S
UCL-UCM-LIC-K9
CUWL-STD-K9
thanks
ā01-31-2013 01:59 AM
Hi Omar,
If you do not get answer here, you can open case with Cisco at cisco.com/go/ph and PH team will be able to help you on this.
regards
Ronak Patel
Rate helpful posts.
ā01-31-2013 05:13 AM
The top one is a TRC-compliant build ot a UCS C220 M3.
The later two are software licenses. UCL-UCM-LIC-K9 is an Enhanced User Connect License for CUCM while CUWL-STD-K9 is a Standard User Workspace License. The ordering guides (partners only) contain additional detail on these SKUs.
Please remember to rate helpful responses and identify helpful or correct answers.
