Inbound and outbound faxes problem ISDN
hugomdbaez
We had an issue with the plot E1 R2 with the service provider, which led us to stop running the plot in ISDN.
The issue is that now I have problems sending and receiving faxes.
Solution data :
CUCM System version: 7.1.5.30000-1
ISR G2 3925 Router with IOS C3900-universalk9-mz.SPA.152-1.T1.bin
Plot E1 ISDN
VG224 VG224 IOS-i6k9s-mz.124-24.T.bi
hugomdbaez
show vers
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.2(1)T1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Mon 19-Sep-11 20:16 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M13, RELEASE SOFTWARE (fc1)
pcolon-router uptime is 3 days, 1 hour, 55 minutes
System restarted at 12:32:13 BUE Fri Aug 24 2012
System image file is "flash0:c3900-universalk9-mz.SPA.152-1.T1.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3925-CHASSIS (revision 1.0) with C3900-SPE100/K9 with 993280K/55296K bytes of memory.
Processor board ID FTX1608AHT3
1 FastEthernet interface
3 Gigabit Ethernet interfaces
31 Serial interfaces
1 terminal line
1 Channelized E1/PRI port
1 Virtual Private Network (VPN) Module
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        C3900-SPE100/K9       FOC16024G3Q
Technology Package License Information for Module:'c3900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            uck9          Permanent      uck9
data          None          None           None
show run
Building configuration...
card type e1 0 1
logging buffered 51200 warnings
aaa new-model
aaa authentication login default local enable
aaa authentication login userlist local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization network grouplist local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
clock timezone BUE -3 0
network-clock-participate wic 1
crypto pki trustpoint TP-self-signed-1266120183
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1266120183
 revocation-check none
 rsakeypair TP-self-signed-1266120183
crypto pki certificate chain TP-self-signed-1266120183
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31323636 31323031 3833301E 170D3132 30323231 31373037
  35355A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 32363631
  32303138 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100E653 70320C02 560AE8EE D2513619 2043FEC7 F270158A 427FE320 B0DB95D6
  38C770CE 5D1A7D7D 8DB342E9 CF73A113 3E56654F 1DD1F793 B109B177 B2BB5DDB
  9ABF7250 0B80B664 9BAF852B C04670D9 5B3E342C DB748D1E 98651BDF 66308D08
  105D01F9 C64525B9 B5D97960 D1790C28 ABB5BA98 1FF4DD94 FD4B0D25 DD8E6E27
  B8990203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14DB69BE 4FCA48C5 55CE52E3 E615E2A8 32CF5B74 53301D06
  03551D0E 04160414 DB69BE4F CA48C555 CE52E3E6 15E2A832 CF5B7453 300D0609
  2A864886 F70D0101 05050003 8181007D C22FEE55 6C79ED13 12BDA90C B3B23F38
  83717D15 FBE0573A D76E7200 CA21B874 B0CD39F8 F9CFC12D B73BFF66 1DFB1621
  D396259D 5EAFBD61 77B70C12 EBCB90E1 76F53289 4D291B05 48F01C5C 2EE68F58
  21230BA5 531BB1E3 F306C9A2 4D1F7CBA FEFEA8CB D2382A6C 4AC71B00 956A7A79
  781338D2 64537E8A E5803638 179697
        quit
no ipv6 cef
ip dhcp excluded-address 10.170.100.1 10.170.100.50
ip dhcp excluded-address 10.170.100.210 10.170.100.254
ip dhcp pool Phone
 network 10.170.100.0 255.255.255.0
 default-router 10.170.100.254
 dns-server 10.170.50.1 10.170.50.2
 option 150 ip 10.170.100.10 10.14.100.10
no ip domain lookup
ip domain name XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
ip inspect name SALIENTE ftp
ip inspect name SALIENTE http
ip inspect name SALIENTE https
ip inspect name SALIENTE h323
ip inspect name SALIENTE sip
ip inspect name SALIENTE sip-tls
ip inspect name SALIENTE skinny
ip inspect name SALIENTE pptp
ip inspect name SALIENTE l2tp
ip inspect name SALIENTE ipsec-msft
ip inspect name SALIENTE dns
ip inspect name SALIENTE udp
ip inspect name SALIENTE tcp
ip inspect name ENTRANTE h323
ip inspect name ENTRANTE sip
ip inspect name ENTRANTE sip-tls
ip inspect name ENTRANTE skinny
ip inspect name ENTRANTE http
ip inspect name ENTRANTE https
ip inspect name ENTRANTE pptp
ip inspect name ENTRANTE l2tp
ip inspect name ENTRANTE ipsec-msft
ip inspect name ENTRANTE dns
ip inspect name ENTRANTE tcp
ip inspect name ENTRANTE udp
ip cef
isdn switch-type primary-net5
voice-card 0
 dspfarm
 dsp services dspfarm
voice rtp send-recv
voice service voip
 ip address trusted list
  ipv4 154.1.41.81
  ipv4 154.1.41.82
  ipv4 10.170.100.10
  ipv4 10.14.100.10
  ipv4 154.0.185.4
 mode border-element
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  bind control source-interface Loopback1
  bind media source-interface Loopback1
  asserted-id pai
  privacy pstn
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 3 g729r8
 codec preference 4 g729br8
voice class codec 10
voice class codec 20
voice class h323 1
  h225 timeout tcp establish 3
  call preserve
voice class sip-profiles 100
 request INVITE sip-header From modify "(.*@).*(>.*)" "\1sprint\2"
 request REINVITE sip-header From modify "(.*@).*(>.*)" "\1sprint\2"
 request INVITE sip-header P-Asserted-Identity modify "(.*@).*(>.*)" "\1sprint\2"
 request REINVITE sip-header P-Asserted-Identity modify "(.*@).*(>.*)" "\1sprint\2"
 request INVITE sip-header Diversion modify "(.*@).*(>.*)" "\1sprint\2"
 request REINVITE sip-header Diversion modify "(.*@).*(>.*)" "\1sprint\2"
voice translation-rule 1
 rule 1 /1152994400/ /7150/
 rule 2 /11529944../ /44/
voice translation-rule 2
 rule 1 /^9/ /\1/
voice translation-rule 3
 rule 1 /^.*/ /1152994400/
voice translation-profile CUE_Voicemail/AutoAttendant
 translate called 1
voice translation-profile PSTN_Outgoing
 translate calling 3
 translate called 2
license udi pid C3900-SPE100/K9 sn FOC16024G3Q
license accept end user agreement
hw-module pvdm 0/0
username adminrtr privilege 15 password 7
redundancy
controller E1 0/1/0
 pri-group timeslots 1-31
 description E1 - Telmex
class-map match-all senalizacion
 match access-group 153
class-map match-all senalizacion-dscp
 match ip dscp cs3
class-map match-all video-dscp
 match ip dscp af41
class-map match-all voice-dscp
 match ip dscp ef
 match access-group 152
 match access-group 151
policy-map QOS-MAN
 class voice-dscp
  priority percent 15
 class video-dscp
  priority percent 50
 class senalizacion-dscp
  bandwidth percent 10
 class class-default
  fair-queue
  random-detect dscp-based
policy-map RECORTE
 class class-default
  shape average 1024000
policy-map marcado-dscp
 class voice
  set ip dscp ef
 class video
  set ip dscp af41
 class senalizacion
  set ip dscp cs3
crypto ctcp port 10000
crypto isakmp policy 3
 hash md5
 authentication pre-share
 group 2
crypto isakmp policy 5
 group 2
crypto isakmp policy 99
crypto isakmp identity hostname
crypto isakmp nat keepalive 20
crypto isakmp client configuration group XXXXXXXXXXXXXXXX
 key XXXXXXXXXXXXXXXXXXXXXXXXX
 dns 10.170.50.1 10.170.50.2
 domain XXXXXXXXXXXXXXXXXXXXXXXXXX
 pool SDM_POOL_1
 acl 100
 max-users 6
 netmask 255.255.255.0
crypto isakmp profile ciscocp-ike-profile-1
   match identity group VPN-DTyC
   client authentication list ciscocp_vpn_xauth_ml_1
   isakmp authorization list ciscocp_vpn_group_ml_1
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile CiscoCP_Profile1
 set security-association idle-time 1800
 set transform-set ESP-3DES-SHA
 set isakmp-profile ciscocp-ike-profile-1
interface Loopback0
 ip address 10.170.253.253 255.255.255.255
interface Loopback1
 ip address 10.170.254.254 255.255.255.255
interface Tunnel10
 description Tunel Paseo Colon - Diagonal por CLARO MPF
 ip address 10.25.1.2 255.255.255.252
 ip virtual-reassembly in
 ip ospf mtu-ignore
 tunnel source 10.25.0.114
 tunnel destination 10.25.0.1
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
 no ip address
 no ip proxy-arp
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/0.1
 encapsulation dot1Q 1 native
 ip address 10.170.0.253 255.255.255.0
 no ip redirects
 no ip proxy-arp
interface GigabitEthernet0/0.50
 description VLAN SERVER
 encapsulation dot1Q 50
 ip address 10.170.50.253 255.255.255.0
 no ip redirects
 no ip proxy-arp
 ip nat inside
interface GigabitEthernet0/0.100
 description Phone VLAN
 encapsulation dot1Q 100
 ip address 10.170.100.253 255.255.255.0
 no ip redirects
 no ip proxy-arp
 h323-gateway voip interface
 h323-gateway voip bind srcaddr 10.170.100.253
interface GigabitEthernet0/0.200
 description VLAN ADMINISTRACION
 encapsulation dot1Q 200
 ip address 10.170.200.253 255.255.255.0
 no ip redirects
 no ip proxy-arp
interface GigabitEthernet0/1
 description Enlace RPV-Telmex-100MB
 ip address 10.25.0.114 255.255.255.252
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 no ip route-cache
 duplex full
 speed 100
interface GigabitEthernet0/2
 ip address 190.221.167.186 255.255.255.248
 ip access-group 101 in
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 ip inspect ENTRANTE in
 ip inspect SALIENTE out
 no ip virtual-reassembly in
 no ip route-cache
 duplex full
 speed 100
interface FastEthernet0/0/0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 no ip route-cache
 shutdown
 duplex auto
 speed auto
interface Serial0/1/0:15
 no ip address
 encapsulation hdlc
 isdn incoming-voice voice
 isdn negotiate-bchan
 no cdp enable
interface Virtual-Template1 type tunnel
 ip unnumbered Loopback0
 tunnel mode ipsec ipv4
 tunnel protection ipsec profile CiscoCP_Profile1
router ospf 20
 router-id 10.170.0.0
 area 43 range 10.43.0.0 255.255.0.0
 area 170 range 10.170.0.0 255.255.0.0
 redistribute static subnets route-map redistribuye
 passive-interface GigabitEthernet0/0
 passive-interface GigabitEthernet0/1
 passive-interface GigabitEthernet0/2
 passive-interface FastEthernet0/0/0
 network 10.25.1.0 0.0.0.3 area 0
 network 10.43.0.0 0.0.255.255 area 43
 network 10.170.0.0 0.0.255.255 area 170
ip local pool SDM_POOL_1 192.168.220.1 192.168.220.10
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 103 interface GigabitEthernet0/2 overload
ip nat inside source static tcp 10.170.50.21 80 190.221.167.188 80 extendable
ip nat inside source static tcp 10.170.50.24 80 190.221.167.189 80 extendable
ip route 0.0.0.0 0.0.0.0 190.221.167.185
ip route 10.25.0.0 255.255.255.252 10.25.0.113
ip route 10.43.0.0 255.255.0.0 10.170.0.254
ip route 10.170.0.0 255.255.0.0 10.170.0.254
access-list 10 permit 10.43.0.0
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 10.0.0.0 0.255.255.255
access-list 100 remark CCP_ACL Category=4
access-list 100 permit ip 10.0.0.0 0.255.255.255 any
access-list 101 remark CCP_ACL Category=17
access-list 101 permit tcp any host 190.221.167.186 eq 10000
access-list 101 permit udp any host 190.221.167.186 eq non500-isakmp
access-list 101 permit udp any host 190.221.167.186 eq isakmp
access-list 101 permit esp any host 190.221.167.186
access-list 101 permit ahp any host 190.221.167.186
access-list 101 permit icmp any any
access-list 101 permit udp any eq non500-isakmp any eq non500-isakmp
access-list 101 permit udp any any eq isakmp
access-list 101 permit esp any any
access-list 101 permit ahp any any
access-list 101 permit ip 192.168.221.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 101 permit tcp 10.170.50.0 0.0.0.255 any
access-list 101 permit udp 10.170.50.0 0.0.0.255 any
access-list 101 permit tcp 10.17.50.0 0.0.0.255 any
access-list 101 permit udp 10.17.50.0 0.0.0.255 any
access-list 101 permit tcp host 10.170.0.250 any eq www
access-list 101 permit tcp host 10.170.0.250 any eq 8080
access-list 101 permit tcp host 10.170.0.250 any eq 443
access-list 101 deny   tcp host 10.170.0.250 host 69.171.247.53
access-list 101 deny   tcp host 10.170.0.250 173.194.42.0 0.0.0.255
access-list 101 permit tcp any host 190.221.167.188 eq www
access-list 101 permit tcp any host 190.221.167.189 eq www
access-list 101 deny   ip any any
access-list 103 deny   ip 10.170.0.0 0.0.255.255 10.0.0.0 0.0.0.255
access-list 103 permit ip 10.170.0.0 0.0.255.255 any
access-list 103 deny   ip 10.43.0.0 0.0.255.255 10.0.0.0 0.0.0.255
access-list 103 permit ip 10.43.0.0 0.0.255.255 any
access-list 151 remark voice
access-list 151 permit udp 10.0.100.0 0.255.0.255 any range 16384 32767
access-list 153 remark senalizacion
access-list 153 permit tcp any any eq 2748
access-list 153 permit tcp any any eq 2000
nls resp-timeout 1
cpd cr-id 1
route-map redistribuye permit 10
 match ip address 10
snmp-server community public RO
snmp-server enable traps entity-sensor threshold
control-plane
voice-port 0/1/0:15
 cptone AR
mgcp profile default
sccp local GigabitEthernet0/0.100
sccp ccm 10.170.100.10 identifier 2 version 7.0
sccp ccm 10.14.100.10 identifier 1 version 7.0
sccp ip precedence 3
sccp
sccp ccm group 988
 associate ccm 2 priority 1
 associate ccm 1 priority 2
 associate profile 20 register CFB442b03078a80
 associate profile 6 register MTP442b03078a80
 keepalive retries 5
 switchover method immediate
 switchback method immediate
 switchback interval 15
dspfarm profile 6 transcode
 description Transcoder DSP
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 maximum sessions 4
 associate application SCCP
dspfarm profile 20 conference
 description Conference DSP
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 codec g729r8
 codec g729br8
 maximum sessions 2
dial-peer voice 7150 voip
 description Acceso al AA en CUCM
 destination-pattern 4400
 session target ipv4:10.170.100.10
 voice-class codec 1
 voice-class h323 1
 dtmf-relay h245-alphanumeric
 no vad
dial-peer voice 71501 voip
 session target ipv4:10.14.100.10
 voice-class codec 1
 voice-class h323 1
 no vad
dial-peer voice 71500 voip
 description ** AutoAttendant en SRST
 preference 2
 shutdown
 destination-pattern 7150
 session protocol sipv2
 session target ipv4:10.14.100.2
 dtmf-relay sip-notify
 codec g711ulaw
 no vad
dial-peer voice 9 voip
 description ***TRUNK-SIP***
 translation-profile outgoing PSTN_Outgoing
 shutdown
 destination-pattern 9[2-9].......
 session target ipv4:154.0.185.4
 voice-class sip dtmf-relay force rtp-nte
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 100 voip
 translation-profile incoming CUE_Voicemail/AutoAttendant
 shutdown
 incoming called-number .
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 11 voip
 shutdown
 destination-pattern 9T
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 10 voip
 shutdown
 destination-pattern 9911
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 20 pots
 description ** E1 pots dial-peer **
 progress_ind setup enable 3
 progress_ind alert enable 8
 port 0/1/0:15
 forward-digits 8
dial-peer voice 911 pots
 description ** Emergencias dial-peer **
 port 0/1/0:15
 prefix 911
dial-peer voice 21 pots
 description ** Llamadas a PSTN **
 port 0/1/0:15
dial-peer voice 500 voip
 destination-pattern 44..
 modem passthrough nse codec g711ulaw
 voice-class codec 1
 voice-class h323 1
 signal-type ext-signal
 fax rate disable
 no vad
dial-peer voice 501 voip
 preference 1
 voice-class codec 1
 voice-class h323 1
 fax rate disable
 no vad
dial-peer voice 1 pots
 description Discado Directo Entrante . ver trama
 incoming called-number 44..
 direct-inward-dial
 port 0/1/0:15
dial-peer voice 502 voip
 destination-pattern 4499
 voice-class codec 1
 voice-class h323 1
 no vad
dial-peer voice 503 voip
 preference 1
 voice-class codec 1
 voice-class h323 1
 no vad
num-exp 115299944.. 44..
gateway
 timer receive-rtp 600
sip-ua
 no remote-party-id
 retry invite 2
 reason-header override
gatekeeper
 shutdown
call-manager-fallback
 secondary-dialtone 9
 max-conferences 6 gain -6
 transfer-system full-consult
 user-locale ES
 timeouts interdigit 5
 ip source-address 10.170.100.253 port 2000
 max-ephones 170
 max-dn 200 dual-line
 system message primary Edificio PColon - SRST
 system message secondary Edif PColon-SRST
 keepalive 10
 default-destination 7150
 moh "SampleAudioSource"
 multicast moh 239.1.1.1 port 16384 route 10.170.100.253 10.170.254.254
 time-zone 18
 time-format 24
 date-format dd-mm-yy
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 exec-timeout 30 30
 privilege level 15
 transport input telnet ssh
line vty 5 15
 privilege level 15
scheduler allocate 20000 1000
ntp server 10.170.50.1 prefer
ntp server 10.170.50.2
end
I am assuming you are using a h323 gateway.
Can you please send the following debugs
Debug h225 asn1
debug h245 asn1
debug voip vtsp all
debug fax relay t30 all-level-1
Please put the debugs in a text file and attach to the thread. Please send the calling fax and called fax number
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Hello aokanlawon ,
I sent you the debugs and the details about the faxes :
ORIGIN :  5299-4459
DESTINATION : 4719-8808
pcolon-router#
pcolon-router#
pcolon-router#
pcolon-router#
pcolon-router#
pcolon-router#Debug h225 asn1
H.225 ASN1 Messages debugging is on
pcolon-router#debug h245 asn1
H.245 ASN1 Messages debugging is on
pcolon-router#debug voip vtsp all
voip vtsp all debugging is on
pcolon-router#debug fax relay t30 all-level-1
Debugging fax relay t30 level-1 all
pcolon-router#
pcolon-router#
pcolon-router#terminal monitor
pcolon-router#
pcolon-router#
pcolon-router#
pcolon-router#
pcolon-router#
pcolon-router#
pcolon-router#
pcolon-router#
.Aug 29 11:09:51.202 BUE: H225.0 INCOMING ENCODE BUFFER::= 20B0060008914A00050201807863401F0034003500330030000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000022C0B50000120F436973636F43616C6C4D616E61676572003100010500C486CCC6BA4000279531AF22E103272373010AAA64F900D50D800007000A0E640A06B8110000279531AF22E103272373010AAA64F9010001000100010010A00100140140B50000120D81E40020040001030003000103
.Aug 29 11:09:51.202 BUE: H225.0 INCOMING PDU ::=
value H323_UserInformation ::=
      h323-uu-pdu
        h323-message-body setup :
          protocolIdentifier { 0 0 8 2250 0 5 }
          sourceAddress
            dialedDigits : "4530",
            h323-ID : {"4530..."}
          sourceInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              productId '436973636F43616C6C4D616E61676572'H
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
          destinationAddress
            dialedDigits : "91539993871"
          activeMC FALSE
          conferenceID '00279531AF22E103272373010AAA64F9'H
          conferenceGoal create : NULL
          callType pointToPoint : NULL
          sourceCallSignalAddress ipAddress :
            ip '0A0E640A'H
            port 1720
          callIdentifier
            guid '00279531AF22E103272373010AAA64F9'H
          mediaWaitForConnect FALSE
          canOverlapSend FALSE
          multipleCalls FALSE
          maintainConnection FALSE
        h245Tunneling FALSE
        nonStandardControl
            nonStandardIdentifier h221NonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '81E40020040001030003000103'H
.Aug 29 11:09:51.202 BUE: H225 NONSTD INCOMING ENCODE BUFFER::= 81E40020040001030003000103
.Aug 29 11:09:51.202 BUE: H225 NONSTD INCOMING PDU ::=
value H323_UU_NonStdInfo ::=
      callMgrParam
        interclusterVersion 3
        enterpriseID {}
.Aug 29 11:09:51.206 BUE: //-1/xxxxxxxxxxxx/VTSP:(0/1/0:15):-1:-1:-1/vtsp_allocate_cdb:
   CDB=0x1C00F690
.Aug 29 11:09:51.206 BUE: //-1/xxxxxxxxxxxx/VTSP:(0/1/0:15):-1:-1:-1/vtsp_insert_cdb:
.Aug 29 11:09:51.206 BUE: //-1/xxxxxxxxxxxx/VTSP:(0/1/0:15):-1:-1:-1/vtsp_process_event:
   [state:INVALID STATE MACHINE, event:E_CC_SETUP_REQ]
.Aug 29 11:09:51.206 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):-1:-1:-1/vtsp_og_call_req:
   Echo Cancel=TRUE, Gain Control=0
   Auto Gain Control=FALSE, Dual Tone Detect Mask=0x0, Seq Tone Detect=FALSE
.Aug 29 11:09:51.206 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):-1:-1:-1/vtsp_do_call_setup_req:
.Aug 29 11:09:51.206 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):-1:0:0/vtsp_dsm_opened_cb:
.Aug 29 11:09:51.206 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):-1:0:0/vtsp_process_event:
   [state:S_SETUP_REQ_PEND, event:E_VTSP_DSM_OPEN_SUCCESS]
.Aug 29 11:09:51.206 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):-1:0:0/act_setup_req_pend_succ:
.Aug 29 11:09:51.206 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):-1:0:0/vtsp_request_call:
   Mode=0, Peer=21
.Aug 29 11:09:51.206 BUE: digit_strip:1, pcn:91539993871, poa:9T
.Aug 29 11:09:51.206 BUE: pcn:1539993871, poa:T
.Aug 29 11:09:51.206 BUE: Final pcn:1539993871, poa:T, dial_string:1539993871
.Aug 29 11:09:51.206 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):-1:0:0/vtsp_create_call_active_on_setup_req:
   Target Carrier ID=
   Source Carrier ID=
   Progress Indication=0, Info Trans Capability=0
   Calling Number=4530, TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed
   Called Number=91539993871, TON=Unknown, NPI=Unknown
.Aug 29 11:09:51.206 BUE: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body callProceeding :
          protocolIdentifier { 0 0 8 2250 0 4 }
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          h245Address ipAddress :
            ip '0AAA64FD'H
            port 55328
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
.Aug 29 11:09:51.206 BUE: H225.0 OUTGOING ENCODE BUFFER::= 21C0060008914A00042800B500001240013C050100000AAA64FDD820110C110000279531AF22E103272373010AAA64F90100010010800100
.Aug 29 11:09:51.246 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:0:0/vtsp_process_event:
   [state:S_SETUP_REQUEST, event:E_TSP_PROGRESS]
.Aug 29 11:09:51.246 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:0:0/act_setup_pend_first_progress:
   Progress Indication=1, Signal Indication=2
.Aug 29 11:09:51.246 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:0:0/vtsp_timer:
   Timer Start Time=42708735, Timer Value=25000(ms)
   Peer=21, Return Code=2
.Aug 29 11:09:51.246 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_dsm_opened_cb:
.Aug 29 11:09:51.246 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_process_event:
   [state:S_NULL, event:E_VTSP_DSM_OPEN_SUCCESS]
.Aug 29 11:09:51.246 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/act_setup_req_wait_pend_success:
   Event=75
.Aug 29 11:09:51.246 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_timer_stop:
   Timer Stop Time=42708735
.Aug 29 11:09:51.246 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_dsm_bridge_check_cb:
.Aug 29 11:09:51.246 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_dsm_bridge_check_cb:exit@1477
.Aug 29 11:09:51.246 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_dsm_bridge_status_cb:
.Aug 29 11:09:51.246 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_dsm_save_fax_config:
   Fax Relay=ENABLED
   Primary Fax Protocol=T38_FAX_RELAY, Fallback Fax Protocol=NONE_FAX_RELAY
   Fax Relay CM Suppression :=ENABLED, Fax Relay ANS Suppression :=DISABLED
   Fax Parameters Set By=Global Settings
   Fax Version:=0, LS Red=0, HS Red=0
.Aug 29 11:09:51.246 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_dsm_set_fax_feat_param:
.Aug 29 11:09:51.246 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_dsm_save_tty_config:
   Save TTY configuration
.Aug 29 11:09:51.246 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_dsm_set_tty_feat_param:
   Set TTY feat parameters
   [state:S_SETUP_PROGRESS, event:E_CC_DO_CAPS_IND]
.Aug 29 11:09:51.246 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_dsm_peer_event_cb:
   Event=E_DSM_CC_CAPS_IND
.Aug 29 11:09:51.250 BUE: H225 NONSTD OUTGOING PDU ::=
      version 16
      protoParam qsigNonStdInfo :
        iei 30
        rawMesg '1E028181'H
.Aug 29 11:09:51.250 BUE: H225 NONSTD OUTGOING ENCODE BUFFER::= 60011000011E041E028181
.Aug 29 11:09:51.250 BUE: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body progress :
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
            ip '0AAA64FD'H
            port 55328
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '60011000011E041E028181'H
.Aug 29 11:09:51.250 BUE: H225.0 OUTGOING ENCODE BUFFER::= 280032C0060008914A00042800B500001240013C050100000AAA64FDD8200000279531AF22E103272373010AAA64F905800100010010A00100120140B50000120B60011000011E041E028181
.Aug 29 11:09:51.458 BUE: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= request : terminalCapabilitySet :
      sequenceNumber 1
      protocolIdentifier { 0 0 8 245 0 7 }
      multiplexCapability h2250Capability :
        maximumAudioDelayJitter 20
        receiveMultipointCapability
          multicastCapability FALSE
          multiUniCastConference FALSE
          mediaDistributionCapability
              centralizedControl FALSE
              distributedControl FALSE
              centralizedAudio FALSE
              distributedAudio FALSE
              centralizedVideo FALSE
              distributedVideo FALSE
        transmitMultipointCapability
        receiveAndTransmitMultipointCapability
        mcCapability
          centralizedConferenceMC FALSE
          decentralizedConferenceMC FALSE
        rtcpVideoControlCapability FALSE
        mediaPacketizationCapability
          h261aVideoPacketization FALSE
        logicalChannelSwitchingCapability FALSE
        t120DynamicPortCapability FALSE
      capabilityTable
          capabilityTableEntryNumber 32
          capability receiveAndTransmitDataApplicationCapability :
            application t38fax :
              t38FaxProtocol udp : NULL
              t38FaxProfile
                fillBitRemoval FALSE
                transcodingJBIG FALSE
                transcodingMMR FALSE
                version 0
                t38FaxRateManagement transferredTCF : NULL
                t38FaxUdpOptions
                  t38FaxMaxBuffer 200
                  t38FaxMaxDatagram 320
                  t38FaxUdpEC t38UDPRedundancy : NULL
            maxBitRate 144
          capabilityTableEntryNumber 39
          capability receiveAudioCapability : genericAudioCapability :
            capabilityIdentifier standard : { 1 3 6 1 4 1 30942 0 1 }
          capabilityTableEntryNumber 21
          capability receiveAudioCapability : g722-48k : 20
          capabilityTableEntryNumber 20
          capability receiveAudioCapability : g722-56k : 20
          capabilityTableEntryNumber 19
          capability receiveAudioCapability : g722-64k : 20
          capabilityTableEntryNumber 17
          capability receiveAudioCapability : nonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '436C65617243686964'H
          capabilityTableEntryNumber 6
          capability receiveAudioCapability : g729AnnexA : 2
          capabilityTableEntryNumber 5
          capability receiveAudioCapability : g729 : 2
          capabilityTableEntryNumber 13
          capability receiveAudioCapability : g729wAnnexB : 2
          capabilityTableEntryNumber 14
          capability receiveAudioCapability : g729AnnexAwAnnexB : 2
          capabilityTableEntryNumber 15
          capability receiveAudioCapability : g7231 :
            maxAl-sduAudioFrames 1
            silenceSuppression TRUE
          capabilityTableEntryNumber 16
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '47373233316172'H
          capabilityTableEntryNumber 11
            silenceSuppression FALSE
          capability receiveAudioCapability : g711Ulaw64k : 20
          capabilityTableEntryNumber 4
          capability receiveAudioCapability : g711Alaw64k : 20
          capabilityTableEntryNumber 10
          capability receiveAudioCapability : g728 : 8
          capabilityTableEntryNumber 9
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '47373236723332'H
          capabilityTableEntryNumber 8
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '47373236723234'H
          capabilityTableEntryNumber 7
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '47373236723136'H
      capabilityDescriptors
          capabilityDescriptorNumber 1
          simultaneousCapabilities
              32,
              5,
              6,
              13,
              14,
              3,
              4,
              7,
              8,
              9,
              17,
              10,
              16,
              15,
              11,
              11,
              19,
              20,
              21,
              39
.Aug 29 11:09:51.462 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 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
.Aug 29 11:09:51.462 BUE: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= request : masterSlaveDetermination :
      terminalType 60
      statusDeterminationNumber 6706
.Aug 29 11:09:51.462 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 01003C401A32
.Aug 29 11:09:52.018 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 86
.Aug 29 11:09:52.018 BUE: H245 MSC INCOMING ENCODE BUFFER::= 0270010600088175000A801380003C000100000100000100000CC00100010004800000860A0000070008824301030180000120C01380000285014080000385011080002B85015000800002000001010002000300002B
.Aug 29 11:09:52.018 BUE: H245 MSC INCOMING PDU ::=
      sequenceNumber 1
      protocolIdentifier { 0 0 8 245 0 10 }
        maximumAudioDelayJitter 60
        mcCapability
      capabilityTable
          capability genericControlCapability :
            capabilityIdentifier standard : { 0 0 8 323 1 3 1 }
          capability receiveAndTransmitUserInputCapability : dtmf : NULL
          capability receiveAndTransmitUserInputCapability : basicString : NULL
          capabilityTableEntryNumber 44
          capability receiveAndTransmitUserInputCapability : hookflash : NULL
          capabilityDescriptorNumber 0
.Aug 29 11:09:52.018 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:09:52.018 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:09:52.018 BUE: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : terminalCapabilitySetAck :
      sequenceNumber 1
.Aug 29 11:09:52.018 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 218001
.Aug 29 11:09:52.018 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 3
.Aug 29 11:09:52.018 BUE: H245 MSC INCOMING ENCODE BUFFER::= 218001
      sequenceNumber 1
.Aug 29 11:09:52.026 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 2
.Aug 29 11:09:52.026 BUE: H245 MSC INCOMING ENCODE BUFFER::= 2080
.Aug 29 11:09:52.026 BUE: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= response : masterSlaveDeterminationAck :
      decision master : NULL
.Aug 29 11:09:52.026 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:09:52.026 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:09:52.026 BUE: H245 MSC OUTGOING PDU ::=
      decision slave : NULL
.Aug 29 11:09:52.026 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 20A0
value MultimediaSystemControlMessage ::= request : openLogicalChannel :
      forwardLogicalChannelNumber 1
      forwardLogicalChannelParameters
        dataType audioData : g711Ulaw64k : 20
        multiplexParameters h2250LogicalChannelParameters :
          sessionID 1
          mediaControlChannel unicastAddress : iPAddress :
            network '0AAA64FD'H
            tsapIdentifier 29569
.Aug 29 11:09:52.026 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 030000000C6013800B050001000AAA64FD738180
.Aug 29 11:09:52.078 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 20
.Aug 29 11:09:52.078 BUE: H245 MSC INCOMING ENCODE BUFFER::= 030000000C6013800B050001000A0E640A0FA100
.Aug 29 11:09:52.078 BUE: H245 MSC INCOMING PDU ::=
          sessionID 1
            network '0A0E640A'H
            tsapIdentifier 4001
.Aug 29 11:09:52.078 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:09:52.078 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:09:52.078 BUE: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : openLogicalChannelAck :
      forwardMultiplexAckParameters h2250LogicalChannelAckParameters :
        mediaChannel unicastAddress : iPAddress :
          network '0AAA64FD'H
          tsapIdentifier 29568
          network '0AAA64FD'H
        flowControlToZero FALSE
.Aug 29 11:09:52.078 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 22C000000680134C000AAA64FD7380000AAA64FD738103000100
.Aug 29 11:09:52.078 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_process_event:
   [state:S_SETUP_PROGRESS, event:E_CC_CAPS_IND]
.Aug 29 11:09:52.078 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_dsm_peer_event_cb:
   Event=E_DSM_CC_CAPS_ACK
.Aug 29 11:09:52.082 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_dsm_feature_notify_cb:
   Feature ID=0, Feature Status=1
.Aug 29 11:09:52.082 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_dsm_reactivate_ringback:
.Aug 29 11:09:52.082 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_dsm_reactivate_ringback:exit@1268
.Aug 29 11:09:52.098 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 23
.Aug 29 11:09:52.098 BUE: H245 MSC INCOMING ENCODE BUFFER::= 22C000000480101C00000AAA64F949FE000AAA64F949FF
.Aug 29 11:09:52.098 BUE: H245 MSC INCOMING PDU ::=
        sessionID 1
          network '0AAA64F9'H
          tsapIdentifier 18942
          network '0AAA64F9'H
          tsapIdentifier 18943
.Aug 29 11:09:52.098 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:09:52.098 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:09:52.306 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 4
.Aug 29 11:09:52.306 BUE: H245 MSC INCOMING ENCODE BUFFER::= 6D400133
.Aug 29 11:09:52.306 BUE: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= indication : userInput : alphanumeric : "3"
.Aug 29 11:09:52.306 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:09:52.306 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:09:52.306 BUE: //21386/xxxxxxxxxxxx/VTSP:(0/1/0:15):25:1:6/vtsp_call_digit_begin:
   Begin Digit=3
.Aug 29 11:09:52.342 BUE: //21387/04C062578D9B/VTSP:(0/1/0:15):1:1:7/vtsp_dsm_digit_begin_cb:
   Begin Digit=4
   Digit Reporting=FALSE, Digit Consume=FALSE, Digit Relay=TRUE
.Aug 29 11:09:52.342 BUE: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= indication : userInput : alphanumeric : "4"
.Aug 29 11:09:52.342 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 6D400134
.Aug 29 11:09:52.506 BUE: //21386/xxxxxxxxxxxx/VTSP:(0/1/0:15):25:1:6/vtsp_call_digit_end:
   End Digit=3, Duration=200
.Aug 29 11:09:52.514 BUE: //21387/04C062578D9B/VTSP:(0/1/0:15):1:1:7/vtsp_dsm_digit_end_cb:
.Aug 29 11:09:52.514 BUE: //21387/04C062578D9B/VTSP:(0/1/0:15):1:1:7/vtsp_timer_stop:
   Timer Stop Time=42708862
   End Digit=4
.Aug 29 11:09:52.598 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 4
.Aug 29 11:09:52.598 BUE: H245 MSC INCOMING ENCODE BUFFER::= 6D400134
.Aug 29 11:09:52.598 BUE: H245 MSC INCOMING PDU ::=
.Aug 29 11:09:52.598 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:09:52.598 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:09:52.606 BUE: //21386/xxxxxxxxxxxx/VTSP:(0/1/0:15):25:1:6/vtsp_call_digit_begin:
   Begin Digit=4
.Aug 29 11:09:52.614 BUE: //21387/04C062578D9B/VTSP:(0/1/0:15):1:1:7/vtsp_dsm_digit_begin_cb:
   Begin Digit=5
.Aug 29 11:09:52.614 BUE: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= indication : userInput : alphanumeric : "5"
.Aug 29 11:09:52.614 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 6D400135
.Aug 29 11:09:52.730 BUE: //21387/04C062578D9B/VTSP:(0/1/0:15):1:1:7/vtsp_dsm_digit_end_cb:
.Aug 29 11:09:52.730 BUE: //21387/04C062578D9B/VTSP:(0/1/0:15):1:1:7/vtsp_timer_stop:
   Timer Stop Time=42708883
   End Digit=5
.Aug 29 11:09:52.806 BUE: //21386/xxxxxxxxxxxx/VTSP:(0/1/0:15):25:1:6/vtsp_call_digit_end:
   End Digit=4, Duration=200
.Aug 29 11:09:52.882 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 4
.Aug 29 11:09:52.882 BUE: H245 MSC INCOMING ENCODE BUFFER::= 6D400130
.Aug 29 11:09:52.882 BUE: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= indication : userInput : alphanumeric : "0"
.Aug 29 11:09:52.882 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:09:52.882 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:09:52.906 BUE: //21386/xxxxxxxxxxxx/VTSP:(0/1/0:15):25:1:6/vtsp_call_digit_begin:
   Begin Digit=0
.Aug 29 11:09:53.106 BUE: //21386/xxxxxxxxxxxx/VTSP:(0/1/0:15):25:1:6/vtsp_call_digit_end:
   End Digit=0, Duration=200
.Aug 29 11:09:53.162 BUE: //21387/04C062578D9B/VTSP:(0/1/0:15):1:1:7/vtsp_dsm_digit_begin_cb:
   Begin Digit=0
.Aug 29 11:09:53.162 BUE: H245 MSC OUTGOING PDU ::=
.Aug 29 11:09:53.162 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 6D400130
.Aug 29 11:09:53.198 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 4
.Aug 29 11:09:53.198 BUE: H245 MSC INCOMING ENCODE BUFFER::= 6D400136
.Aug 29 11:09:53.198 BUE: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= indication : userInput : alphanumeric : "6"
.Aug 29 11:09:53.198 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:09:53.198 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:09:53.206 BUE: //21386/xxxxxxxxxxxx/VTSP:(0/1/0:15):25:1:6/vtsp_call_digit_begin:
   Begin Digit=6
.Aug 29 11:09:53.274 BUE: //21387/04C062578D9B/VTSP:(0/1/0:15):1:1:7/vtsp_dsm_digit_end_cb:
.Aug 29 11:09:53.274 BUE: //21387/04C062578D9B/VTSP:(0/1/0:15):1:1:7/vtsp_timer_stop:
   Timer Stop Time=42708938
   End Digit=0
.Aug 29 11:09:53.406 BUE: //21386/xxxxxxxxxxxx/VTSP:(0/1/0:15):25:1:6/vtsp_call_digit_end:
   End Digit=6, Duration=200
.Aug 29 11:09:53.502 BUE: //21387/04C062578D9B/VTSP:(0/1/0:15):1:1:7/vtsp_dsm_digit_begin_cb:
   Begin Digit=3
.Aug 29 11:09:53.502 BUE: H245 MSC OUTGOING PDU ::=
.Aug 29 11:09:53.502 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 6D400133
.Aug 29 11:09:53.610 BUE: //21387/04C062578D9B/VTSP:(0/1/0:15):1:1:7/vtsp_dsm_digit_end_cb:
.Aug 29 11:09:53.610 BUE: //21387/04C062578D9B/VTSP:(0/1/0:15):1:1:7/vtsp_timer_stop:
   Timer Stop Time=42708971
   End Digit=3
.Aug 29 11:09:54.294 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_process_event:
   [state:S_SETUP_PROGRESS, event:E_TSP_PROCEEDING]
.Aug 29 11:09:54.294 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/act_setup_pend_prog_proceeding:
   Progress Indication=8
.Aug 29 11:09:55.565 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_process_event:
   [state:S_SETUP_REQ_PROC, event:E_TSP_ALERT]
.Aug 29 11:09:55.565 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/act_setup_pend_alert:
   Progress Indication=2, Signal Indication=1
.Aug 29 11:09:55.565 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_ring_noan_timer_start:
   Timer Start Time=42709167, No Answer Timer Value=180000(ms)
   Ringback Indication=FALSE, Ring Timeout=180(s)
.Aug 29 11:09:55.565 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_dsm_reactivate_ringback:
.Aug 29 11:09:55.565 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_dsm_reactivate_ringback:exit@1268
.Aug 29 11:09:55.565 BUE: H225 NONSTD OUTGOING PDU ::=
      version 1
        iei 30
        rawMesg '1E0280821C269E8100036774640000001B41434D...'H
.Aug 29 11:09:55.565 BUE: H225 NONSTD OUTGOING ENCODE BUFFER::= 60010100011E2C1E0280821C269E8100036774640000001B41434D2C0D0A50524E2C6973646E2A2C2C4E4554352A2C0D0A0D0A
.Aug 29 11:09:55.565 BUE: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body alerting :
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
            ip '0AAA64FD'H
            port 55328
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '60010100011E2C1E0280821C269E810003677464...'H
        tunnelledSignallingMessage
          tunnelledProtocolID
            id tunnelledProtocolAlternateID :
              protocolType "gtd"
          messageContent
            '41434D2C0D0A50524E2C6973646E2A2C2C4E4554...'H
          tunnellingRequired NULL
.Aug 29 11:09:55.569 BUE: H225.0 OUTGOING ENCODE BUFFER::= 23C0060008914A00042800B500001240013C050100000AAA64FDD8201B0C00110000279531AF22E103272373010AAA64F90100010010A801003A0140B50000123360010100011E2C1E0280821C269E8100036774640000001B41434D2C0D0A50524E2C6973646E2A2C2C4E4554352A2C0D0A0D0A224204677464011B41434D2C0D0A50524E2C6973646E2A2C2C4E4554352A2C0D0A0D0A
.Aug 29 11:09:55.793 BUE: %ISDN-6-CONNECT: Interface Serial0/1/0:23 is now connected to 1539993871 N/A
.Aug 29 11:09:55.793 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_process_event:
   [state:S_SETUP_REQ_PROC, event:E_TSP_CONNECT]
.Aug 29 11:09:55.793 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/act_setup_pend_connect:
.Aug 29 11:09:55.793 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_ring_noan_timer_stop:
   Timer Stop Time=42709190
.Aug 29 11:09:55.793 BUE: H225 NONSTD OUTGOING PDU ::=
      version 1
        iei 76
        rawMesg '4C0C0083313533393939333837311C269E810003...'H
.Aug 29 11:09:55.793 BUE: H225 NONSTD OUTGOING ENCODE BUFFER::= 60010100014C364C0C0083313533393939333837311C269E8100036774640000001B414E4D2C0D0A50524E2C6973646E2A2C2C4E4554352A2C0D0A0D0A
.Aug 29 11:09:55.793 BUE: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body connect :
            ip '0AAA64FD'H
            port 55328
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '60010100014C364C0C0083313533393939333837...'H
          tunnelledProtocolID
              protocolType "gtd"
          messageContent
            '414E4D2C0D0A50524E2C6973646E2A2C2C4E4554...'H
.Aug 29 11:09:55.797 BUE: H225.0 OUTGOING ENCODE BUFFER::= 22C0060008914A0004000AAA64FDD8202800B500001240013C0501000000279531AF22E103272373010AAA64F91D0C00110000279531AF22E103272373010AAA64F90100010010A80100440140B50000123D60010100014C364C0C0083313533393939333837311C269E8100036774640000001B414E4D2C0D0A50524E2C6973646E2A2C2C4E4554352A2C0D0A0D0A224204677464011B414E4D2C0D0A50524E2C6973646E2A2C2C4E4554352A2C0D0A0D0A
.Aug 29 11:09:55.933 BUE: H225.0 INCOMING ENCODE BUFFER::= 20B0060008914A00050201807836401F0034003500300033000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000022C0B50000120F436973636F43616C6C4D616E61676572003100010400C793853C3080179034B422E103282375010AAA64FA00D50D800007000A0E640A06B8110080179034B422E103282375010AAA64FA010001000100010010A00100140140B50000120D81E40020040001030003000103
.Aug 29 11:09:55.933 BUE: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          sourceAddress
            dialedDigits : "4503",
            h323-ID : {"4503..."}
          sourceInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
          destinationAddress
            dialedDigits : "946052090"
          activeMC FALSE
          conferenceID '80179034B422E103282375010AAA64FA'H
            ip '0A0E640A'H
            port 1720
          callIdentifier
            guid '80179034B422E103282375010AAA64FA'H
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
.Aug 29 11:09:55.937 BUE: H225 NONSTD INCOMING ENCODE BUFFER::= 81E40020040001030003000103
.Aug 29 11:09:55.937 BUE: H225 NONSTD INCOMING PDU ::=
      callMgrParam
        enterpriseID {}
.Aug 29 11:09:55.937 BUE: //-1/xxxxxxxxxxxx/VTSP:(0/1/0:15):-1:-1:-1/vtsp_allocate_cdb:
   CDB=0x1C00FC40
.Aug 29 11:09:55.937 BUE: //-1/xxxxxxxxxxxx/VTSP:(0/1/0:15):-1:-1:-1/vtsp_insert_cdb:
.Aug 29 11:09:55.937 BUE: //-1/xxxxxxxxxxxx/VTSP:(0/1/0:15):-1:-1:-1/vtsp_process_event:
.Aug 29 11:09:55.937 BUE: //21392/801790342823/VTSP:(0/1/0:15):-1:-1:-1/vtsp_og_call_req:
.Aug 29 11:09:55.937 BUE: //21392/801790342823/VTSP:(0/1/0:15):-1:-1:-1/vtsp_do_call_setup_req:
.Aug 29 11:09:55.937 BUE: //21392/801790342823/VTSP:(0/1/0:15):-1:0:0/vtsp_dsm_opened_cb:
.Aug 29 11:09:55.937 BUE: //21392/801790342823/VTSP:(0/1/0:15):-1:0:0/vtsp_process_event:
.Aug 29 11:09:55.937 BUE: //21392/801790342823/VTSP:(0/1/0:15):-1:0:0/act_setup_req_pend_succ:
.Aug 29 11:09:55.937 BUE: //21392/801790342823/VTSP:(0/1/0:15):-1:0:0/vtsp_request_call:
   Mode=0, Peer=20
.Aug 29 11:09:55.937 BUE: //21392/801790342823/VTSP:(0/1/0:15):-1:0:0/vtsp_create_call_active_on_setup_req:
   Target Carrier ID=
   Source Carrier ID=
   Calling Number=4503, TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed
   Called Number=946052090, TON=Unknown, NPI=Unknown
.Aug 29 11:09:55.941 BUE: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
            ip '0AAA64FD'H
            port 31178
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
.Aug 29 11:09:55.941 BUE: H225.0 OUTGOING ENCODE BUFFER::= 21C0060008914A00042800B500001240013C050100000AAA64FD79CA110C110080179034B422E103282375010AAA64FA0100010010800100
.Aug 29 11:09:55.985 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:0:0/vtsp_process_event:
.Aug 29 11:09:55.985 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:0:0/act_setup_pend_first_progress:
.Aug 29 11:09:55.985 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:0:0/vtsp_timer:
   Timer Start Time=42709209, Timer Value=25000(ms)
   Peer=20, Return Code=2
.Aug 29 11:09:55.985 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_dsm_opened_cb:
.Aug 29 11:09:55.985 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_process_event:
.Aug 29 11:09:55.985 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/act_setup_req_wait_pend_success:
   Event=75
.Aug 29 11:09:55.985 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_timer_stop:
   Timer Stop Time=42709209
.Aug 29 11:09:55.985 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_dsm_bridge_check_cb:
.Aug 29 11:09:55.985 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_dsm_bridge_check_cb:exit@1477
.Aug 29 11:09:55.985 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_dsm_bridge_status_cb:
.Aug 29 11:09:55.985 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_dsm_save_fax_config:
   Fax Relay=ENABLED
.Aug 29 11:09:55.985 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_dsm_set_fax_feat_param:
.Aug 29 11:09:55.985 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_dsm_save_tty_config:
.Aug 29 11:09:55.985 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_dsm_set_tty_feat_param:
.Aug 29 11:09:55.985 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_dsm_peer_event_cb:
.Aug 29 11:09:55.989 BUE: H225 NONSTD OUTGOING PDU ::=
      version 16
        iei 30
        rawMesg '1E028181'H
.Aug 29 11:09:55.989 BUE: H225 NONSTD OUTGOING ENCODE BUFFER::= 60011000011E041E028181
.Aug 29 11:09:55.989 BUE: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
            ip '0AAA64FD'H
            port 31178
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
.Aug 29 11:09:55.989 BUE: H225.0 OUTGOING ENCODE BUFFER::= 280032C0060008914A00042800B500001240013C050100000AAA64FD79CA0080179034B422E103282375010AAA64FA05800100010010A00100120140B50000120B60011000011E041E028181
.Aug 29 11:09:56.045 BUE: H245 MSC OUTGOING PDU ::=
      sequenceNumber 1
        mcCapability
      capabilityTable
              t38FaxProfile
                version 0
                t38FaxUdpOptions
                  t38FaxMaxBuffer 200
            maxBitRate 144
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
              32,
              5,
              6,
              13,
              14,
              3,
              4,
              7,
              8,
              9,
              17,
              10,
              16,
              15,
              11,
              11,
              19,
              20,
              21,
              39
.Aug 29 11:09:56.049 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 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
.Aug 29 11:09:56.049 BUE: H245 MSC OUTGOING PDU ::=
      terminalType 60
      statusDeterminationNumber 8934
.Aug 29 11:09:56.049 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 01003C4022E6
.Aug 29 11:09:56.201 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 86
.Aug 29 11:09:56.201 BUE: H245 MSC INCOMING ENCODE BUFFER::= 0270010600088175000A801380003C000100000100000100000CC00100010004800000860A0000070008824301030180000120C01380000285014080000385011080002B85015000800002000001010002000300002B
.Aug 29 11:09:56.201 BUE: H245 MSC INCOMING PDU ::=
      sequenceNumber 1
        mcCapability
      capabilityTable
.Aug 29 11:09:56.205 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:09:56.205 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:09:56.205 BUE: H245 MSC OUTGOING PDU ::=
      sequenceNumber 1
.Aug 29 11:09:56.205 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 218001
.Aug 29 11:09:56.205 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 3
.Aug 29 11:09:56.205 BUE: H245 MSC INCOMING ENCODE BUFFER::= 218001
.Aug 29 11:09:56.205 BUE: H245 MSC INCOMING PDU ::=
      sequenceNumber 1
.Aug 29 11:09:56.209 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 2
.Aug 29 11:09:56.209 BUE: H245 MSC INCOMING ENCODE BUFFER::= 2080
.Aug 29 11:09:56.209 BUE: H245 MSC INCOMING PDU ::=
.Aug 29 11:09:56.209 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:09:56.209 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:09:56.209 BUE: H245 MSC OUTGOING PDU ::=
.Aug 29 11:09:56.209 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 20A0
          sessionID 1
            network '0AAA64FD'H
            tsapIdentifier 25255
.Aug 29 11:09:56.213 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 030000000C6013800B050001000AAA64FD62A780
.Aug 29 11:09:56.241 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 20
.Aug 29 11:09:56.241 BUE: H245 MSC INCOMING ENCODE BUFFER::= 030000000C6013800B050001000A0E640A0FA100
.Aug 29 11:09:56.241 BUE: H245 MSC INCOMING PDU ::=
          sessionID 1
            network '0A0E640A'H
            tsapIdentifier 4001
.Aug 29 11:09:56.245 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:09:56.245 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:09:56.245 BUE: H245 MSC OUTGOING PDU ::=
          network '0AAA64FD'H
          tsapIdentifier 25254
          network '0AAA64FD'H
.Aug 29 11:09:56.245 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 22C000000680134C000AAA64FD62A6000AAA64FD62A703000100
.Aug 29 11:09:56.245 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_process_event:
.Aug 29 11:09:56.245 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_dsm_peer_event_cb:
.Aug 29 11:09:56.245 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_dsm_feature_notify_cb:
.Aug 29 11:09:56.245 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_dsm_reactivate_ringback:
.Aug 29 11:09:56.245 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_dsm_reactivate_ringback:exit@1268
.Aug 29 11:09:56.249 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 23
.Aug 29 11:09:56.249 BUE: H245 MSC INCOMING ENCODE BUFFER::= 22C000000480101C00000AAA64FA4BA4000AAA64FA4BA5
.Aug 29 11:09:56.249 BUE: H245 MSC INCOMING PDU ::=
        sessionID 1
          network '0AAA64FA'H
          tsapIdentifier 19364
          network '0AAA64FA'H
          tsapIdentifier 19365
.Aug 29 11:09:56.249 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:09:56.249 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:09:58.877 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 5
.Aug 29 11:09:58.877 BUE: H245 MSC INCOMING ENCODE BUFFER::= 0400000000
.Aug 29 11:09:58.877 BUE: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= request : closeLogicalChannel :
      source user : NULL
.Aug 29 11:09:58.877 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:09:58.877 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:09:58.877 BUE: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : closeLogicalChannelAck :
.Aug 29 11:09:58.877 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 23800000
.Aug 29 11:09:58.885 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 2
.Aug 29 11:09:58.885 BUE: H245 MSC INCOMING ENCODE BUFFER::= 4A40
.Aug 29 11:09:58.885 BUE: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= command : endSessionCommand : disconnect : NULL
.Aug 29 11:09:58.885 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:09:58.885 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:09:58.885 BUE: H245 MSC OUTGOING PDU ::=
.Aug 29 11:09:58.885 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 4A40
.Aug 29 11:09:58.901 BUE: H225.0 INCOMING ENCODE BUFFER::= 2580060008914A00051100110000279531AF22E103272373010AAA64F910800100
.Aug 29 11:09:58.901 BUE: H225.0 INCOMING PDU ::=
      h323-uu-pdu
        h323-message-body releaseComplete :
          callIdentifier
        h245Tunneling FALSE
.Aug 29 11:09:58.905 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_dsm_bridge_status_cb:
.Aug 29 11:09:58.905 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_process_event:
   [state:S_CONNECT, event:E_CC_DISCONNECT]
.Aug 29 11:09:58.905 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/act_disconnect:
   Cause Value=16
.Aug 29 11:09:58.905 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_ring_noan_timer_stop:
   Timer Stop Time=42709501
.Aug 29 11:09:58.909 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_dsm_get_levels_done_cb:
.Aug 29 11:09:58.909 BUE: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
.Aug 29 11:09:58.909 BUE: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A00041100110000279531AF22E103272373010AAA64F910800100
.Aug 29 11:09:58.917 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_process_event:
   [state:S_WAIT_STATS, event:E_VTSP_DSM_STATS_COMPLETE]
.Aug 29 11:09:58.921 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/act_dsm_dsp_stats_complete:
.Aug 29 11:09:58.921 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_timer:
   Timer Start Time=42709502, Timer Value=60000(ms)
.Aug 29 11:09:58.921 BUE: %ISDN-6-DISCONNECT: Interface Serial0/1/0:23  disconnected from 1539993871 , call lasted 3 seconds
.Aug 29 11:09:58.949 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_process_event:
   [state:S_WAIT_RELEASE, event:E_TSP_DISCONNECT_CONF]
.Aug 29 11:09:58.949 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/act_wrelease_release:
.Aug 29 11:09:58.949 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_play_busy_timer_stop:
   Timer Stop Time=42709505
.Aug 29 11:09:58.949 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_timer_stop:
.Aug 29 11:09:58.949 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_do_call_history:
   Coder Rate=5
.Aug 29 11:09:58.949 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:1:8/vtsp_is_valid_dsm_handle:
   DMGR=0x1AD5A14, VTSP CDB=0x1C00F690
.Aug 29 11:09:58.949 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:-1:-1/vtsp_dsm_closed_cb:
.Aug 29 11:09:58.949 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:-1:-1/vtsp_process_event:
   [state:S_CLOSE_DSPRM, event:E_VTSP_DSM_CLOSE_COMPLETE]
.Aug 29 11:09:58.949 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:-1:-1/act_terminate:
.Aug 29 11:09:58.949 BUE: //21390/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:-1:-1/vtsp_timer_stop:
.Aug 29 11:09:58.949 BUE: //-1/xxxxxxxxxxxx/VTSP:(0/1/0:15):23:-1:-1/vtsp_free_cdb:
   CDB=0x1C00F690
.Aug 29 11:09:59.037 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_process_event:
.Aug 29 11:09:59.037 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/act_setup_pend_prog_proceeding:
.Aug 29 11:09:59.993 BUE: RAS OUTGOING PDU ::=
value RasMessage ::= gatekeeperRequest :
      requestSeqNum 8631
      rasAddress ipAddress :
        ip '0AAA64FD'H
        port 60477
      endpointType
        vendor
          vendor
            t35CountryCode 181
            t35Extension 0
            manufacturerCode 18
        gateway
          protocol
            voice :
              supportedPrefixes
        mc FALSE
        undefinedNode FALSE
.Aug 29 11:09:59.993 BUE: RAS OUTGOING ENCODE BUFFER::= 000021B6060008914A0004000AAA64FDEC3D2800B500001240013C05010000
.Aug 29 11:10:01.077 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 10
.Aug 29 11:10:01.077 BUE: H245 MSC INCOMING ENCODE BUFFER::= 0200020600088175000A
.Aug 29 11:10:01.077 BUE: H245 MSC INCOMING PDU ::=
      sequenceNumber 2
.Aug 29 11:10:01.077 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:10:01.077 BUE: h245_decode_cap: Term has no caps at all
.Aug 29 11:10:01.077 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:10:01.077 BUE: H245 MSC OUTGOING PDU ::=
      forwardLogicalChannelNumber 4
      source user : NULL
.Aug 29 11:10:01.077 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 0400000300
      sequenceNumber 2
.Aug 29 11:10:01.077 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 218002
.Aug 29 11:10:01.077 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 5
.Aug 29 11:10:01.077 BUE: H245 MSC INCOMING ENCODE BUFFER::= 0400000000
      source user : NULL
.Aug 29 11:10:01.077 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 23800000
.Aug 29 11:10:01.097 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 4
.Aug 29 11:10:01.097 BUE: H245 MSC INCOMING ENCODE BUFFER::= 23800003
.Aug 29 11:10:01.097 BUE: H245 MSC INCOMING PDU ::=
.Aug 29 11:10:01.097 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:10:01.097 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:10:01.125 BUE: H225.0 INCOMING ENCODE BUFFER::= 28501900060008914A00050004C06257F11A11E1BC62EFE54CDE46FF10800100
.Aug 29 11:10:01.125 BUE: H225.0 INCOMING PDU ::=
      h323-uu-pdu
        h323-message-body notify :
          callIdentifier
            guid '04C06257F11A11E1BC62EFE54CDE46FF'H
        h245Tunneling FALSE
.Aug 29 11:10:01.125 BUE: //21387/04C062578D9B/VTSP:(0/1/0:15):1:1:7/vtsp_process_event:
   [state:S_CONNECT, event:E_CC_SERVICE_MSG]
.Aug 29 11:10:01.125 BUE: //21387/04C062578D9B/VTSP:(0/1/0:15):1:1:7/act_service_msg_down:
.Aug 29 11:10:01.125 BUE: //21387/04C062578D9B/VTSP:(0/1/0:15):1:1:7/vtsp_timer_stop:
   Timer Stop Time=42709723
.Aug 29 11:10:01.145 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 90
.Aug 29 11:10:01.145 BUE: H245 MSC INCOMING ENCODE BUFFER::= 0270030600088175000A801780003C000100000100000100000EC0031000400100010004800000860A0000070008824301030180000120C01D80000285014080000385011080002B85015000800002000001010002000300002B
.Aug 29 11:10:01.145 BUE: H245 MSC INCOMING PDU ::=
      sequenceNumber 3
        mcCapability
        transportCapability
          mediaChannelCapabilities
              mediaTransport ip-UDP : NULL
      capabilityTable
          capability receiveAudioCapability : g711Ulaw64k : 30
.Aug 29 11:10:01.149 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:10:01.149 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:10:01.149 BUE: H245 MSC OUTGOING PDU ::=
      sequenceNumber 3
.Aug 29 11:10:01.149 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 218003
      sequenceNumber 2
        mcCapability
      capabilityTable
              t38FaxProfile
                version 0
                t38FaxUdpOptions
                  t38FaxMaxBuffer 200
            maxBitRate 144
          capabilityTableEntryNumber 27
          capability receiveUserInputCapability : basicString : NULL
              32,
              3,
              4,
              5,
              6,
              13,
              14
              27
.Aug 29 11:10:01.153 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 027002060008817500078013800014000100000100000100000CC0010001000780001F4A0812860100807C0100014008C00200C802014040009080001A83011080000522C00180000422800180000C2400010180000D2408010180000220C0138000032040130080010106001F0002000300040005000C000D00001A
.Aug 29 11:10:01.153 BUE: H245 MSC OUTGOING PDU ::=
      terminalType 60
      statusDeterminationNumber 3061
.Aug 29 11:10:01.153 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 01003C400BF5
.Aug 29 11:10:01.165 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 7
.Aug 29 11:10:01.165 BUE: H245 MSC INCOMING ENCODE BUFFER::= 01003280738384
.Aug 29 11:10:01.165 BUE: H245 MSC INCOMING PDU ::=
      terminalType 50
      statusDeterminationNumber 7570308
.Aug 29 11:10:01.165 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:10:01.165 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:10:01.165 BUE: H245 MSC OUTGOING PDU ::=
.Aug 29 11:10:01.165 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 20A0
.Aug 29 11:10:01.165 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 3
.Aug 29 11:10:01.165 BUE: H245 MSC INCOMING ENCODE BUFFER::= 218002
      sequenceNumber 2
.Aug 29 11:10:01.165 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 2
.Aug 29 11:10:01.165 BUE: H245 MSC INCOMING ENCODE BUFFER::= 2080
      forwardLogicalChannelNumber 5
          sessionID 1
            network '0AAA64FD'H
            tsapIdentifier 31389
.Aug 29 11:10:01.165 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 030000040C6013800B050001000AAA64FD7A9D00
.Aug 29 11:10:01.169 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 20
.Aug 29 11:10:01.169 BUE: H245 MSC INCOMING ENCODE BUFFER::= 030000010C6013800B050001000A0E640A0FA100
.Aug 29 11:10:01.169 BUE: H245 MSC INCOMING PDU ::=
      forwardLogicalChannelNumber 2
          sessionID 1
            network '0A0E640A'H
            tsapIdentifier 4001
.Aug 29 11:10:01.173 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:10:01.173 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:10:01.173 BUE: H245 MSC OUTGOING PDU ::=
          network '0AAA64FD'H
          tsapIdentifier 31388
          network '0AAA64FD'H
.Aug 29 11:10:01.173 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 22C000010680134C000AAA64FD7A9C000AAA64FD7A9D03000100
.Aug 29 11:10:01.173 BUE: //21387/04C062578D9B/VTSP:(0/1/0:15):1:1:7/vtsp_process_event:
   [state:S_CONNECT, event:E_CC_CAPS_IND]
.Aug 29 11:10:01.173 BUE: //21387/04C062578D9B/VTSP:(0/1/0:15):1:1:7/vtsp_dsm_peer_event_cb:
.Aug 29 11:10:01.173 BUE: //21387/04C062578D9B/VTSP:(0/1/0:15):1:1:7/vtsp_dsm_feature_notify_cb:
.Aug 29 11:10:01.173 BUE: //21387/04C062578D9B/VTSP:(0/1/0:15):1:1:7/vtsp_dsm_reactivate_ringback:
.Aug 29 11:10:01.173 BUE: //21387/04C062578D9B/VTSP:(0/1/0:15):1:1:7/vtsp_dsm_reactivate_ringback:exit@1268
.Aug 29 11:10:01.217 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 23
.Aug 29 11:10:01.217 BUE: H245 MSC INCOMING ENCODE BUFFER::= 22C000040480101C00000AAA640B6898000AAA640B6899
.Aug 29 11:10:01.217 BUE: H245 MSC INCOMING PDU ::=
        sessionID 1
          network '0AAA640B'H
          tsapIdentifier 26776
          network '0AAA640B'H
          tsapIdentifier 26777
.Aug 29 11:10:01.217 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:10:01.217 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:10:03.917 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_process_event:
   [state:S_SETUP_REQ_PROC, event:E_TSP_DISCONNECT_PI_IND]
.Aug 29 11:10:03.917 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/act_setup_pend_disc_pi_ind:
   Progress Indication=8, Cause Value=17, Convert To Disconnect Without PI=FALSE
.Aug 29 11:10:03.917 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_ring_noan_timer_stop:
   Timer Stop Time=42710002
.Aug 29 11:10:03.917 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_set_release_source:
   Release Direction=PSTN, Release Source=Called Party-PSTN
.Aug 29 11:10:04.993 BUE: RAS OUTGOING PDU ::=
      requestSeqNum 8631
        ip '0AAA64FD'H
        port 60477
      endpointType
        vendor
          vendor
            t35CountryCode 181
            t35Extension 0
            manufacturerCode 18
        gateway
          protocol
            voice :
              supportedPrefixes
        mc FALSE
        undefinedNode FALSE
.Aug 29 11:10:04.993 BUE: RAS OUTGOING ENCODE BUFFER::= 000021B6060008914A0004000AAA64FDEC3D2800B500001240013C05010000
.Aug 29 11:10:05.441 BUE: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:293269365 1500 bytes is out-of-order; expected seq:293238957. Reason: TCP reassembly queue overflow - session 10.170.0.250:60502 to 190.221.162.12:80
.Aug 29 11:10:06.345 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 5
.Aug 29 11:10:06.345 BUE: H245 MSC INCOMING ENCODE BUFFER::= 0400000000
.Aug 29 11:10:06.345 BUE: H245 MSC INCOMING PDU ::=
      source user : NULL
.Aug 29 11:10:06.345 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:10:06.345 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:10:06.345 BUE: H245 MSC OUTGOING PDU ::=
.Aug 29 11:10:06.345 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 23800000
.Aug 29 11:10:06.353 BUE: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 2
.Aug 29 11:10:06.353 BUE: H245 MSC INCOMING ENCODE BUFFER::= 4A40
.Aug 29 11:10:06.353 BUE: H245 MSC INCOMING PDU ::=
.Aug 29 11:10:06.353 BUE: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
.Aug 29 11:10:06.353 BUE: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
.Aug 29 11:10:06.353 BUE: H245 MSC OUTGOING PDU ::=
.Aug 29 11:10:06.353 BUE: H245 MSC OUTGOING ENCODE BUFFER::= 4A40
.Aug 29 11:10:06.373 BUE: H225.0 INCOMING ENCODE BUFFER::= 2580060008914A00051100110080179034B422E103282375010AAA64FA10800100
.Aug 29 11:10:06.373 BUE: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
.Aug 29 11:10:06.373 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_dsm_bridge_status_cb:
.Aug 29 11:10:06.377 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_process_event:
   [state:S_SETUP_REQ_PROC, event:E_CC_DISCONNECT]
.Aug 29 11:10:06.377 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/act_disconnect:
   Cause Value=17
.Aug 29 11:10:06.377 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_ring_noan_timer_stop:
   Timer Stop Time=42710248
   [Busy]-Tone Played In Direction [Network]
.Aug 29 11:10:06.385 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_dsm_get_levels_done_cb:
.Aug 29 11:10:06.385 BUE: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
.Aug 29 11:10:06.385 BUE: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A00041100110080179034B422E103282375010AAA64FA10800100
.Aug 29 11:10:06.393 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_process_event:
.Aug 29 11:10:06.397 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/act_dsm_dsp_stats_complete:
.Aug 29 11:10:06.397 BUE: //21392/801790342823/VTSP:(0/1/0:15):21:1:9/vtsp_timer:
