Inbound Call not Working
Leonardo Santana
My client is not able to receive inbound calls.
At the logs i see this messages:
%VOICE_IEC-3-GW: H323: Internal Error (OLC ACK T103 timeout): IEC=1.1.183.5.70.0 on callID 1049 GUID=9E30499FED2711E68725C44860A6B7E8
*Feb 8 11:22:03.253: %VOICE_IEC-3-GW: H323: Internal Error (OLC ACK T103 timeout): IEC=1.1.183.5.70.0 on callID 1050 GUID=9E30499FED2711E68725C44860A6B7E8
*Feb 8 11:28:05.693: %VOICE_IEC-3-GW: H323: Internal Error (OLC ACK T103 timeout): IEC=1.1.183.5.70.0 on callID 1054
E1 R2
controller E1 0/1/0
framing NO-CRC4
clock source line primary
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
country brazil
metering
seizure-ack-time 20
category 2
answer-signal group-b 1
E1 0/1/0 is up.
Applique type is Channelized E1 - balanced
Cablelength is Unknown
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20090408, FPGA: 13, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line Primary.
Data in current interval (174 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
This a remote site, we have two CUCM servers at the HQ
CUCM Version:
System version: 8.0.3.22900-5
From the debug ccapi inout we receive the disconnect cause 41.
What could be?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
5 Replies 5
sanjaydevan
Can you paste your dial-peer configs?
regards
Devan
Did you figure out what was wrong? We are having the same issue.
Matt
Add debug isdn q931 to post plz
Please remember to rate useful posts, by clicking on the stars below.
avelino01
Did you figure out what was wrong? I am having the same issue.
Thank you in advance
Avelino
I would suggest that you post a new question in the forum with the specifics about your problem (description, configs, etc.) rather than responding here.
Maren
