Good day!!
I have a doubt, I have one CME with FXO port and a few SIP phones (5), I'm trying to get inbound calls to reach one specific extension, for instance 1001 (receptionist).
When I dial to PSTN calls go outside without issues, perfect sound, no echo, everything works great.
The problem is when I try to get incoming calls to the fxo port to reach receptionist extension (1001) which is a SIP phone 7821 series.
My inbound config is as follows:
dial-peer voice 1 pots
translation-profile incoming Incoming_PSTN
incoming called-number 9010101 (example)
direct-inward-dial
port 0/2/0
Call is well received by the Router but can not find any method to route the call directly to the receptionist phone.
I really appreciate your help as no config had work for me. (I have tried answer-address also)
Thanks !!!
