05-27-2014 12:48 PM - edited 03-16-2019 10:54 PM
Hello, I am receiving complaints that people outside the U.S. are dialing our number and are then prompted with a second dial tone. They then re-dial the number and it will ring through to our phones. My question is where is this secondary dial tone coming from? Thanks for your help!
Solved! Go to Solution.
05-27-2014 02:05 PM
Add "direct-inward-dial" on your inbound POTS dialpeer.
Example:
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
05-27-2014 01:51 PM
Look at your call flow to determine where it might be coming from.
No way to tell without more info, that's why you need to look at how the call flow is handled in your environment.
05-27-2014 02:05 PM
Example:
direct-inward-dial
05-28-2014 08:03 AM
Hi, this come from the gateway which is set to run a two stage call, if you want to be in one stage with on dial tone configure DID.
