04-11-2018 06:43 AM - edited 03-17-2019 12:36 PM
I'm experiencing an issue on a 2911 running IOS 15.7(3)M2.
I have Multi VRF set up with provider facing interfaces in a separate VRF, a physical connection and a loopback used for signalling. I have the CUCM facing side in the global VRF. My dial-peers facing the provider have sip media and control bound at the dial-peer specifying the loopback interface I'm using for signaling. The CUCM facing dial has the interface in the global VRF specified. I am using server groups for both provider UBE and my CUCM cluster.
Outbound calls work fine; audio works both ways. The issue is inbound. When a call is received at my CUBE, the call goes through, but the calling phone audio is not transmitted to the receiving phone.
I ran "debug voice rtp error" and found this:
002289: *Apr 11 2018 07:54:34.738 CDT: voip_rtp_recv_fs_input:pak punted, vrf_tableid(0)
I assume this is why inbound audio isn't being passed.
I do not experiencing this issue on a 4321 running 16.06.02.
Any help is greatly appreciated.
04-11-2018 08:53 AM
04-11-2018 09:20 AM
Thank you for your response.
I do have "voice-class sip bind media source-interface Loopback100" and "voice-class sip bind control source-interface Loopback100" on the provider facing dial-peers. I have "voice-class sip bind control source-interface Port-channel3" and "voice-class sip bind media source-interface Port-channel3" on the CUCM dial-peers. Loopback100 is in the outside VRF.
The networks in the server-groups are reachable via the interfaces that are sip bind at the dial-peer.
When I say outbound, I mean a call placed from my network to a test cell phone. Those calls work fine.
When I call in from that cell phone, the call connects, but I get one-way audio (in this case: cell phone speaks - phone on my network doesn't hear). So I assume I have my bindings set correctly.
Doing debugs I noticed that the above error is output during a call made from outside to my network.
04-11-2018 10:33 AM
To test, I removed the VRF. RTP is being sent.
We would like to keep the provider interfaces in the VRF.
This issue is baffling me.
I tried down grading to version 15.6(3)M4 to test, but it didn't work.
04-11-2018 11:03 AM
