Incoming call from PSTN/FXO, 4 ring only and will disconnect with pulse tone
jayceep14
Outgoing Call has no Issue,However if we call our PSTN # connected to FXO port, It will ring 4times only then disconnect then we hear a pulse tone(not a busy tone).
If we answer the call before the 4rings we can talk with no issue.
below are our test configuration,incoming call via fxo will be forwarded to dn 1001
telephony-service
max-ephones 110
max-dn 288
ip source-address 10.0.0.1 port 2000
timeouts ringing 500
load 7960-7940 P00308010200
date-format yy-mm-dd
max-conferences 8 gain -6
web admin system name admin password pass
transfer-system full-consult
create cnf-files version-stamp 7960 May 28 2018 06:39:55
ephone-dn 1 dual-line
number 1001
ephone 1
mac-address 0015.2B23.BD39
button 1:1
voice-port 0/0/0
cptone PH
connection plar opx 1001
10 Replies 10
narinder sandhu
good day my friend :)
please could you upload the debugs using:
debug ccapi inout
debug vpm
debug vtsp
I would like to understand the disconnect cause and from which direction the disconnect is initiated please highlight the start of the call in the output.
Havea great day
hi narinder,
Attactedh the debug file while doing the call from outside.
debug ccapi inout  ( debug not supported )
debug vpm
debug vtsp
btw Im using Cisco 2851 router(cme) v8.6.
basically the issue is incoming call takes 4 ring only then phone says missed call.
from the phone outside hearing different tone but not busy tone.
ah sorry my fault typo  could you try:
debug voip ccapi inout
debug vtsp
debug vpm
thanks
attached the output of debug voip ccapi inout
thankyou could you you run all 3 commands at the same time and re run the test,
also I would like to know are you running ground start or loop start signaling to the PSTN.
please send me full show run output.
Many thanks
I tried ground start but does not fix.
see attached show run
That's a disconnect from us to the Telco -
Jun 1 08:21:21.770: htsp_process_event: [0/0/0, FXOLS_PROCEEDING, E_HTSP_EVENT_TIMER]fxols_disc_confirm
Interesting enough that the call disconnected with CV=16 but I do not see any cut through. Reproduce the issue with only the following enabled -
debug voip vtsp all
debug vpm signal
Run all of them at the same time before making a test call.
hi nipun only a thought but wouldn't a cuthrough require a handset to be lifted , the issue is the call is disconnecting after 4 rings we are not setting up a audio stream.
Correct. A CV=16 is rare to be seen without the call being actually connected and being disconnected prematurely, hence I mentioned that even though the CV=16 is being seen, the call never connects and there is no cut through.
just looking at this the call disconnect looks like a clean teardown,
Jun  1 08:21:21.778: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 9341250264AB11E880F6AD3520749D3F, SetupTime 08:21:10.748 UTC Fri Jun 1 2018, PeerAddress , PeerSubAddress , DisconnectCause 10  , DisconnectText normal call clearing (16), ConnectTime 08:21:21.768 UTC Fri Jun 1 2018, DisconnectTime 08:21:21.768 UTC Fri Jun 1 2018, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Jun  1 08:21:21.778: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:06/01/2018 08:21:10.750,cgn:,cdn:1001,frs:0,fid:103,fcid:9341250264AB11E880F6AD3520749D3F,legID:5F,bguid:9341250264AB11E880F6AD3520749D3F
please enter all these debugs at the same time and run the test again and send me the output.
debug voip dialpeer
debug vtsp
debug vpm
also could you try resetting the phone please.
