Incoming call not landing on IP phones using CUCM
Mayank Nauni
Hi all,
I am facing an issue; the incoming calls are not landing on the IP phones using the CUCM, below is the debug for the same and it shows the cause as Unallocation/Unassigned number.
I checked the config of Gateway, route pattern, partitions and CSS but seems to be ok.
.Jan  3 17:01:44.977: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=93 nr=117
.Jan  3 17:01:44.977: ISDN Se0/0/0:15 Q931: SETUP pd = 8  callref = 0x017B
         Sending Complete
         Bearer Capability i = 0x8090A3
                 Standard = CCITT
                 Transfer Capability = Speech
                 Transfer Mode = Circuit
                 Transfer Rate = 64 kbit/s
         Channel ID i = 0xA98381
                 Exclusive, Channel 1
         Calling Party Number i = 0x0083, '0162508156'
                 Plan:Unknown, Type:Unknown
         Called Party Number i = 0x81, '1065'
                 Plan:ISDN, Type:Unknown
.Jan  3 17:01:44.981: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=94
.Jan  3 17:01:44.981: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x817B callID = 0x00F5 switch = primary-net5 interface = User
.Jan  3 17:01:44.985: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=117 nr=94
.Jan  3 17:01:44.985: ISDN Se0/0/0:15 Q931: CALL_PROC pd = 8  callref = 0x817B
.Jan  3 17:01:44.985: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=118 nr=94
.Jan  3 17:01:44.985: ISDN Se0/0/0:15 Q931: DISCONNECT pd = 8  callref = 0x817B
         Cause i = 0x8081 - Unallocated/unassigned number
.Jan  3 17:01:44.993: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=118
.Jan  3 17:01:44.997: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=119
.Jan  3 17:01:45.037: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=94 nr=119
.Jan  3 17:01:45.037: ISDN Se0/0/0:15 Q931: RELEASE pd = 8  callref = 0x017B
.Jan  3 17:01:45.037: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=95
Any suggestions?
Mayank
-Regards,
Mayank Nauni
CCIE#48541
Cisco Champion 2019
34 Replies 34
Gajanan Pande
Mayank,
Is it a new config or old config ?
If it was working before & not working now, check if the incoming dial-peer config is changed on gateway ?
It appears that you have DID range ( 1065 being part of it ) & the telco is just sending last 4 digits to the gateway & gateway is not able locate the number. DP config needs to be checked ?
GP.
Hi Mr. Pande,
It is a new config and it never worked.  Let me check the same with the telco and will also copy the dial peer config  here for more suggestions around it.
Mayank
-Regards,
Mayank Nauni
CCIE#48541
Cisco Champion 2019
If you took DID range, then I dont see any issue at Telco side, they are sending digits as they should.
GP.
Yes you are right.. even I dont see an issue with the telco end.
-Regards,
Mayank Nauni
CCIE#48541
Cisco Champion 2019
Gajanan Pande
Forgot to ask, what type of gateway protocol is being used ? My above explaination holds good for H.323.
GP.
Hi Mr. Pandey,
The gateway is H.323
Mayank
-Regards,
Mayank Nauni
CCIE#48541
Cisco Champion 2019
Cool. Let us know the dial-peer config.
GP.
posting it in another 3 - 4 minutes... thanks for the help
-Regards,
Mayank Nauni
CCIE#48541
Cisco Champion 2019
config attached for your reference.
-Regards,
Mayank Nauni
CCIE#48541
Cisco Champion 2019
I'll be travelling, would respond after couple of hours. Others might also help you here.
GP.
thanks again for your help.
-Regards,
Mayank Nauni
CCIE#48541
Cisco Champion 2019
An important VOIP dial-peer is missing from the config or you can modify the existing VOIP dial-peer as below..
dial-peer voice x voip     ------------------> x is just the dial-peer Tag e.g. 1,2, 3 etc...
destination-pattern 1... ------------------> This is to represent your DID range.
session target ipv4:10.3.3.11 --------------------> This is your callmanager
voice-class codec 100
dtmf-relay h245-alphanumeric
no vad
If you let me know your DID range, I can get back with precise config.
GP.
thanks ... I will share the DID range shortly with you
-Regards,
Mayank Nauni
CCIE#48541
Cisco Champion 2019
The required information is as under :-
The ISDN onramp has 600 DIDs allocated. The allocation is +60 3 2773 1000 to 1599. Number for external extension is 8.
-Regards,
Mayank Nauni
CCIE#48541
Cisco Champion 2019
