01-03-2012 02:06 AM - edited 03-16-2019 08:47 AM
Hi all,
I am facing an issue; the incoming calls are not landing on the IP phones using the CUCM, below is the debug for the same and it shows the cause as Unallocation/Unassigned number.
I checked the config of Gateway, route pattern, partitions and CSS but seems to be ok.
.Jan 3 17:01:44.977: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=93 nr=117
.Jan 3 17:01:44.977: ISDN Se0/0/0:15 Q931: SETUP pd = 8 callref = 0x017B
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x0083, '0162508156'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x81, '1065'
Plan:ISDN, Type:Unknown
.Jan 3 17:01:44.981: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=94
.Jan 3 17:01:44.981: ISDN Se0/0/0:15 Q931: Received SETUP callref = 0x817B callID = 0x00F5 switch = primary-net5 interface = User
.Jan 3 17:01:44.985: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=117 nr=94
.Jan 3 17:01:44.985: ISDN Se0/0/0:15 Q931: CALL_PROC pd = 8 callref = 0x817B
.Jan 3 17:01:44.985: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=118 nr=94
.Jan 3 17:01:44.985: ISDN Se0/0/0:15 Q931: DISCONNECT pd = 8 callref = 0x817B
Cause i = 0x8081 - Unallocated/unassigned number
.Jan 3 17:01:44.993: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=118
.Jan 3 17:01:44.997: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=119
.Jan 3 17:01:45.037: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=94 nr=119
.Jan 3 17:01:45.037: ISDN Se0/0/0:15 Q931: RELEASE pd = 8 callref = 0x017B
.Jan 3 17:01:45.037: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=95
Any suggestions?
Mayank
01-03-2012 11:25 PM
I have modified the existing VOIP dial-peer as suggested but the issue still persists
01-03-2012 11:34 PM
How does the new dial-peer config looks now ? Pls post only that dial-peer config.
What is the DN range assigned to your phones ? If you have DID range 1000 to 1599, you should either have the same DN range or have a translation pattern to convert those DIDs to your DN range. Pls confirm if such config is in place in your CUCM.
GP.
01-03-2012 11:51 PM
Please find the responses below :-
dial-peer voice 2 voip
preference 2
destination-pattern 1...
session target ipv4:10.3.3.11
incoming called-number .T
voice-class codec 100
dtmf-relay h245-alphanumeric
no vad
I will be attaching the translation pattern shortly.
01-04-2012 12:05 AM
also try removing " incoming called-number .T " from the DP. This will also work only if you have proper DN range or Translation pattern configured in CUCM
GP.
01-03-2012 11:34 PM
If there are multiple interfaces on the gateway, can you check whether you added a bind command for the interface (ip address) that is configured as the h.323 gateway in call manager?
Gateway(config-if)#h323-gateway voip bind srcaddr X.X.X.X
01-03-2012 11:53 PM
Hi Baris,
It is already done... thanks for highlighting.
Please also let us know what would be the CSS on gateway for called and calling party, same as phones or something different?
Mayank
01-04-2012 12:02 AM
CSS can be different, just ensure that the partitions in which your phones are, shd be included in gateway's CSS. Same to be done for phone CSS too ( include gateway partitions ). You can play with partitions & CSS.
GP.
01-03-2012 11:59 PM
One quick query ....
If my interface's IP address is 192.168.1.1 which is the gateway ... will that be the srcaddr in the suggested command below?
01-04-2012 12:00 AM
correct.
01-04-2012 12:47 AM
"also try removing " incoming called-number .T " from the DP. This will also work only if you have proper DN range or Translation pattern configured in CUCM"
Did the same... no improvements!
01-04-2012 01:50 AM
As I said, it will work only if you have the DID range as extension numbers ( DN ) or there is a proper translation pattern in place to translate your DID range to DN range. I dont see any details from you on this point.
GP.
01-04-2012 07:01 PM
Hi Mr. Pande,
The translation pattern is displayed in the *.doc attachement above, is this what you are looking for?
Regars,
Mayank Nauni
01-04-2012 08:26 PM
Hi Mayank,
What is your DN range ?
I see a Translation pattern for 1xxx, which translates to a big number, are you using E.164 DN plan ?
GP.
01-04-2012 09:34 PM
DID range is 327731000 to 327731599 and we have given 4 digit DN to IP phones e.g 10000, 1001, 1002.
"I see a Translation pattern for 1xxx, which translates to a big number, are you using E.164 DN plan ?"
I am not sure about it ... can you suggest me how to find it out?
01-05-2012 01:06 AM
Remove your translation pattern " 1xxx " from CUCM & it should fix it.
GP.
