Incoming call not landing on IP phones using CUCM
Mayank Nauni
Hi all,
I am facing an issue; the incoming calls are not landing on the IP phones using the CUCM, below is the debug for the same and it shows the cause as Unallocation/Unassigned number.
I checked the config of Gateway, route pattern, partitions and CSS but seems to be ok.
.Jan  3 17:01:44.977: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=93 nr=117
.Jan  3 17:01:44.977: ISDN Se0/0/0:15 Q931: SETUP pd = 8  callref = 0x017B
         Sending Complete
         Bearer Capability i = 0x8090A3
                 Standard = CCITT
                 Transfer Capability = Speech
                 Transfer Mode = Circuit
                 Transfer Rate = 64 kbit/s
         Channel ID i = 0xA98381
                 Exclusive, Channel 1
         Calling Party Number i = 0x0083, '0162508156'
                 Plan:Unknown, Type:Unknown
         Called Party Number i = 0x81, '1065'
                 Plan:ISDN, Type:Unknown
.Jan  3 17:01:44.981: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=94
.Jan  3 17:01:44.981: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x817B callID = 0x00F5 switch = primary-net5 interface = User
.Jan  3 17:01:44.985: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=117 nr=94
.Jan  3 17:01:44.985: ISDN Se0/0/0:15 Q931: CALL_PROC pd = 8  callref = 0x817B
.Jan  3 17:01:44.985: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=118 nr=94
.Jan  3 17:01:44.985: ISDN Se0/0/0:15 Q931: DISCONNECT pd = 8  callref = 0x817B
         Cause i = 0x8081 - Unallocated/unassigned number
.Jan  3 17:01:44.993: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=118
.Jan  3 17:01:44.997: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=119
.Jan  3 17:01:45.037: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=94 nr=119
.Jan  3 17:01:45.037: ISDN Se0/0/0:15 Q931: RELEASE pd = 8  callref = 0x017B
.Jan  3 17:01:45.037: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=95
Any suggestions?
Mayank
-Regards,
Mayank Nauni
CCIE#48541
Cisco Champion 2019
34 Replies 34
I have modified the existing VOIP dial-peer as suggested but the issue still persists
-Regards,
Mayank Nauni
CCIE#48541
Cisco Champion 2019
How does the new dial-peer config looks now ? Pls post only that dial-peer config.
What is the DN range assigned to your phones ? If you have DID range 1000 to 1599, you should either have the same DN range or have a translation pattern to convert those DIDs to your DN range. Pls confirm if such config is in place in your CUCM.
GP.
Please find the responses below :-
dial-peer voice 2 voip
preference 2
destination-pattern 1...
session target ipv4:10.3.3.11
incoming called-number .T
voice-class codec 100
dtmf-relay h245-alphanumeric
no vad
I will be attaching the translation pattern shortly.
-Regards,
Mayank Nauni
CCIE#48541
Cisco Champion 2019
also try removing " incoming called-number .T " from the DP. This will also work only if you have proper DN range or Translation pattern configured in CUCM
GP.
If there are multiple interfaces on the gateway, can you check whether you added a bind command for the interface (ip address) that is configured as the h.323 gateway in call manager?
Gateway(config-if)#h323-gateway voip bind srcaddr X.X.X.X
Hi Baris,
It is already done... thanks for highlighting.
Please also let us know what would be the CSS on gateway for called and calling party, same as phones or something different?
Mayank
-Regards,
Mayank Nauni
CCIE#48541
Cisco Champion 2019
CSS can be different, just ensure that the partitions in which your phones are, shd be included in gateway's CSS. Same to be done for phone CSS too ( include gateway partitions ). You can play with partitions & CSS.
GP.
One quick query ....
If my interface's IP address is 192.168.1.1 which is the gateway ... will that be the srcaddr in the suggested command below?
-Regards,
Mayank Nauni
CCIE#48541
Cisco Champion 2019
correct.
"also try removing " incoming called-number .T " from the DP. This will also work only if you have proper DN range or Translation pattern configured in CUCM"
Did the same... no improvements!
-Regards,
Mayank Nauni
CCIE#48541
Cisco Champion 2019
As I said, it will work only if you have the DID range as extension numbers ( DN ) or there is a proper translation pattern in place to translate your DID range to DN range. I dont see any details from you on this point.
GP.
Hi Mr. Pande,
The translation pattern is displayed in the *.doc attachement above, is this what you are looking for?
Regars,
Mayank Nauni
-Regards,
Mayank Nauni
CCIE#48541
Cisco Champion 2019
Hi Mayank,
What is your DN range ?
I see a Translation pattern for 1xxx, which translates to a big number, are you using E.164 DN plan ?
GP.
DID range is 327731000 to 327731599 and we have given 4 digit DN to IP phones e.g 10000, 1001, 1002.
"I see a Translation pattern for 1xxx, which translates to a big number, are you using E.164 DN plan ?"
I am not sure about it ... can you suggest me how to find it out?
-Regards,
Mayank Nauni
CCIE#48541
Cisco Champion 2019
Remove your translation pattern " 1xxx " from CUCM & it should fix it.
GP.
