ā01-03-2012 02:06 AM - edited ā03-16-2019 08:47 AM
Hi all,
I am facing an issue; the incoming calls are not landing on the IP phones using the CUCM, below is the debug for the same and it shows the cause as Unallocation/Unassigned number.
I checked the config of Gateway, route pattern, partitions and CSS but seems to be ok.
.Jan 3 17:01:44.977: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=93 nr=117
.Jan 3 17:01:44.977: ISDN Se0/0/0:15 Q931: SETUP pd = 8 callref = 0x017B
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x0083, '0162508156'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x81, '1065'
Plan:ISDN, Type:Unknown
.Jan 3 17:01:44.981: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=94
.Jan 3 17:01:44.981: ISDN Se0/0/0:15 Q931: Received SETUP callref = 0x817B callID = 0x00F5 switch = primary-net5 interface = User
.Jan 3 17:01:44.985: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=117 nr=94
.Jan 3 17:01:44.985: ISDN Se0/0/0:15 Q931: CALL_PROC pd = 8 callref = 0x817B
.Jan 3 17:01:44.985: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=118 nr=94
.Jan 3 17:01:44.985: ISDN Se0/0/0:15 Q931: DISCONNECT pd = 8 callref = 0x817B
Cause i = 0x8081 - Unallocated/unassigned number
.Jan 3 17:01:44.993: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=118
.Jan 3 17:01:44.997: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=119
.Jan 3 17:01:45.037: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=94 nr=119
.Jan 3 17:01:45.037: ISDN Se0/0/0:15 Q931: RELEASE pd = 8 callref = 0x017B
.Jan 3 17:01:45.037: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=95
Any suggestions?
Mayank
ā01-03-2012 11:25 PM
I have modified the existing VOIP dial-peer as suggested but the issue still persists
ā01-03-2012 11:34 PM
How does the new dial-peer config looks now ? Pls post only that dial-peer config.
What is the DN range assigned to your phones ? If you have DID range 1000 to 1599, you should either have the same DN range or have a translation pattern to convert those DIDs to your DN range. Pls confirm if such config is in place in your CUCM.
GP.
ā01-03-2012 11:51 PM
Please find the responses below :-
dial-peer voice 2 voip
preference 2
destination-pattern 1...
session target ipv4:10.3.3.11
incoming called-number .T
voice-class codec 100
dtmf-relay h245-alphanumeric
no vad
I will be attaching the translation pattern shortly.
ā01-04-2012 12:05 AM
also try removing " incoming called-number .T " from the DP. This will also work only if you have proper DN range or Translation pattern configured in CUCM
GP.
If there are multiple interfaces on the gateway, can you check whether you added a bind command for the interface (ip address) that is configured as the h.323 gateway in call manager?
Gateway(config-if)#h323-gateway voip bind srcaddr X.X.X.X
ā01-03-2012 11:53 PM
Hi Baris,
It is already done... thanks for highlighting.
Please also let us know what would be the CSS on gateway for called and calling party, same as phones or something different?
Mayank
ā01-04-2012 12:02 AM
CSS can be different, just ensure that the partitions in which your phones are, shd be included in gateway's CSS. Same to be done for phone CSS too ( include gateway partitions ). You can play with partitions & CSS.
GP.
ā01-03-2012 11:59 PM
One quick query ....
If my interface's IP address is 192.168.1.1 which is the gateway ... will that be the srcaddr in the suggested command below?
ā01-04-2012 12:00 AM
correct.
ā01-04-2012 12:47 AM
"also try removing " incoming called-number .T " from the DP. This will also work only if you have proper DN range or Translation pattern configured in CUCM"
Did the same... no improvements!
ā01-04-2012 01:50 AM
As I said, it will work only if you have the DID range as extension numbers ( DN ) or there is a proper translation pattern in place to translate your DID range to DN range. I dont see any details from you on this point.
GP.
ā01-04-2012 07:01 PM
Hi Mr. Pande,
The translation pattern is displayed in the *.doc attachement above, is this what you are looking for?
Regars,
Mayank Nauni
ā01-04-2012 08:26 PM
Hi Mayank,
What is your DN range ?
I see a Translation pattern for 1xxx, which translates to a big number, are you using E.164 DN plan ?
GP.
ā01-04-2012 09:34 PM
DID range is 327731000 to 327731599 and we have given 4 digit DN to IP phones e.g 10000, 1001, 1002.
"I see a Translation pattern for 1xxx, which translates to a big number, are you using E.164 DN plan ?"
I am not sure about it ... can you suggest me how to find it out?
ā01-05-2012 01:06 AM
Remove your translation pattern " 1xxx " from CUCM & it should fix it.
GP.
