Incoming call not working h323 / CUCM 12.x
goldnetps
Hi team,
I was working for some hours to troubleshoot incoming calls not working and outgoing calls PSTN (one side can't hear a thing)
Sympton is:
Call from external numbel > extension attends > external keeps calling > call dropped
I've checked ccapi inout logs and RTMT collect but no success finding the problem yet.
I se a disconnect cause 16 - Normal call clearing, and on router debugs I see "Transfer number is null".
The call flow is:
External phone >  PSTN > h.323 > CUCM > Extension
Dial-peers:
Incoming dial-peer:
dial-peer voice 900 pots
description Incoming PSTN
incoming called-number .
no digit-strip
direct-inward-dial
port 0/0/0:0
Outgoing dial-peer
dial-peer voice 105 voip
description To CM Publisher
preference 1
destination-pattern 24....$
session target ipv4:10.243.70.5
voice-class codec 1
voice-class h323 1
dtmf-relay h245-signal
no vad
I'm going to attach the collected logs and running config
Does it happen for all calls or just for some extensions?
Please
Let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
