Long delay before the first ring with ISR 4321
MedTiti92
Hi Guys,
I have Cisco ISR 4321 manage voip in my company. the issue is : When I want to call another IP phone in the building of my company(internal), the ring is ok, but when I want to call a local number or a mobile, it takes 50 seconds to have the first ring.. it is so long. Please help
12 Replies 12
b.winter
High T302 Timer in CUCM?
Overlapping Dial-patterns in CUCM?
Rerouting of the call? SIP session problems, e.g. provider is not responding to the invite messages? What does the CUBE logs say?
There are a lot of old posts with the same question, e.g.:
https://community.cisco.com/t5/unified-communications-infrastructure/super-long-delay-in-some-outbound-calls/td-p/4461736
https://community.cisco.com/t5/other-collaboration-subjects/long-delay-after-dialing-the-number-before-connection-is-made/td-p/54441
https://community.cisco.com/t5/telepresence-and-video-infrastructure/long-post-dial-delay/td-p/95939
When you say you have a Cisco ISR4321 are you running CME and your phones are registered to the router, or is the router a component in your CUCM cluster? How to diagnose this is very different in the two systems.
Maren
Yes i'm using CME router to my phones, i'm not using CUCM
Are you using E1ISDN Link or a SIP Trunk as TSP?
Please let us know
Carlo
Please rate all helpful posts "The more you help the more you learn"
I use SIP Trunk
under both telephony-service and voice register global configuration add timeout interdigit 10
Remember to create cnf-files for telephony-service and create profiles under voice register global.
Please send the output of a debug ccsip messages while calling out
Carlo
I did, but nothing changed. it is always 15 seconds
CME_Router(config)#telephony-service
CME_Router(config-telephony)#tim
CME_Router(config-telephony)#timeou
CME_Router(config-telephony)#timeouts inter
CME_Router(config-telephony)#timeouts interd
CME_Router(config-telephony)#timeouts interdigit ?
<2-120> seconds
CME_Router(config-telephony)#timeouts interdigit 10
CME_Router(config-telephony)#exit
CME_Router(config)#voic
CME_Router(config)#voice regis
CME_Router(config)#voice register glo
CME_Router(config)#voice register global
CME_Router(config-register-global)#time
CME_Router(config-register-global)#timeo
CME_Router(config-register-global)#timeouts inter
CME_Router(config-register-global)#timeouts interdigit 10
CME_Router(config-register-global)#end
CME_Router#wr
Can you please activate a debug ccsip message and make a call?
When you are done please post the output.
Carlo
Please see the debug ccsip messages log :
*Nov 16 08:08:14.609: //2057/0FFC1E418C0F/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:X.X.X.X:5060;Dpt=7bb8-400;Hpt=8e42_16;CxtId=3;TRC=ffffffff-ffffffff SIP/2.0
Via: SIP/2.0/UDP 197.241.16.44:5060;branch=z9hG4bK697170C
From: "Desktop-Office" <sip:+22723431664@quo.voiceft.rg>;tag=5604032-1DD9
To: <sip:88221020@X.X.X.X>;tag=f6wrdg6d
Date: Thu, 16 Nov 2023 08:07:57 GMT
Call-ID: 15F9043E-838E11EE-8C169C93-DDEE99C1@quo.voiceft.rg
User-Agent: Cisco-SIPGateway/IOS-17.6.4
Max-Forwards: 70
Route: <sip:X.X.X.X:5060;lr;Hpt=8e42_116;CxtId=3;TRC=ffffffff-ffffffff;X-HwB2bUaCookie=7653>
P-Asserted-Identity: "Desktop-Office" <sip:+22723431664@quo.voiceft.rg>
Timestamp: 1700122094
CSeq: 104 BYE
Reason: Q.850;cause=16
Session-ID: 090beb6e00105000a00024813b45dc05;remote=988981b644c25fffbf3c17d2f26feec9
Content-Length: 0
*Nov 16 08:08:14.770: //2057/0FFC1E418C0F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
From: "office"<sip:+22723431664@quo.voiceft.rg>;tag=5604032-1DD9
CSeq: 104 BYE
P-Charging-Vector: icid-value="8d69a4db02c7880fbb695c5f33f87446.3909109914.1446169.104";orig-ioi=1;term-ioi=10.224.248.109
Content-Length: 0
*Nov 16 08:08:18.389: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
PUBLISH sip:24813bb0004f@192.168.128.1 SIP/2.0
Via: SIP/2.0/UDP 192.168.128.14:5060;branch=z9hG4bK528b273e
To: <sip:24813bb0004f@192.168.128.1>
From: <sip:24813bb0004f@192.168.128.1>;tag=24813bb0004f013361f038e3-1804ad95
Call-ID: 24813bb0-004f0003-6bab4a67-33f712f6@192.168.128.14
Contact: <sip:1A970-1CEF@192.168.128.14:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-24813bb0004f>";+u.sip!devicename.ccm.cisco.com="SEP24813BB0004F";+u.sip!model.ccm.cisco.com="621"
Session-ID: 728887ed00105000a00024813bb0004f;remote=00000000000000000000000000000000
CSeq: 2 PUBLISH
User-Agent: Cisco-CP7821/14.0.1
Event: presence
SIP-If-Match: abcdefg
Expires: 2147483647
Max-Forwards: 70
Content-Length: 465
Content-Type: application/pidf+xml
Content-Disposition: session;handling=required
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<presence xmlns="urn:ietf:params:xml:ns:pidf" xmlns:dm="urn:ietf:params:xml:ns:pidf:data-model" xmlns:e="urn:ietf:params:xml:ns:pidf:status:rpid" xmlns:ce="urn:cisco:params:xml:ns:pidf:rpid" xmlns:sc="urn:ietf:params:xml:ns:pidf:servcaps" entity="sip:24813bb0004f">
<tuple id="1"> <status> <basic>open</basic> </status> </tuple>
<dm:person><e:activities><ce:available/></e:activities> </dm:person>
</presence>
*Nov 16 08:09:22.450: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE tel:+25321331564 SIP/2.0
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bKcw6pctya0a9955a0a0tn5yntv;Role=3;Hpt=8e42_36;TRC=ffffffff-ffffffff
Record-Route: <sip:X.X.X.X:5060;lr;Hpt=8e42_16;CxtId=4;TRC=ffffffff-ffffffff;X-HwB2bUaCookie=2167>
Call-ID: asbcecw95w9cnb5wzn676ewcmjb9j7iczj45@B.5.105.quo.voiceft.rg
From: "77022119"<sip:77022119@X.X.X.X;transport=udp;user=phone>;tag=dmyf12fk
To: <sip:+25321331564@X.X.X.X;transport=udp;user=phone>
CSeq: 1 INVITE
Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,INFO,PRACK,NOTIFY,MESSAGE,REFER,UPDATE
Contact: <sip:X.X.X.X:5060;Dpt=ea8a-200;Hpt=8e42_16;CxtId=4;TRC=ffffffff-ffffffff>
Max-Forwards: 25
Supported: timer,100rel,histinfo
Session-Expires: 1800
Min-SE: 600
P-Asserted-Identity: "77022119"<sip:77022119@X.X.X.X;transport=udp;user=phone>
P-Charging-Vector: icid-value=EF3FD01000-1116-10531707;orig-ioi=MNC001.MCC638.3GPPNETWORK.ORG;term-ioi=1
P-Early-Media: supported,gated
Content-Length: 527
Content-Type: application/sdp
v=0
o=- 20677184 20677184 IN IP4 X.X.X.Y
s=SBC call
c=IN IP4 X.X.X.Y
t=0 0
m=audio 55624 RTP/AVP 96 97 8 18 98 0 100 99
a=rtpmap:96 AMR/8000
a=fmtp:96 mode-set=0,2,4,7;mode-change-neighbor=1;mode-change-period=2
a=rtpmap:97 AMR/8000
a=fmtp:97 mode-set=7
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=rtpmap:98 telephone-event/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:100 AMR/8000
a=fmtp:100 mode-change-neighbor=1;mode-change-period=2
a=rtpmap:99 AMR/8000
a=ptime:20
a=maxptime:40
Hi ,
Thanks for the output but is not  complete. It should start with "Received:"  followed by INVITE message.
Please let me know
Carlo
Can you please
*Nov 16 08:08:14.605: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:988221020@192.168.128.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.128.15:5060;branch=z9hG4bK42568349
From: "Desktop-Office" <sip:202@192.168.128.1>;tag=24813b45dc0500c171bc5be5-203c02ba
To: <sip:988221020@192.168.128.1>;tag=56044DC-156A
Call-ID: 24813b45-dc05001e-4f28bcb3-4d2534ca@192.168.128.15
Max-Forwards: 70
Date: Thu, 16 Nov 2023 08:08:11 GMT
CSeq: 102 BYE
Content-Length: 0
*Nov 16 08:08:14.608: //2056/0FFC1E418C0F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 16 Nov 2023 08:08:14 GMT
Server: Cisco-SIPGateway/IOS-17.6.4
CSeq: 102 BYE
Session-ID: 988981b644c25fffbf3c17d2f26feec9;remote=090beb6e00105000a00024813b45dc05
Content-Length: 0
*Nov 16 08:09:22.458: //2060/48C48E188C1E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 16 Nov 2023 08:09:22 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Session-ID: 00000000000000000000000000000000;remote=f80eadcd41bb523993d92190c47b043d
Content-Length: 0
*Nov 16 08:09:22.458: //2061/48C48E188C1E/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:214@192.168.128.14:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.128.1:5060;branch=z9hG4bK698AB4
From: "77022119" <sip:77022119@192.168.128.1>;tag=5618D16-25A6
To: <sip:214@192.168.128.14>
Call-ID: 48C57854-838E11EE-8C249C93-DDEE99C1@192.168.128.1
Supported: 100rel,timer,resource-priority,replaces
Min-SE: 1800
Cisco-Guid: 1220840984-2207125998-2350816403-3723401665
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1700122162
Contact: <sip:77022119@192.168.128.1:5060>
Expires: 180
Max-Forwards: 24
P-Asserted-Identity: "77022119" <sip:77022119@192.168.128.1>
Session-ID: f80eadcd41bb523993d92190c47b043d;remote=00000000000000000000000000000000
Content-Length: 217
v=0
o=CiscoSystemsSIP-GW-UserAgent 5375 1105 IN IP4 192.168.128.1
s=SIP Call
c=IN IP4 192.168.128.1
t=0 0
m=audio 8846 RTP/AVP 0 19
a=rtpmap:19 CN/8000
a=ptime:20
*Nov 16 08:09:22.472: //2061/48C48E188C1E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Session-ID: 0b6cc99600105000a00024813bb0004f;remote=f80eadcd41bb523993d92190c47b043d
Date: Thu, 16 Nov 2023 08:09:19 GMT
CSeq: 101 INVITE
Server: Cisco-CP7821/14.0.1
Contact: <sip:1A970-1CEF@192.168.128.14:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEP24813BB0004F"
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-8.5.1
Allow-Events: kpml,dialog
Content-Length: 0
Recv-Info: conference
Recv-Info: x-cisco-conference
*Nov 16 08:09:22.476: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY tel:+25321331564 SIP/2.0
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bKcsy99vn0utc0ca9bown5bvswt;Role=3;Hpt=8e42_36;TRC=ffffffff-ffffffff;X-HwDim=4
Record-Route: <sip:X.X.X.X:5060;lr;Hpt=8e42_16;CxtId=4;TRC=ffffffff-ffffffff>
Call-ID: asbcywraidby2cc2wi2da2d1ccdbecfrae2m@10.224.248.107
To: <tel:+25321331564>
CSeq: 1 NOTIFY
Max-Forwards: 67
Supported: 100rel
Event: ua-profile
Subscription-State: active
P-Asserted-Identity: <tel:+25321331564>
P-Called-Party-ID: <tel:+25321331564>
P-Charging-Vector: icid-value=ATS9900-202311161053190025963;orig-ioi=1;icid-generated-at=quo.voiceft.rg
Content-Length: 190
Content-Type: application/simservs+xml
<?xml version="1.0"?>
<simservs>
<dial-tone-management>
<dial-tone-pattern>standard-dial-tone</dial-tone-pattern>
</dial-tone-management>
<call-waiting active="true"/>
</simservs>
*Nov 16 08:09:22.605: //2061/48C48E188C1E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:214@192.168.128.14>;tag=24813bb0004f01346f21f303-63d028a5
CSeq: 101 INVITE
Remote-Party-ID: "Desktop-Office" <sip:214@192.168.128.1>;party=called;id-type=subscriber;privacy=off;screen=yes
Content-Length: 0
*Nov 16 08:09:22.607: //2060/48C48E188C1E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:+25321331564@X.X.X.X;transport=udp;user=phone>;tag=5618DAC-172
CSeq: 1 INVITE
Require: 100rel
RSeq: 273
P-Asserted-Identity: "Desktop-Office" <sip:214@quo.voiceft.rg>
Contact: <sip:+25321331564@197.241.16.44:5060>
Content-Length: 0
*Nov 16 08:09:22.805: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
PRACK sip:+25321331564@197.241.16.44:5060 SIP/2.0
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bKv9as9co6ny9s5nyttp0wpcwtb;Role=3;Hpt=8e42_36;TRC=ffffffff-ffffffff
CSeq: 2 PRACK
Max-Forwards: 25
RAck: 273 1 INVITE
Content-Length: 0
*Nov 16 08:09:22.806: //2060/48C48E188C1E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 2 PRACK
Content-Length: 0
*Nov 16 08:09:26.133: %SYS-5-LOG_CONFIG_CHANGE: Monitor logging: level debugging, xml disabled, filtering disabled
*Nov 16 08:09:27.578: %SYS-5-CONFIG_I: Configured from console by admin on vty2 (196.201.192.2)
*Nov 16 08:09:30.150: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL tel:+25321331564 SIP/2.0
CSeq: 1 CANCEL
Max-Forwards: 25
Reason: Q.850;cause=16;text="Normal call clearing"
Content-Length: 0
*Nov 16 08:09:30.153: //2060/48C48E188C1E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 16 Nov 2023 08:09:30 GMT
CSeq: 1 CANCEL
Content-Length: 0
*Nov 16 08:09:30.153: //2061/48C48E188C1E/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:214@192.168.128.14:5060 SIP/2.0
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1700122170
Content-Length: 0
Sent:
SIP/2.0 487 Request Cancelled
CSeq: 1 INVITE
Session-ID: f80eadcd41bb523993d92190c47b043d;remote=0b6cc99600105000a00024813bb0004f
Content-Length: 0
*Nov 16 08:09:30.157: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK tel:+25321331564 SIP/2.0
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
*Nov 16 08:09:30.161: //2061/48C48E188C1E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Thu, 16 Nov 2023 08:09:26 GMT
CSeq: 101 CANCEL
Content-Length: 0
*Nov 16 08:09:30.167: //2061/48C48E188C1E/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Content-Length: 0
*Nov 16 08:09:30.168: //2061/48C48E188C1E/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:214@192.168.128.14:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Nov 16 08:09:39.912: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.128.14:5060;branch=z9hG4bK623d48bd
From: <sip:24813bb0004f@192.168.128.1>;tag=24813bb0004f0136542b8427-2642ddb5
Call-ID: 24813bb0-004f0004-2732701f-0e9336ef@192.168.128.14
CSeq: 3 PUBLISH
Event: presence
Expires: 2147483647
Max-Forwards: 70
Content-Length: 459
<dm:person><e:activities><ce:dnd/></e:activities> </dm:person>
</presence>
*Nov 16 08:09:42.009: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:192.168.128.1 SIP/2.0
Via: SIP/2.0/UDP 192.168.128.16:5060;branch=z9hG4bK7b493603
From: <sip:206@192.168.128.1>;tag=24813b45f71905d73e16b753-6c2442e3
To: <sip:206@192.168.128.1>
Call-ID: 24813b45-f7190068-7edec58d-21fd2e21@192.168.128.16
Max-Forwards: 70
Session-ID: 5caa636100105000a00024813b45f719;remote=00000000000000000000000000000000
Date: Thu, 16 Nov 2023 08:09:37 GMT
CSeq: 1403 REGISTER
Contact: <sip:1A96A-124C@192.168.128.16:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-24813b45f719>";+u.sip!devicename.ccm.cisco.com="SEP24813B45F719";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
*Nov 16 08:09:42.011: //2062/546D2D638C25/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:206@192.168.128.1>;tag=561D977-25D7
Date: Thu, 16 Nov 2023 08:09:42 GMT
CSeq: 1403 REGISTER
Supported: X-cisco-cme-sis-9.0.0
Supported: X-cisco-srtp-fallback
Contact: <sip:206@192.168.128.16:5060>;expires=600
Expires: 600
Content-Length: 0
*Nov 16 08:09:49.944: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bKusu9tbay50uv5u0soaoa5cstn;Role=3;Hpt=8e42_36;TRC=ffffffff-ffffffff
Record-Route: <sip:X.X.X.X:5060;lr;Hpt=8e42_16;CxtId=4;TRC=ffffffff-ffffffff;X-HwB2bUaCookie=1144>
Call-ID: asbc23o1d063rp5ro2455o82oxd42o13xk13@B.5.102.quo.voiceft.rg
From: "77022119"<sip:77022119@X.X.X.X;transport=udp;user=phone>;tag=y6kv6nxx
CSeq: 1 INVITE
Contact: <sip:X.X.X.X:5060;Dpt=eaca-200;Hpt=8e42_16;CxtId=4;TRC=ffffffff-ffffffff>
Max-Forwards: 65
Min-SE: 600
P-Charging-Vector: icid-value=AE0F86D3E81D8520231116105346;orig-ioi=10.224.248.109;term-ioi=1
Content-Length: 412
v=0
o=- 19826984 19826984 IN IP4 X.X.X.Y
s=SBC call
c=IN IP4 X.X.X.Y
t=0 0
m=audio 55640 RTP/AVP 108 102 8 0 4 18 116
a=rtpmap:108 AMR/8000
a=fmtp:108 mode-change-neighbor=1;mode-change-period=2
a=rtpmap:102 AMR/8000
a=rtpmap:8 PCMA/16000
a=rtpmap:4 G723/8000
a=rtpmap:116 telephone-event/8000
a=ptime:20
a=maxptime:20
*Nov 16 08:09:49.951: //2064/5927CD018C27/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 16 Nov 2023 08:09:49 GMT
CSeq: 1 INVITE
Session-ID: 00000000000000000000000000000000;remote=891094dc2221525ebd6f1ad4d0faf976
Content-Length: 0
*Nov 16 08:09:49.951: //2065/5927CD018C27/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.128.1:5060;branch=z9hG4bK69AE15
From: "77022119" <sip:77022119@192.168.128.1>;tag=561F87B-1574
Call-ID: 5928907F-838E11EE-8C2D9C93-DDEE99C1@192.168.128.1
Min-SE: 1800
Cisco-Guid: 1495780609-2207125998-2351406227-3723401665
CSeq: 101 INVITE
Timestamp: 1700122189
Expires: 180
Max-Forwards: 64
Session-ID: 891094dc2221525ebd6f1ad4d0faf976;remote=00000000000000000000000000000000
Content-Length: 217
v=0
o=CiscoSystemsSIP-GW-UserAgent 1591 8883 IN IP4 192.168.128.1
s=SIP Call
t=0 0
m=audio 8850 RTP/AVP 0 19
a=rtpmap:19 CN/8000
a=ptime:20
*Nov 16 08:09:49.958: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK6oc6vypybb9so9vnnycpvp5cv;Role=3;Hpt=8e42_36;TRC=ffffffff-ffffffff;X-HwDim=4
Call-ID: asbc0kzrxydvxu6zsndysuxkyzmtunud6dzw@10.224.248.107
CSeq: 1 NOTIFY
Max-Forwards: 67
Supported: 100rel
Event: ua-profile
P-Charging-Vector: icid-value=ATS9900-202311161053460062604;orig-ioi=1;icid-generated-at=quo.voiceft.rg
Content-Length: 190
<simservs>
</simservs>
*Nov 16 08:09:49.965: //2065/5927CD018C27/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Session-ID: 4701700800105000a00024813bb0004f;remote=891094dc2221525ebd6f1ad4d0faf976
Date: Thu, 16 Nov 2023 08:09:46 GMT
CSeq: 101 INVITE
Content-Length: 0
*Nov 16 08:09:50.084: //2065/5927CD018C27/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:214@192.168.128.14>;tag=24813bb0004f0137781a104a-565fb113
CSeq: 101 INVITE
Content-Length: 0
*Nov 16 08:09:50.086: //2064/5927CD018C27/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:+25321331564@X.X.X.X;transport=udp;user=phone>;tag=561F902-96
CSeq: 1 INVITE
Require: 100rel
RSeq: 9864
Content-Length: 0
*Nov 16 08:09:50.301: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bKc6bs0vu5anu9sco0p9u65p95u;Role=3;Hpt=8e42_36;TRC=ffffffff-ffffffff
CSeq: 2 PRACK
Max-Forwards: 65
RAck: 9864 1 INVITE
Content-Length: 0
*Nov 16 08:09:50.303: //2064/5927CD018C27/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 16 Nov 2023 08:09:50 GMT
CSeq: 2 PRACK
Content-Length: 0
*Nov 16 08:09:57.413: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 CANCEL
Max-Forwards: 65
Content-Length: 0
*Nov 16 08:09:57.416: //2064/5927CD018C27/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 16 Nov 2023 08:09:57 GMT
CSeq: 1 CANCEL
Content-Length: 0
*Nov 16 08:09:57.417: //2065/5927CD018C27/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1700122197
Content-Length: 0
*Nov 16 08:09:57.417: //2064/5927CD018C27/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Session-ID: 891094dc2221525ebd6f1ad4d0faf976;remote=4701700800105000a00024813bb0004f
Content-Length: 0
*Nov 16 08:09:57.422: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
*Nov 16 08:09:57.424: //2065/5927CD018C27/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Thu, 16 Nov 2023 08:09:53 GMT
CSeq: 101 CANCEL
Content-Length: 0
*Nov 16 08:09:57.429: //2065/5927CD018C27/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Content-Length: 0
*Nov 16 08:09:57.430: //2065/5927CD018C27/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Nov 16 08:10:00.511: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.128.14:5060;branch=z9hG4bK182ea43d
From: <sip:24813bb0004f@192.168.128.1>;tag=24813bb0004f013977a80c74-58011373
Call-ID: 24813bb0-004f0005-31f69be9-77cb4834@192.168.128.14
CSeq: 4 PUBLISH
Event: presence
Expires: 2147483647
Max-Forwards: 70
Content-Length: 465
</presence>
*Nov 16 08:10:01.933: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.128.13:5060;branch=z9hG4bK28a2f8e1
From: <sip:215@192.168.128.1>;tag=24813b45fe05011c05dd81cb-4deea76a
To: <sip:215@192.168.128.1>
Call-ID: 24813b45-fe050002-07becab2-680c5610@192.168.128.13
Max-Forwards: 70
Session-ID: b32792ef00105000a00024813b45fe05;remote=00000000000000000000000000000000
Date: Thu, 16 Nov 2023 08:09:58 GMT
CSeq: 249 REGISTER
Contact: <sip:1A978-21B8@192.168.128.13:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-24813b45fe05>";+u.sip!devicename.ccm.cisco.com="SEP24813B45FE05";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
*Nov 16 08:10:01.935: //2066/604D549D8C2E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:215@192.168.128.1>;tag=562274B-9F8
Date: Thu, 16 Nov 2023 08:10:01 GMT
CSeq: 249 REGISTER
Contact: <sip:215@192.168.128.13:5060>;expires=600
Expires: 600
Content-Length: 0
CME_Router#
Hi ,
From this trace, the call proceeds in 2,5 seconds. I guess that the previous interdigits config wasn't correctly applyed to IP Phones.
Please apply the config through the following command and retry:
create profile
apply-config
telephony-service
create cnf-files
reset
end
wr
Please let me know
Carlo
