11-16-2023 08:44 AM
Hi team,
I was working for some hours to troubleshoot incoming calls not working and outgoing calls PSTN (one side can't hear a thing)
Sympton is:
Call from external numbel > extension attends > external keeps calling > call dropped
I've checked ccapi inout logs and RTMT collect but no success finding the problem yet.
I se a disconnect cause 16 - Normal call clearing, and on router debugs I see "Transfer number is null".
The call flow is:
External phone > PSTN > h.323 > CUCM > Extension
Dial-peers:
Incoming dial-peer:
dial-peer voice 900 pots
description Incoming PSTN
incoming called-number .
no digit-strip
direct-inward-dial
port 0/0/0:0
Outgoing dial-peer
dial-peer voice 105 voip
description To CM Publisher
preference 1
destination-pattern 24....$
session target ipv4:10.243.70.5
voice-class codec 1
voice-class h323 1
dtmf-relay h245-signal
no vad
I'm going to attach the collected logs and running config
11-16-2023 10:39 AM
Does it happen for all calls or just for some extensions?
Please
Let me know
Carlo
