Incoming call not working-h323 gateway
SwathyEdayath
Dear All,
I am going through one issue that incoming calls not working for all users for h323 gateway. below is the isdn debug.
your help is much appreciated.
*Jun 28 07:17:34.180: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x7F00
Bearer Capability i = 0x8090A3
Standard = CCITTIP Telephony and Phones, IP Phones and Accessories, Other IP Telephony
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x2180, '0586155651'
Plan:ISDN, Type:National
Sending Complete
Called Party Number i = 0x81, '092081000'
Plan:ISDN, Type:Unknown
*Jun 28 07:17:34.181: ISDN Se0/1/0:15 Q931: Received SETUP callref = 0xFF00 callID = 0x001F switch = primary-net5 interface = User
SJH-MAL-KHORFAKHAN-IDFVG1#
*Jun 28 07:17:34.187: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xFF00
*Jun 28 07:17:34.187: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0xFF00
Cause i = 0x8081 - Unallocated/unassigned number
*Jun 28 07:17:34.201: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x7F00
*Jun 28 07:17:34.202: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xFF00
Jaime Valencia
Review your call routing, that means it cannot find that number because it doesn't exist, digit manipulation is required, or CSS/partitions are wrong.
java
if this helps, please rate
TONY SMITH
What is the call flow here?  All we can tell from your post is that it's coming in on ISDN (and not being matched).  You mention H.323 - is this a gateway talking to CUCM as H.323?  If so then you need to check the dial peers.
Can you post you whole configuration?
Please do a debug voip ccsip inout and posted the output as a attachment to the post reply.
Also please provide information about your setup and the call flow.
Response Signature
