talking too loud message?
alwayslearning
CUCM System version: 11.5.1.15900-18
Phones 8811 firmware sip88xx.12-7-1-0001-393
Users in two different buildings are reporting their phones are beeping and flashing a message on the phone display telling them they are being too loud. Initially I thought they were talking about paging and that someone was playing jokes. But the message displays on the phone screen, the only sound is a beeping tone.
8 Replies 8
Jaime Valencia
New feature on the 12.7 FW, review the RN
java
if this helps, please rate
I found it. Is there a way to turn that off in Call Manager or does it have to be done from the phone?
You can definitely disable it via the phone settings, but only Via the device menu and not centrally  via the CUCM.
George
Hope the above helps,
gsotirop
Check out CSCvt04894.
NOTE: This is a "feature request".
FYI, CSCvt04894 is now implemented in v12.8.1 and disabled by default.
George Sotiropoulos
This is "Lower your Voice" Notification and it was introduced on firmware 12.7. This is a feature that could be disabled.
George
gsotirop
is there a way to send curl or xml commands to disable this feature remotely?
3rd party apps like Variphy (probably others) can run macro's to replicate the button presses necessary to disable this feature at a device level.  You can run it against device types, devices pools...it can also be scheduled to run off hours.
This is what I just finished doing for about 2,500 phones.
