10-26-2011 01:53 PM - edited 03-16-2019 07:43 AM
I have a 2901 with 4 Pri T1 >connected to a CUCM 8.5 >and a 8.5 UCCX
when agents answer calls after a while this fall
how awesome is that the issue is random. on the router there are no errors in CO
and the only mistake was caught Cause i = 0x80FF - Interworking error; unspecified.
if anyone can help us be very grateful
10-26-2011 02:58 PM
Post the entire trace.
10-26-2011 03:48 PM
*Oct 23 15:22:55.318: ISDN Se0/1/1:23 Q931: RX <- SETUP pd = 8 callref = 0x0316
Bearer Capability i = 0x9090A2
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98396
Exclusive, Channel 22
Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Calling Party Number i = 0x0083, '8095323753'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '1411'
*Oct 23 15:22:55.318: ISDN Se0/1/1:23 Q931: Received SETUP callref = 0x8316 callID = 0x167C switch = primary-5ess interface = User
*Oct 23 15:22:55.322: ISDN Se0/1/1:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8316
*Oct 23 15:22:55.362: ISDN Se0/1/1:23 Q931: TX -> ALERTING pd = 8 callref = 0x8316
*Oct 23 15:22:55.546: ISDN Se0/1/1:23 Q931: TX -> CONNECT pd = 8 callref = 0x8316
*Oct 23 15:22:55.562: ISDN Se0/1/1:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x0316
*Oct 23 15:23:41.402: ISDN Se0/1/1:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x0316
*Oct 23 15:23:41.402: %ISDN-6-DISCONNECT: Interface Serial0/1/1:21 disconnected from 8095323753 , call lasted 45 seconds
*Oct 23 15:23:41.402: ISDN Se0/1/1:23 Q931: TX -> RELEASE pd = 8 callref = 0x8316
*Oct 23 15:23:41.426: ISDN Se0/1/1:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0316
10-27-2011 05:36 AM
Disconnect/error comes from telco, so you have to ask them why.
