Incoming call..when calling number starts with 9. only they get dial tone..
mshamkumar
Hi Experts,
                   This is some thing weird problem...whose area code starts with 9 and when they try to call FXO pots line after first ring they get dial tone then ends with fast busy signal...
When I tried with all possibilities I figured out that its hitting SRST dial peers:
dial-peer voice 8 pots
preference 8
destination-pattern 9T
incoming called-number .
port 0/2/3
when I removed or shutdown this dial-peers it works fine..
Check Below debug these captured when we have dial tone..
    Line 62:    Peer Info Type=DIALPEER_INFO_SPEECH
    Line 68:    Dial String=, Expanded String=, Calling Number=9018012250T
    Line 69:    Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
    Line 78:    Dial String=, Expanded String=, Calling Number=9018012250T
    Line 79:    Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
    Line 81:    Result=Success(0); Incoming Dial-peer=1 Is Matched
    Line 83:    Result=Success(0); Incoming Dial-peer=2 Is Matched
    Line 85:    Result=Success(0); Incoming Dial-peer=3 Is Matched
    Line 87:    Result=Success(0); Incoming Dial-peer=4 Is Matched
    Line 89:    Result=Success(0); Incoming Dial-peer=5 Is Matched
    Line 91:    Result=Success(0); Incoming Dial-peer=6 Is Matched
    Line 93:    Result=Success(0); Incoming Dial-peer=7 Is Matched
    Line 95:    Result=Success(0); Incoming Dial-peer=8 Is Matched
    Line 98:    Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=1
    Line 150:    Incoming Dial-peer=1, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
    Line 183:    Stop Tone On Digit=TRUE, Tone=Dial Tone,
    Line 205:    Fax Relay=TRUE, Dial Tone=TRUE, Digit Collect=TRUE, Overlap=FALSE, DID=FALSE
    Line 329:    Peer Info Type=DIALPEER_INFO_SPEECH
    Line 335:    Dial String=, Expanded String=, Calling Number=9TT
    Line 336:    Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
    Line 345:    Dial String=, Expanded String=, Calling Number=9TT
    Line 346:    Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
    Line 348:    Result=Success(0); Incoming Dial-peer=1 Is Matched
    Line 350:    Result=Success(0); Incoming Dial-peer=2 Is Matched
    Line 352:    Result=Success(0); Incoming Dial-peer=3 Is Matched
    Line 354:    Result=Success(0); Incoming Dial-peer=4 Is Matched
    Line 357: SCOTRT002#Result=Success(0); Incoming Dial-peer=5 Is Matched
    Line 359:    Result=Success(0); Incoming Dial-peer=6 Is Matched
    Line 361:    Result=Success(0); Incoming Dial-peer=7 Is Matched
    Line 363:    Result=Success(0); Incoming Dial-peer=8 Is Matched
19 Replies 19
I am sorry...I didn't abused or used any hurting language in these post....what ever I posted it was simple and straight forward that's it....even you think it was abusing language...I apologize...I am sorry for that....Thank you so much...
I am glad I could help. Dont forget to rate the posts!
Please rate all useful posts
Would you mind deleting the incomming called number . from the SRST dial peers.
Luis Sandi
kpranger1
I ran into this same issue.  I tried the recommended steps with no luck.  After working with TAC and enabling "answer-address ." to the MGCP dial peers, calls routed correclty.  This was applied to all mgcp dial peers.
Example:
dial-peer voice 999000 pots
service mgcpapp
answer-address .
port 0/0/0
I hope this helps someone in the future!
Keith
Thank you Friend.
When I had the same issue very long back I worked with tac and it was bug with code i was using on gatewasy for MGCP and I guess they added the same command to solved the problem.
