12-04-2014 04:20 AM - last edited on 03-25-2019 08:32 PM by ciscomoderator
Dear Experts,
can we manipulate the called URI number like we manipulate the digits (e.g Translation pattern) ?
can we have manipulate the incoming called number to match a route pattern
for eg. the called uri is 955XXXX@CUCM-address
route pattern 955XXXX ==> Voice Gateway
thanks for your help in advance
Anas
12-04-2014 04:33 AM
Why do you need to do this? The URI contains the target for the request. Why would you want to change it?
12-04-2014 05:09 AM
because it should match a route pattern not Directory ? it always return 404 not found
it comes as a URI because it is use SIP trunk to reach the CUCM
12-04-2014 06:36 AM
This is because the user portion of the URI in cucm will only match a directory number not a Route pattern as I explained in your other post.
12-04-2014 01:51 PM
is there work around for that ? I need to match a route pattern?
