Incoming calls creating many many call legs on unassigned extensions.
David Tamburin
We have a SIP trunk with some DID's on it.
When a person makes an incoming call to an assigned extension everything works fine.
When a person makes a call to an unassigned extension, it keep creating call legs until the sip trunk fills up.
I believe the call is bouncing back and forth between CUCM and the Voice Router.
If anyone could shed some light on why this is doing this, I would appreciate it.
Dial peer on router.
dial-peer voice 4001 voip
 destination-pattern 84578708..
 session protocol sipv2
 session target ipv4:10.104.10.13
 dtmf-relay rtp-nte
 codec g711ulaw
And there is a translation pattern in CUCM  84578708XX to 708XX
Here is a show statement as an example...   (8457870855)
rtr2951-1200RT300NBGNY-vg1#show call active voice compact
 <callID>  A/O FAX T<sec> Codec       type        Peer Address       IP R<ip>:<udp>
Total call-legs: 66
    867653 ANS     T350   g711ulaw    VOIP        P8457836333   10.101.122.246:21096
    867654 ORG     T350   g711ulaw    VOIP        P5343230       172.16.2.1:31606
    867660 ANS     T309   g711ulaw    VOIP        P8457036999     10.113.30.17:16422
    867661 ORG     T309   g711ulaw    VOIP        P5910839       172.16.2.1:33864
    867758 ANS     T179   g711ulaw    VOIP        P18455653978       172.16.2.1:30698
    867760 ORG     T179   g711ulaw    VOIP        P8457870855       172.16.2.1:30872
    867761 ANS     T180   g711ulaw    VOIP        P18457870855       172.16.2.1:35106
    867763 ORG     T180   g711ulaw    VOIP        P8457870855       172.16.2.1:31734
    867764 ANS     T180   g711ulaw    VOIP        P18457870855       172.16.2.1:30624
    867766 ORG     T180   g711ulaw    VOIP        P8457870855       172.16.2.1:30982
    867767 ANS     T180   g711ulaw    VOIP        P18457870855       172.16.2.1:35682
    867769 ORG     T180   g711ulaw    VOIP        P8457870855       172.16.2.1:30380
    867770 ANS     T181   g711ulaw    VOIP        P18457870855       172.16.2.1:31704
    867772 ORG     T181   g711ulaw    VOIP        P8457870855       172.16.2.1:30574
    867773 ANS     T210   g711ulaw    VOIP        P18453638148       172.16.2.1:31578
    867774 ORG     T210   g711ulaw    VOIP        P8455610990      239.192.1.1:16384
    867775 ANS     T181   g711ulaw    VOIP        P18457870855       172.16.2.1:30432
    867777 ORG     T181   g711ulaw    VOIP        P8457870855       172.16.2.1:30474
    867778 ANS     T182   g711ulaw    VOIP        P18457870855       172.16.2.1:35426
    867780 ORG     T182   g711ulaw    VOIP        P8457870855       172.16.2.1:31172
    867783 ANS     T182   g711ulaw    VOIP        P18457870855       172.16.2.1:30168
    867785 ORG     T182   g711ulaw    VOIP        P8457870855       172.16.2.1:31280
    867786 ANS     T182   g711ulaw    VOIP        P18457870855       172.16.2.1:30290
    867788 ORG     T182   g711ulaw    VOIP        P8457870855       172.16.2.1:30412
    867789 ANS     T183   g711ulaw    VOIP        P18457870855       172.16.2.1:30644
    867791 ORG     T183   g711ulaw    VOIP        P8457870855       172.16.2.1:31042
    867792 ANS     T183   g711ulaw    VOIP        P18457870855       172.16.2.1:30950
    867794 ORG     T183   g711ulaw    VOIP        P8457870855       172.16.2.1:30734
    867795 ANS     T183   g711ulaw    VOIP        P18457870855       172.16.2.1:30996
    867797 ORG     T183   g711ulaw    VOIP        P8457870855       172.16.2.1:31402
    867798 ANS     T184   g711ulaw    VOIP        P18457870855       172.16.2.1:30016
    867800 ORG     T184   g711ulaw    VOIP        P8457870855       172.16.2.1:35250
    867801 ANS     T185   g711ulaw    VOIP        P18457870855       172.16.2.1:32022
    867803 ORG     T185   g711ulaw    VOIP        P8457870855       172.16.2.1:30786
    867804 ANS     T185   g711ulaw    VOIP        P18457870855       172.16.2.1:30538
    867806 ORG     T185   g711ulaw    VOIP        P8457870855       172.16.2.1:35956
    867807 ANS     T186   g711ulaw    VOIP        P18457870855       172.16.2.1:35740
    867809 ORG     T186   g711ulaw    VOIP        P8457870855       172.16.2.1:30514
    867810 ANS     T186   g711ulaw    VOIP        P18457870855       172.16.2.1:31796
    867812 ORG     T186   g711ulaw    VOIP        P8457870855       172.16.2.1:35964
    867813 ANS     T186   g711ulaw    VOIP        P18457870855       172.16.2.1:35942
    867815 ORG     T186   g711ulaw    VOIP        P8457870855       172.16.2.1:30730
    867816 ANS     T187   g711ulaw    VOIP        P18457870855       172.16.2.1:35316
    867818 ORG     T187   g711ulaw    VOIP        P8457870855       172.16.2.1:30026
    867819 ANS     T187   g711ulaw    VOIP        P18457870855       172.16.2.1:30466
    867821 ORG     T187   g711ulaw    VOIP        P8457870855       172.16.2.1:35966
    867822 ANS     T188   g711ulaw    VOIP        P18457870855       172.16.2.1:30428
    867824 ORG     T188   g711ulaw    VOIP        P8457870855       172.16.2.1:30318
    867825 ANS     T188   g711ulaw    VOIP        P18457870855       172.16.2.1:30204
    867827 ORG     T188   g711ulaw    VOIP        P8457870855       172.16.2.1:32816
    867828 ANS     T188   g711ulaw    VOIP        P18457870855       172.16.2.1:30826
    867830 ORG     T188   g711ulaw    VOIP        P8457870855       172.16.2.1:31696
    867831 ANS     T189   g711ulaw    VOIP        P18457870855       172.16.2.1:31356
    867833 ORG     T189   g711ulaw    VOIP        P8457870855       172.16.2.1:32472
    867834 ANS     T189   g711ulaw    VOIP        P18457870855       172.16.2.1:31340
    867836 ORG     T189   g711ulaw    VOIP        P8457870855       172.16.2.1:30626
    867848 ANS     T149   g711ulaw    VOIP        P18454626621       172.16.2.1:30892
    867850 ORG     T149   g711ulaw    VOIP        P8455625855       172.16.2.1:31538
    867851 ANS     T149   g711ulaw    VOIP        P18457870855       172.16.2.1:30620
thanks,
Davidt
seems like the routing loop is happening around here, call that comes from ITSP than matches the dial-peer voice 1 . a dial-peer voice 4010 pointing to call-manager if there are any number that are not provisioned/configured .CUCM will send back 404 not fund to VGW then, then VGW hunt to the next dial-peer and find hit a dial-peer voice 4003 pointing to back to the provider at which point they will send the call back to use creating a loop.
Can you please add "huntstop" on these dial-peer also make two test call one for non-working another working and see the behavior .
dial-peer voice 1 voip
 incoming called-number .%
 dtmf-relay rtp-nte h245-alphanumeric
 codec g711ulaw
 dial-peer voice 4010 voip
 destination-pattern 8455625855
 dtmf-relay rtp-nte
 codec g711ulaw
 dial-peer voice 4003 voip
 destination-pattern [2-9]......
 session target ipv4:172.16.2.1
 voice-class sip early-offer forced
 codec g711ulaw
Br,
nadeem Ahmed
Br, Nadeem Please rate all useful post.
Nadeem Ahmed
Can you please send me show run from router and do you have debugs for any failed or loop call.
debug voice ccapi inout
debug ccsip message.
Br,
nadeem Ahmed
I tried number 5625855
 codec g711ulaw
 dtmf-relay rtp-nte
 codec g711ulaw
 codec g711ulaw
Br,
nadeem Ahmed
David Tamburin
Nadeem,
Thanks for the solution, seems to be working fine now.
